Old Jan 26, 2013, 06:44 AM
x5252x is offline
Find More Posts by x5252x
Joined Jun 2010
Originally Posted by bbz View Post
is there anywhere i might find a 2.5k ohm resistor in old electronics or what not?
No, you cannot get a 2.5k resistor that I am aware of, take a look at your local electronics shop or online and find the closest value you can to what you need.
x5252x is offline Find More Posts by x5252x
Old May 13, 2013, 03:24 AM
Don Chucho is offline
Find More Posts by Don Chucho
You are what You do
Don Chucho's Avatar
Bucharest/ Romania
Joined Oct 2005
micro brushed car ESC form a servo board
Great Topic
Would like to give it a try but there are two more things that are missing:
1) What would be the maximum voltage handled (2S LiPo possible?),
2) What would be the maximum Amps handled by this micro ESC and if it's too low how and where to insert some FET's?
I'm trying to use this for an Iwaver 02m (1/24 car) modded for 2.4GHz
Don Chucho is offline Find More Posts by Don Chucho
Old Aug 06, 2013, 03:04 PM
x5252x is offline
Joined Jun 2010
Originally Posted by Don Chucho View Post
Great Topic
1) Depends on the servo you use, most will accept a voltage of 2S.
2) Again, depends on your servo, could be a few amps.
If you were wanting to use this for a 1/24 car I would advise against it, it's a fairly large scale compared with what this tutorial was designed for, a 1/24 scale motor could be pulling a fair amount of power.
It is hard to find such small ESCs like in the tutorial, however have a look on eBay and I'm sure you'll find a few listings for new brushed ESCs that will fit fine with your scale.
Old Feb 28, 2014, 11:11 AM
microairman1 is offline
Find More Posts by microairman1
Team Heads up RC
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
Do you need any resistors or does it work with out them?
microairman1 is offline Find More Posts by microairman1
Old Jun 08, 2014, 11:51 AM
Kasuhico is offline
Find More Posts by Kasuhico
Joined Mar 2010
Is there a way to avoid reverse?
I would like to use it as a PWM-Analog converter.
So I could translate servo signal to analog voltage from 0v to 5v.
Kasuhico is offline Find More Posts by Kasuhico
Old Nov 24, 2014, 08:08 AM
andrewedwardjudd is offline
Find More Posts by andrewedwardjudd
Joined Oct 2014
Hi, While waiting for parts from HK, I cut off a 70t03GH FET from an old computer board and used this as the only extra component to take the low current coming from the servo motor to drive a proportionally driven 5w light bulb. I am sure i could have used a higher current device if i had one ready.
I used the pot adjusted as best i could by hand as i had broken gears. I could not stop the motor from spinning rapidly but it did not matter.
So while my servo controller had a tiny area where the motor reduces power/voltage before reversing direction, my DX6 TX was easily able to enable me to have a smooth rise in voltage from zero to 4.89V across the entire throttle stick using just a large amount of subtrim and a throttle curve ending at 14%.
The FET was a fun device. You can for example turn the FET on and off just using your finger if you are near a person who is touching the other side of the circuit, but it works faster if your other hand touches the other side of the circuit.
Unfortunately once i had it prototyped and i resoldiered the FET it stopped working, and given the time and effort to cut these FETs off a board I decided to wait for the HK parts i needed rather than continuing what was seeming more and more like reinventing the wheel:-(
andrewedwardjudd is offline Find More Posts by andrewedwardjudd
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Discussion Using a brushed esc as a dimmer for led xraydoc Night Flying 6 Feb 17, 2011 04:40 PM
Question Reduced brightness when running led through brushed esc - why? xraydoc Night Flying 3 Aug 30, 2010 04:29 AM
Mini-HowTo I made a Servo as a Power Switch using a 5v Relay: my how-to guide with video + pics! HoaRC DIY Electronics 2 Jun 30, 2009 11:08 AM
