Old Aug 19, 2012, 12:41 PM
bovick is offline
Find More Posts by bovick
Failed RC 10 step program.
United States, IN, Indianapolis
Joined Nov 2006
How to disable 2.4 on 8FG for use with EZUHF?
Does anyone know if 2.4ghz is disabled automatically when the trainer port connector is plugged in (appropriate pins shorted) or is there some other way to do it manually?
bovick is offline Find More Posts by bovick
Old Aug 19, 2012, 02:23 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
It is disabled by default if you short two pins in trainer port... it just output PPM stream.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Aug 19, 2012, 03:27 PM
Paul C. is offline
Find More Posts by Paul C.
Paul C.'s Avatar
Joined Mar 2012
There's how I disable the 2.4
Paul C. is offline Find More Posts by Paul C.
Old Aug 19, 2012, 09:03 PM
bovick is offline
Joined Nov 2006
Paul, can you confirm or negate Farmer_Joe's comment about it being disabled by default when trainer is plugged in with the pins shorted? If that comment is correct, then I wouldn't want to mess with making a swtich as you show, but if the 2.4 is still on, then I'll go grab my soldering iron Also, the photo doesn't seem to show an 8FG...
Old Aug 19, 2012, 10:06 PM
anixs is offline
Find More Posts by anixs
Edmonton, AB, Canada
Joined Oct 2002
No surgery required... Just hold down the RTN button when turning on your 8FG. Then select "RF OFF."
anixs is offline Find More Posts by anixs
Old Aug 20, 2012, 02:28 AM
Paul C. is offline
Paul C.'s Avatar
Joined Mar 2012
I can't tell you if the 2.4 is disable when the trainer is plugged.
Try to do that
Old Aug 20, 2012, 02:48 AM
bovick is offline
Joined Nov 2006
anixs... I knew that one, but when plugging in the trainer cord, holding RTN does not take you to the "RF ON/ OFF" screen as when you just power up normally. The on/off switch in my case is in OFF when I plug in the trainer cable.. and the shorted pins DO turn it on as it's supposed to.. but holding RTN in that case doesn't do anything. I've tried. :/
Old Aug 21, 2012, 07:45 PM
bovick is offline
Joined Nov 2006
Ok, the workaround I am now using is to have the throttle above minimum when plugging in trainer cord. This makes the 8fg prompt me with the throttle warning and asks if it should transmit or not... so simply select no here
Question Disabling gyro on MCX brick.(how?) tippytoe Coaxial Helicopters 5 Jul 14, 2012 07:35 PM
Discussion EzUHF on my Futaba T7C 2.4 Paul C. FPV Talk 0 Jul 08, 2012 02:11 PM
Wanted WTT Used Futaba 3PM-2.4 with NO RX for a FS-gt3b with RX tconners Cars - Accessories (FS/W) 1 Jun 11, 2012 07:45 PM
For Sale FUTABA 8FG 2.4 for sale pipercubdude Aircraft - General - Radio Equipment (FS/W) 25 Jun 11, 2012 10:44 AM
Help! Futaba 7c 2.4 + EzUHF on a 5Ah 3S LiPo, will that work? hardhat Radios 2 Feb 17, 2011 03:00 PM
