Old Aug 20, 2012, 06:39 PM
bulldogmatto is offline
Find More Posts by bulldogmatto
Joined Aug 2012
Heng Long Crystals
Hello fellow tankers - I would like to add crystal #4 to my Heng Long KV 1 .[I]t is the basic one with plastic gears and tracks, #3878[/.I] However, there is no 2 hole receiver for it on the only circuit board inside of the tank - I have seen on a how to video a second circuit board that the crystal plugs into . can anyone please advise me on if and how I can install the crystal ? Any input would be greatly appreciated - Thank You - Matto
bulldogmatto is offline Find More Posts by bulldogmatto
Old Aug 20, 2012, 07:33 PM
FreakyDude is offline
Find More Posts by FreakyDude
FreakyDude's Avatar
Canada, ON, Barrie
Joined Jul 2011
Matto The reciever board where you need to add or change the crystal is slightly behind the RX18 controller. It is upside down and has 4 small screws holding it down, One in each corner. Should be a blue or green color. Take those 4 screws out turn the reciever board rightside up and pull the old crystal out, add the new crystal and re attached the board to the tank with the 4 screws.
should be easy peasy.
FreakyDude is offline Find More Posts by FreakyDude
Old Aug 22, 2012, 12:39 PM
Joined Aug 2012
KV 1 Crystal change
Thanks for your help - I don`t believe I can do it - from what you are saying I should be able to swap old for new . There is no crystal to remove (eveything is soldered) and I realized the controller doesn`t have the socket to plug in the crystal . It is an ABC channel tank - the more expensive ones probably have the removeable crystals .
Old Aug 29, 2012, 06:46 PM
FreakyDude's Avatar
Canada, ON, Barrie
Joined Jul 2011
post a picture of your reciever board, lets have a look at it because even if it is soldered in you can still change it.
Old Aug 30, 2012, 09:25 AM
buckeye36 is offline
Find More Posts by buckeye36
buckeye36's Avatar
Egg Harbor Township, NJ
Joined Mar 2010
Sounds like you have a non-smoke&sound tank, uses a 3 position switch on both tank and transmitter---no removable crystal.
buckeye36 is offline Find More Posts by buckeye36
Old Sep 02, 2012, 12:38 AM
Rustbucket is online now
Find More Posts by Rustbucket
Portland Oregon
Joined Aug 2006
HELLO I am asking the same question so what do you about changing it out and how many problems are involve ?. What all do you have to change out or is it eveything ?
if you go to the up dated board something tells me you change everything including the radio unless there is way to do the radio with out going for one with the christals ??
HEY Freaky Dude I sent you an E mail and never got any answers on my questions ?
Just wondering. FOR i am thinking of the way I told you about but I can see a couple of problems doing it the other way.
SO I am still looking for answers. I hope I did push your way.
YOU were helping me and I was starting to learn a few things thanks to you .
By the way did you check out those sights I sudjusted to ya I hope your weeken goes good. talk to ya when you get the time .
thanks again DON
Rustbucket is online now Find More Posts by Rustbucket
Discussion How to improve firing power of airsoft heng long tanks Othor11 RC Tanks 20 Jan 05, 2014 10:39 PM
Help! Heng long tank distance control problem Othor11 RC Tanks 16 Jan 20, 2013 06:05 PM
Help! Heng Long Panzer IV Tank Loose connection? kenjara RC Tanks 4 Jul 26, 2012 08:30 AM
Help! Broken gear on heng long Pershing Peter27 RC Tanks 4 Jul 21, 2012 11:44 AM
Discussion Heng Long Panther - disassembly instructions / mini guide? rjsdavis RC Tanks 2 Jun 19, 2012 03:23 AM
