Old Oct 11, 2012, 03:05 PM
pmisuinas is online now
Find More Posts by pmisuinas
Springfield, VA
Joined Feb 2000
Originally Posted by simplyfly View Post
The stock model is flyable, with no changes.
Manufacturer Recommended System
motor :37/40 400Kv
60A ESC
6s 2800 - 3200mAh
AUW: 2.5Kg
I am working on mine, and I just don't see why you would want to do this. I am instead using a different motor, a Scorpion 3026-10, Kv 980, on 4S. Calculated performance is:
APC 11x7E on 4-cell Li-Po operation (14.0 volts)
Amps - 56.4
Watts - 789
RPM - 10,625
Thrust - 102 ounces (6 pounds 6 ounces)
Pitch Speed - 70 MPH
APC 12x6E on 4-cell Li-Po operation (14.0 volts)
Amps - 62.46
Watts - 874
RPM - 10,475
Thrust - 122 ounces (7 pounds 10 ounces)
Pitch Speed - 60 MPH
I don't know why they recommend the weight and expense of a 6S system, unless it's needed to achieve the CG location. I have not reached that point yet, so maybe that is the driver...Pete M
pmisuinas is online now Find More Posts by pmisuinas
Old Oct 11, 2012, 06:55 PM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
With 6s 5000, it balances well with the packs located toward the back of the cabin...
The 42/58 is much heavier than the scorpion 3026, so smaller packs may still balance well. I tried 4s 3000mAh, and its too light with the 42/58 500kv. I could change the motor to 35/36 1400Kv...
simplyfly is offline Find More Posts by simplyfly
Old Oct 16, 2012, 12:20 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Thanks for the responses simplyfly and pmisuinas.
Out of curiosity, what FPV gear are you running? I also have a LR setup, but do not have the courage to install it on a floater... I am using DL signal with Lawmate 1.2 1000mW vtx, GoPro HD, RVOSDv5, Dominators and cross hairs on the ground, spw on the ship. Next purchase is to add a RMRC 540.
Despite their being higher resolution cameras on the market, this 540 has the best low light capabilities of all that I have seen.
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Oct 27, 2012, 10:37 AM
go ahead and try
Joined Nov 2011
I am using Open LRS w/ booster, Cyclops OSD, x-bee modems, 800mW VTx, 650TVL, 1g mini cam x2, RC922's, no head or antenna tracker....
Old Jan 07, 2013, 07:08 PM
Renfield is offline
Find More Posts by Renfield
above us only sky
Renfield's Avatar
United States, SC, Greenville
Joined Jan 2006
Where are they now?
Anyone have a good lead on where to buy the big one today?
Renfield is offline Find More Posts by Renfield
Old Jan 12, 2013, 09:26 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
I guess everyone who's interested already has one. I have the electronics and no foam, because the LHS over promised and under delivered.
I'll try KMP again. But their referral to a dealer in FL was a dead end. Some of the China direct options are tempting. Three for $44/ea.
Discussion Whats happening at Wybung? HUMPHREY1957 Australia 1665 Today 06:47 AM
Discussion what happened to the 1/25 concorde? aferguson Foamy EDFs 20 Feb 23, 2015 06:01 PM
Question What happened? MikeRx Electric Plane Talk 5 Jun 18, 2012 12:05 PM
Discussion What happened to the RCG icon? HappyKillmore Site Chat 12 Jul 19, 2010 07:50 PM
Discussion What happened with the giant Skyhawk? MtnGoat Slope 4 May 09, 2007 01:02 PM
