Old Aug 20, 2012, 08:17 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
what is the point using gimbal with vib damper when you mount with rubber band?
honestly... im lost.. when i was searching about the gimbal threads in the forum.. there are like half of them using rubber band to fix the camera on gimbal...
well i dont see if there is any screw mounted at bottom.. i assume not cuz then you dont need a rubber band
so... tell me... WHY
jy0933 is offline Find More Posts by jy0933
Old Aug 20, 2012, 08:36 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Rubber band is NOT a good vibration damper. Rubber band can cause excitation instead of damping.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Aug 21, 2012, 01:58 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Rubber bands are evil
gitit20 is offline Find More Posts by gitit20
Old Aug 21, 2012, 01:59 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
yeah, i know. right? but i have seen almost 70%+ goprop mounting using rubber band.... and im totally lost
Old Aug 21, 2012, 03:56 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
how else would you mount it without making a case for it?
since the gopro has no thread on bottom for mounting, the only way to mount a gopro on a plain surface like the bar of a gimbal is to use rubber band, tape or velcro.
warthox is offline Find More Posts by warthox
Discussion BOLT ON WING MOUNTING (converting from rubber band) Wylie Shaw Sailplane Talk 15 Aug 17, 2012 04:24 PM
Question gaurdian - Only works when you point the plane symbol to the tail of my aircraft mjc1970 Eagle Tree Systems 4 Jul 31, 2012 07:38 AM
Discussion Camera Anti Vib Mount -test flight (Dampers from CD ) guyg Aerial Photography 1 Mar 12, 2011 04:30 PM
Discussion What rubber band and where do you get? mpodder Hand Launch 4 Oct 19, 2009 06:06 PM
What Size Rubber Bands can be used to secure Sky Scooter Wing? Tfour2 Beginner Training Area (Aircraft-Electric) 10 May 11, 2003 10:56 PM
