Old Aug 19, 2012, 02:21 PM
flylowfast is offline
Find More Posts by flylowfast
Joined Jun 2009
Build Log
Experiment with a new (?) type of airfoil
Yesterday I started building a high wing micro plane who would be quite stable and well behaved after having many problems with my two previous micro plane builds (here and here).
In order to simplify the building of the main wing I thought of cutting off the leading edge and gluing in on top of the wing.
Thus, the wing has a sharp leading edge and also a step in its thickness, similar to the KF airfoils (see attached pictures).
Yesterday, I only did the main wing and cut out the elevator.
More to come, although this build will proceed at a slow pace due to many other obligations.
flylowfast is offline Find More Posts by flylowfast
Old Aug 19, 2012, 07:55 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
once you start getting down to the very small scale, airfoil data does not always scale down. birds that thermal for hours look very differnt from top of the line gliders.
is this going to be scale looking?
nemoskull is offline Find More Posts by nemoskull
Old Aug 20, 2012, 03:54 PM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
I like the idea...but yeah, you may well see very little difference to a 'standard' wing.
The cuts give a good look to the wing shape and may reduce tip stalling in slow flight. That sort of thing seems to help with backyard gusts of wind too. Either which way, it looks better than a school ruler
Another thing perhaps, is to sand upward underneath the wing. While most shapings indeed don't matter much, it works like reflex on a flying wing. The airflow is just more stable out of the back of the wing, heading onto the tail. I've had good results with a 45 degree sanding on the lower leading edge and less of an angle but deeper into the wing at the rear.
Slider2732 is offline Find More Posts by Slider2732
Old Aug 21, 2012, 05:21 AM
Joined Jun 2009
No, since this is not a model of a real plane.
It will look mostly like a high wing trainer.
Old Aug 21, 2012, 05:23 AM
Joined Jun 2009
On the leading edge there is not a lot of material left to sand the lower surface.
On the back edge, I could sand or cut a bit off, but I doubt it will have any effect.
Discussion Experiments with KFm airfoil on 'Elf' DLG glider JetPlaneFlyer Foamies (Scratchbuilt) 118 Jun 30, 2012 11:46 PM
Discussion New Plane with new Airfoil launches 263 feet! ifome Hand Launch 8 Apr 02, 2012 12:07 PM
Question "bird" type flying wing, with or without reflexed airfoil? KenSt Flying Wings 6 Aug 31, 2011 06:22 AM
Discussion Experiences with different types of glue Raidenflight Foamy EDFs 1 Oct 07, 2010 06:29 AM
Discussion Scratched-built Wing, with a K-F type airfoil Rusty-Gunn Foamies (Scratchbuilt) 8 May 09, 2007 02:40 AM
