Old Sep 19, 2012, 06:55 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Hey Paul,
I'll e-mail you.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Sep 19, 2012, 01:48 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Wheels
I tried a different approach to these wheels since Pete suggested that heavier wheels would be beneficial in providing some needed weight in the short D.VIII nose. (I normally do wheels this way).
So I searched out some appropriate tire material and settled on #18 O-Rings from Lowe's (a home improvement store in the US). Cut out Depron hubs, beveled the front, added 1/16 Aluminum tube centers, applied tissue, and added the tires. They spin nearly true on the .8mm wire axle I plan to use.
I had to mask and paint Pete's outer wheel covers since it's near impossible to apply a tissue decal to the cone while keeping a straight stripe. The picture below is photo deception - the stripe is in fact straight. Note that I painted Pete's tires the correct gray - haven't decided on mine since I like a subdued black/gray.
Now I just need to tone down the weathering and do some minor touch up.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Sep 19, 2012, 02:32 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
WooHoo! Gene they look great! I've gone to using smaller diameter brass for my wheel hubs that way I can use thinner wire to have better spring action. I'm not sure of the .08 wire diameter vs the aluminum tube ID.
The wheels were well thought out and built mine with two fifferent covers too inside and outside.
BTW I got your super cool cowling lots of work went into getting that difficult part spot on! Well done Sir and thank you also for Z micro camera. Now I gott figure out how to use it no instuctions.
Pete
Old Sep 19, 2012, 03:12 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Now you tell me....
Now I got to figure out how to use [keychain camera] with no instuctions.
It's is an old #3 808 camera - the line is up to #18 as of today! I sent you an email last week with lots of links to instructions, suggestions, etc. For starters, it doesn't get much better than right here on RCGroups. However, since that's a560 page thread, you'll have an easier time finding more distilled info here.
It's charged up and ready to go, so shoot and post away!
Gene K
Old Sep 19, 2012, 03:14 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
... [you] built mine with two different covers too inside and outside.
As is mine.
Gene K
Old Sep 19, 2012, 07:13 PM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
Well here I go let's see if this works, the video is of a dogfight scene with Fokker triplanes
Dog Fighting WWIMicro planes (2 min 30 sec)
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Sep 19, 2012, 07:15 PM
Crazy Canuck
NEWBEFLYER's Avatar
Joined Apr 2007
WOW! It really does work! I'm soooo cool ...look out RCG I'm posting videos whipppeee!!!!Here's Pete's Neauport video
Pete's Neauport (5 min 17 sec)
Old Sep 19, 2012, 07:17 PM
Crazy Canuck
NEWBEFLYER's Avatar
Joined Apr 2007
The "Intel Den" with the guys
Pete in The Intel Den (2 min 58 sec)
Old Sep 27, 2012, 05:25 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Engine Progress
In an effort to copy Pete's amazing rotating engine on his NP-11, I searched the Internet for more info on the Fokker D.VIII's Oberursel-UR2 engine. Among the great info I found (besides that provided by PiperCub49 and UNGN in Pete's NP-11 thread) were plans for a 1/33 paper model, and also many graphics, including these beautiful illustrations.
I downloaded the paper plan and scaled it for the ROF cowl, and it became (more) obvious that the Depron cowl was too thick to house a scale-diameter engine. Accordingly, I proceeded to use my trusty Dremel to remove foam from the inside of the cowl: the resulting thin fiberglass shell is flexible, but I'll reinforce the end with a former that holds the magnets that will attach the cowl to the firewall.
Shown below are pics of a partial mock up of the paper engine and the slimmed cowl.
Gene K
Old Sep 27, 2012, 08:20 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Gene,
Excellent effort...
Toni....
If your out there... Help! Your designs made by Shapeways would be so cool in the D.VIII....
We'll carry on.....
Pete
Old Sep 28, 2012, 07:13 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Excellent effort...
Thanks, Pete. Hopefully it'll work as well as yours!
The engine center sections are 110#-card covered Depron, drilled to accept an Aluminum or brass bearer for the prop shaft. In the first picture, you can see the tool that I used to "wrap-up" the cylinders.
The paper model designer did a great job!
Gene
Old Sep 28, 2012, 09:03 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Wow! that looks great... Do you think the cylinders will hold up? Are they card stock (heavy paper) ? I'd use a brass tube if you have some. As I think that will be more true and hold up better. If you can you may want to place a disc of light ply on the back side/inside with the foam and brass/aluminum tube.
Is the clearance ok?
Pete
Old Sep 28, 2012, 10:08 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Absolutely. I used Por to mount the open-ended cylinders, and then put a healthy drop of Elmer's white glue into each before adding the top. Feels very strong.
Yes, 110# Velum rolled around a screwdriver handle to form.
It will be tight with details added to the top of the cylinders... but, I think I may be overkilling on details. Test fitting to the installed PZ Mustang motor will tell the tale.
Gene K
Old Sep 28, 2012, 01:59 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Looks like you've got it. Remember you'll be adding some down and right thrust to the P-51 shaft. That may give you less room.
Does the P-51 spur and big gear fit inside or do you even need it to with the shaft extension? BTW I have 4 micro brass nuts that will fit the brass shaft extension. I'll put one in the mail with your MG's when I do your motor (I'm going to make two). I'll show you a picture of my Voss DR-I as I just put the extension shaft on mine. It makes it look cool with my soda can aluminum prop hub plate. Well at least if your using the PZ P-51 prop.
BTW did you see in the 1:24 scale paper build I sent the metalic paper the builder used? That could make a pretty good looking motor too.
What glue did you use at first when making the cylinders? Where did you get your card paper?
What's the weight at this point of your motor?
Pete
Old Sep 28, 2012, 02:30 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Doesn't need it with the extension, but I may make another motor that is "hollow" enough to house the gear (thus precluding use of the extension)..... still figgerin'. No need to make a motor for me, Pete, as I have this one figured out - thanks!
Great -- I'll be looking in your Voss thread .
Unfortunately, that paper's no longer available (for those interested in an amazing paper over-the-top D.VIII build, see here).
I used Elmer's Rubber Cement to form them, then Por to attach them to the hub. The card stock came from my old paper model stash - I think I got it at Office Depot.[/QUOTE]
Making the engine has been a neat excursion for me, just like making the cowl. I may even make some real progress on the airframe next week.
Gene K
Build Log Mini Micro Fokker D-VI PorschePylot Foamies (Scratchbuilt) 27 Nov 24, 2015 07:38 AM
Discussion Start of Micro Fokker D.VII mtflyr Scratchbuilt Indoor and Micro Models 53 Sep 14, 2012 10:01 AM
Sold Balsa USA Fokker D-VIII 1/4 Scale Kit. *NIB* richardc951 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 28, 2012 01:57 PM
For Sale Balsa USA Fokker D-VIII kit 1/4 scale nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 08, 2012 03:32 PM
Allan's Fokker D.VIII Mr. Wiz Electric Plane Talk 0 Jul 25, 2001 09:05 AM
