Old Oct 09, 2012, 04:25 PM
Dr Totakt is offline
Find More Posts by Dr Totakt
Dr Totakt's Avatar
Norway, just north of the arctic circle.
Joined Jan 2009
Originally Posted by KaiWE View Post
Thank you, Petter
I see now that I must have lights too - looks really cool!
They have a few really good items at HobbyKing, this product is one of them.
I highly recommend this, just plug and play.
Link
Dr Totakt is offline Find More Posts by Dr Totakt
Old Oct 16, 2012, 11:56 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Got mine in, busy now with another project but can't wait to get it up and flying.
rotagen is offline Find More Posts by rotagen
Old Oct 26, 2012, 08:41 AM
mikhail tupulov is offline
Find More Posts by mikhail tupulov
Switzerland
Joined Aug 2012
Which plane?
I really like the newest version (orange). Very short take off roll out! The flaps are icing on the cake.
mikhail tupulov is offline Find More Posts by mikhail tupulov
Reply With Quote  (Disabled)
Old Dec 28, 2012, 10:08 PM
OnTheEdge is offline
Find More Posts by OnTheEdge
Drum, Pa
Joined May 2006
Just got mine finished tonight. It's supposed to snow here tomorrow so not sure about a madden although if there's a way, I'll fly it. Nice plane overall. Went together well. Did a few mods to my liking.
Hopefully some of you guys are out there experimenting with other props. While the stock one looks scale, I'm thinking it's not the most efficient. Not looking for more power but battery efficiency.
OnTheEdge is offline Find More Posts by OnTheEdge
Old Jan 17, 2013, 04:15 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Got another airplane from EasySky in the air today, a YaK-12.
Tecnically identical with the Wilga, and flies just as nice - maybe even nicer, the main wing is stiffer due to the four struts...
Ready for Dawn Patrol over the Tundra:
KaiWE is offline Find More Posts by KaiWE
Old Jan 20, 2013, 06:09 PM
Drum, Pa
Joined May 2006
I got an email from HK last week about the Yak. Looks nice. At first I thought they just borrowed the cowl from the Wilga, but after looking up photos of the Yak 12, it looks some what scale. I may get one next order as I really like the Wilga. I've been flying at an indoor dome several times. Really liking it. Servos leave a little to be desired due to poor centering. Flew it outdoors on a windy day and did well there too. Wheels are a little small for grass landings but if it rolls over it doesn't do any damage.
The Wilga can really slow down with the flaps. Having a blast with it.
Old Feb 04, 2013, 12:36 PM
Seahawk One is offline
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Was able to maiden mine yesterday. Although a bit tail heavy with my 2S 1300mAh, she could still float at low speed. Needed 7-10 feet (2-3m) to take off, which was hard packed dirt for yesterdays flights.
I was worried about her feet breaking as the wheels are mounted to a spring loaded plastic contraption that I guess is rather scale. I did have a few aggressive landings as I was adjusting flaps, and so far so good. I am hoping the flexible wire type LG will absorb most of the shock when landing. I also flew without the foam wire covers.
Spectators not familiar with the Wilga pretty much called her an ugly duckling. But I'm happy to report they all felt she was as beautiful as a swan in the air.
I like the side door with locking handle. Plenty of room inside the tiny fuse and even though I don't have huge hands, tricky to get in and around.
The 2S 1300 I used is sort of long, so even though I balanced at the 50-52mm, I will see if I have any 2S that are shorter and thus help place the CG a bit forward.
I will probably add the kit on one of my next orders from HK International that has only a few small things.
Nice cheap floater! I like!!
Neil
Seahawk One is offline Find More Posts by Seahawk One
Old Feb 05, 2013, 03:50 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Was out flying the Wilga and YaK, comparing their abilities and behavior - on the end of the second battery in the YaK, the aileron servo failed. Turned around with rudder and landed undamaged. The Wilga behaved perfect , but I am now a bit skeptical to the EasySky servos, with two failing after minimal use - guess I'll swap them all out to be on the safe side...
Old Feb 06, 2013, 11:34 AM
USA, WA, Seattle
Joined Aug 2007
Thanks for the info KaiWE. Thus far, I've only got three batteries through my Wilga but I may replace the servos as preventive maintenance.
Cheers~
Neil
Old Feb 07, 2013, 02:54 PM
gordynic is online now
Find More Posts by gordynic
scotland
Joined Jul 2003
Hi guys, well I had mine delivered yesterday, it came in a moulded polystyrene box with a cardboard outer lid and travelled fine. Ive been over the plane and I'm undecided yet if I will modify it first, or fly it as it comes out the box.... I have a list of the likes and dislikes so far
1. Ilike the simple engine mount and how easy it is to give side and down thrust.... but it looks a bit flimsy
2I do like the ease of access through the side door , but will it need a magnet after a few flights?
