Old Aug 20, 2012, 11:01 PM
United States, CT, Old Lyme
Joined Sep 2011
Building supplies
So, I have been searching the spadflyers site and found a good source of corroplast on corrugatedplastics.net, but i'm having trouble sourcing the PVC pipe. Just wondering if people are still getting it direct from genova (sp?)?
paintmann111 is offline Find More Posts by paintmann111
Old Aug 21, 2012, 09:34 AM
Call me Frosty
TheRealFrosty's Avatar
Lawton, Oklahoma - USA
Joined Sep 2004
I have bought the canadian down spout from home depot as described in the following cut/paste text from the www.spadworld.net building materials thread. We still have a local Southerland's store that sells the american downspout, so I have not tried the Do It Best store purchase.
THIS IS UP TO DATE AS OF 8/2/2010
Genova RW200 ordered from Do It Best hardware 4pounds 2 ounces per 10 feet. presently under 10 bucks/stick.
eguttters.com K-pax 2.5 square and 3 pounds 4 ounces per stick, 3 sticks cut and shipped two 3 and 4 foot sections cost me 62 bucks.
Home Depot's SKU number 264-917 orders of 6 sticks(sold in packs 1minimum) of the Amerimax's PVC TO583. It is the 2 and 3/8 square Canadian PVC and weights 2 pounds 10 ounces per 10 foot section. 6 sticks cost me 45 bucks and shipping was free. Ya gotta go into the store order and prepay for it though.
You might try the same number (Americmax TO583) at Do it Best stores. They list Amerimax products online but they don't list the downspout, instead their downspout listed is the Genova RW200 HEAVY American.
frosty
TheRealFrosty is offline Find More Posts by TheRealFrosty
Old Aug 21, 2012, 07:01 PM
Joined Sep 2011
Thanks a bunch, i'll try home depot first.
Old Aug 22, 2012, 10:29 AM
Call me Frosty
Joined Sep 2004
keep in mind that the "Canadian" down spout is flimsier.
Old Aug 22, 2012, 06:15 PM
Australia, QLD, Booyal
Joined Aug 2011
Isnt it possible to ake an equivalent from corflute ? I think a bit of reinforcing and it could work
scrubmonkey is offline Find More Posts by scrubmonkey
Old Aug 22, 2012, 08:26 PM
Call me Frosty
Joined Sep 2004
Yep, it is done a lot. Easiest to make is a square tube with one side doubled where the glue holds it together. Basicaly 4 creased flutes for folds and 5 equal size faces.
Old Aug 23, 2012, 01:51 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
And shove some bamboo skewers or dowels in the flutes where you want a screw to hold like around the firewall and such. We have a Marvin's that sells the Canadian, but they're only down South, I think just Georgia, Alabama & Mississippi, but maybe you have a similar regional supplier you might try as well. Even a "Mom & Pop" hardware store could probably order it for you.
JohnsPop is offline Find More Posts by JohnsPop
Old Aug 26, 2012, 11:27 PM
Joined Sep 2011
Found the american made one at Aubuchon hardware. They readily stock it.
Old Aug 27, 2012, 10:26 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Awesome, now get to building!
Old Aug 27, 2012, 06:30 PM
Joined Sep 2011
haha will do. Wish we had 4mm coroplast at the local sign store. Just stinks to have to pay 20$ shipping on one case of 10 sheets.
Old Aug 27, 2012, 08:10 PM
Canada, ON, Cottam
Joined Jan 2012
Home Depot has the 4mm around here. It is pretty easy to get at most hardware stores. The highly covetted and desireable 2mm is harder to get.
aspeed is offline Find More Posts by aspeed
Old Aug 29, 2012, 08:51 PM
Joined Sep 2011
I thought everyone used the 4mm? The SNS calls for 4mm for the wings. Does the 2mm perform better?
Old Aug 30, 2012, 08:59 AM
Canada, ON, Cottam
Joined Jan 2012
It is lighter with the 2mm. It also bends into a smoother airfoil. I would think anything under a .40 should use it for the wing. If the plan calls for 4mm I would use it rather than trying to find 2mm, it is a hassle to get locally in most areas. Most smaller planes use the 2mm on SPAD to the Bone. You can roll up the 2mm, tape it and get it in the back seat of a car though, and maybe save the shipping if you can find it. You still will need 4mm for rudders and stabs.
Old Aug 30, 2012, 09:11 PM
Joined Aug 2011
Double up the 2mm for the elev and rudder and you can hinge in the middle of the surface
Old Aug 31, 2012, 01:00 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Blasphemy! You must have a good, cheap source for 2mm. With the shipping cost and aggravation, I would never double up 2mm for anything, I'd just use 4mm, but that's just me....
Sold Building Supply Lot 8KCAB Aircraft - General - Miscellaneous (FS/W) 4 Jul 11, 2012 07:31 AM
For Sale 20 amp power supply , " a real power supply " torqeroll Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jun 28, 2012 03:29 PM
How to build a 12volt power supply! tallflyer GWS (Grand Wing Servo) 7 Jun 30, 2004 01:10 PM
Question Building a power supply for brushless motors BillBrian Batteries and Chargers 18 Dec 14, 2003 10:41 AM
Scratch Building Supplies ??? Xlogic Power Systems 3 Jun 25, 2002 12:33 PM
