Gulf Breeze, FL
Joined Jul 2006
No, no, no.....NO! Besides being too thick, you'd lose it all on the very hot fuser!
Naptha is great for UHU cleanup - it will remove excess on seams without any bad effects on the foam or tissue (much better than rolling up little gum balls with your finger). Just use a "dampy" paper towel and don't flood the seam else it will dissovle . Naptha is also useful for thinning the UHU. Thanks to a tip from Freddie B, I tried Elmer's Rubber Cement to laminate foam (as for a cowl), and it's perfect for sanding edges without raising gum balls or riges as UHU would. I'm away from home, and hopefully won't have to return early to board-up for Hurricane Isaac! Also hope it will spare you too, Glenn! Gene K |
Gulf Breeze, FL
Joined Jul 2006
Gene K |
Fabulous. Subscribed.
Latest blog entry: My Favorite of Favorites
Gulf Breeze, FL
Joined Jul 2006
I came back early today to do my "hurricane prep". If it hits here, it will be my third hurricane in eight years. Time to retire somewhere else....maybe....but then, paradise is worth it. By the way, I served many years down your way at McDill AFB.
However, I've tried many times, but finally gave up after ruining a great Epson inkjet. My challenges included, among other things, getting foam thin enough (I slice my own, but it didn't have the strength I thought I needed), aligning the patterns on both sides of the foam for double sided printing, and "the bother" of going through Inkaid application and waterproofing the final product. So I don't necessarily agree that "it makes more sense to run the foam through an inkjet." Considering the advantages (to me) of tissue-printing (waterproof, added strength, no Depron thickness limitation, ease of making round sections without creasing, etc, etc), I settled on printed tissue. I haven't given up on trying to print directly on Depron, so I donated some equipment to Pete to figure it out for me - he has more time to play than I do. ![]() Back to Huricane Prep.... Gene K |
| Thread Tools | |
| Build Log Mini Micro Fokker D-VI | PorschePylot | Foamies (Scratchbuilt) | 20 | Feb 18, 2013 01:24 PM |
| Discussion Start of Micro Fokker D.VII | mtflyr | Indoor and Micro Models | 53 | Sep 14, 2012 10:01 AM |
| Sold Balsa USA Fokker D-VIII 1/4 Scale Kit. *NIB* | richardc951 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jul 28, 2012 01:57 PM |
| For Sale Balsa USA Fokker D-VIII kit 1/4 scale | nero1156 | Aircraft - Fuel - Airplanes (FS/W) | 1 | Apr 08, 2012 03:32 PM |
| Allan's Fokker D.VIII | Mr. Wiz | Electric Plane Talk | 0 | Jul 25, 2001 09:05 AM |