3.the control surfaces are free moving and fairly slop free, so they'll stay as they are
4. I really think it calls for two 5 gram servos for the ailerons, but as it comes they seem to work ok
5 I like the look of the wire U.C. but the springs are a bit naff, maybe needs adiifferent spring set up, maybe with a coil or two wrapped around the pivot
The dislikes I have are because of my own personal preferences
1.I don't like the length of unsupported wire between the fuselage and the rudder , same for the elevatot
2. the rods going into the flaps are floppy , I will probably replace them with something a stronger/thicker
3 As I said earlier, it needs servos fitted into the wings...not a big job
4.I am not sure that the wing spars are man enough for the job and will last , or should I fitt a 3mm carbon tube
this is not a critisism of this plane, I am not even starting to build it properly for the next two weeks , as my grandkids are visiting next week and my workroom (roomshed, shed room ) has to be emptied so they can sleep there
this is going to be an interesting build/modify
gordynic is online now Find More Posts by gordynic
Old Feb 08, 2013, 03:13 PM
USA, WA, Seattle
Joined Aug 2007
gordynic,
I swear I had echoed essentially just about all the same concerns you mention when I first got her and prior to building/flying, but I can honestly say I was pleasantly surprised at how well the push rods and connectors work. Same with the controls at the end of the ailerons. But after attaching these together, seems to work just fine. I can't see any adverse/excessive play and in the air she seems just fine in terms of input and maneuverability.
I did however adjust the servo horn on the flaps as I didn't feel like it moved enough. I've got about 60° of deflection which is more like brakes now. So maybe I shouldn't have needed to adjust them at at all.
All said, I encourage you to maiden as it came, then reassess. I think this would also help potential buyers see your before and after thoughts.
One of the lightest wing loadings in my fleet.
Regardless, love the input, thoughts and pics and look forward to see all the mods you end up doing!
Curious to see if yours is tail heavy as well- at the 52mm CG location.
~Cheers,
Neil
Old Feb 08, 2013, 04:38 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Got mine assembled today.
This looks like it is going to be a favorite! I am impressed with the engineering.
I, too, thought the flap-travel looked a little skimpy, but I am going to fly it as is first.
I think that the spring of the main gear music-wire is all that is required, and that the coil-spring mechanism is just a nice looking adjunct. We shall see.
More after I test-fly it.
Lancer31 is offline Find More Posts by Lancer31
Old Feb 08, 2013, 04:48 PM
USA, WA, Seattle
Joined Aug 2007
Lancer31, I agree with the springs being more cosmetic than functional and that the main gear/uc suspenion will be from the wire itself.
That said, have you figured out a way to install the orange strut covers so that they can flex with the lg/uc and not just pop off? I've flown without them because of being unsure how to mount without them popping off on every landing....
Neil
Old Feb 08, 2013, 06:24 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
I glued the orange struts with UHU POR, and they have stayed on for the 50+ flights I have on her. I was also very sceptical in regard to the U/C and pushrods initially, but I have not encountered a single problem after having replaced the upon-arrival-faulty elevator servo.
Have maxed out the throws on all linkages, and I cannot wish for more. In fact the elevator is over the top, I can do loops with 12 inch radius (without stalling/snapping at the top)...
Flying with 60 degrees of flaps is pure fun, can fly as slow as my HZ Champ
Will keep this one as stock as possible, have added nav lights, but that will be the only mod.
But I have a kit that I will turn into a Super/Fun Wilga with dual aileron (2x6g) servos, stronger motor, stiffer wing etc. I am looking forward to experiment with spoilerons/flaperons in addition to the flaps - the full scale Wilga 35 use drooping ailerons in addition to the flaps for extreme STOL...
Discussion Everything wilga (Sapac Wilga 2000 Mods, Vids etc...) KentuckyRanger Foamies (Kits) 93 Oct 16, 2015 09:32 PM
Build Log 3 meter Wilga build Big Nuts 181 Scale Sailplanes 81 Jun 08, 2015 05:33 PM
Wanted Wilga 35 dong727 Aircraft - Fuel - Airplanes (FS/W) 1 Jul 08, 2012 02:02 PM
Wanted Wilga 35 dong727 Aircraft - Electric - Airplanes (FS/W) 0 Jul 08, 2012 12:49 PM
Discussion Wilgas Wilgas! Ranfred Radius Scale Sailplanes 10 Aug 08, 2008 04:48 PM
