Old Aug 19, 2012, 05:17 AM
advera is offline
Find More Posts by advera
Joined Sep 2004
Help!
KK2.0 with DJI ESC'S possible ?
Hello Members,
as an beginner i like to ask you if somebody has experience using
DJI OPTO ESC's with the KK2.0 Board ?
If so please tell us how you realised it
THX
Herbert
advera is offline Find More Posts by advera
Old Aug 19, 2012, 05:42 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
An ESC is an ESC.
The problem starts when you have ESCs not suitable for multicopters, such as DJI escs.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 19, 2012, 07:00 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Yes, with the exemption of the autopilot system and the Z-15, DJI is just re-labeling off the shelf R/C equipment like the rest of them.
jab is offline Find More Posts by jab
Old Aug 19, 2012, 07:45 AM
advera is offline
Joined Sep 2004
DJI ESC with KK2.0
Hello,
i think i have to use one ESC which supplies 5Volts at M1 on the KK2.0 Board
But there is no 5V at the red lined "PIN" from the DJI ESC :-(
Also i have no experience with using an UBEC at M1
so it seems to be a problem using the DJI 's ????
Any Idea ?
I do not want to buy compatible but think i must do so ???
thx
Herbert
Old Aug 19, 2012, 08:29 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
Originally Posted by advera View Post
Hello,
Any Idea ?
thx
Herbert
http://www.hobbyking.com/hobbyking/s...Reduction.html
Old Aug 19, 2012, 09:03 AM
advera is offline
Joined Sep 2004
hey jab
of course BUT i also have to connect the ESC at the SAME M1 Port
is it possible ?
[/I]
Old Aug 19, 2012, 09:20 AM
timecop is offline
Joined Dec 2010
Use Y-Cable
Old Aug 19, 2012, 09:49 AM
advera is offline
Joined Sep 2004
y-cable
How to use it ?
Old Aug 19, 2012, 05:57 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
How to use it ?
Your asking how to use a Y cable?
I dont have the enthusiasm right now to draw a picture.
So here is a picture from the web.
Replace "RX" with the M1 output on your KK2 controller.
Dont worry about removing any red wires because the DJI ESC's are optically isolated, no BEC built into them so there is no requirement to remove the red wire.
Y cable you can buy or build.
Sad Sack is offline Find More Posts by Sad Sack
Old Sep 28, 2012, 12:22 AM
brownegg24am is offline
Find More Posts by brownegg24am
United States, MI, Troy
Joined Sep 2012
IS there a website you could show me where I could buy this?
brownegg24am is offline Find More Posts by brownegg24am
Old Sep 28, 2012, 12:32 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
http://www.ebay.com/itm/5X-300mm-Ser...item3f1a5dcf1e
Remember to remove the red wire on the Y cable that leads to your ESC. Just like the diagram above shows.
AcroFPV is offline Find More Posts by AcroFPV
Old Sep 28, 2012, 01:29 AM
Joined Sep 2012
do you simply cut the red wire and thats the end of it or do you have to go all the way in and remove it?
Old Sep 28, 2012, 01:31 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
You can cut it.
Old Nov 24, 2012, 02:53 PM
danv is offline
Find More Posts by danv
Joined Nov 2012
KK2 M1 will not start with Exceed 40A OPTO and Hobby Wing 3A ubec
I cannot get M1 to start. I,m trying to use (4) Exceed Proton 40A OPTO ESC'S on a Quad with A Hobby Wing (3) amp switching UBEC to supply power to the KK2. Using a made-up Y cable to connect the opto esc and ubec to the M1 connection - KK2 powers up and M2, 3 & 4 start but M1 will not start. Dissconected red ( ) wire from the esc plug and tried again - M1 will not start. Disconnected the white signal wire from the ubec connection - still M1 will not start. Switched esc's around they are all good. Any Ideas???
danv is offline Find More Posts by danv
Old Nov 26, 2012, 08:15 AM
MediEvilKenEvil is offline
Find More Posts by MediEvilKenEvil
Joined Nov 2012
KK2 Connections
I'm no expert on this, I've just built my first quad (DJI F450 with KK2 1.5) and the way I did it was to power the board with the BEC on M1 (no Y-lead) and then copy the default setting from M1 to M5 and connect the 1st ESC to that position and the rest as normal (M2,M3,M4). Works a treat! I zeroed all the settings at the M1 connection. Hope this helps.
MediEvilKenEvil is offline Find More Posts by MediEvilKenEvil
Question V-Tail Quad copter with HK KK2.0 Multi-Rotor Control Board horst1903 Multirotor Electronics 3 Dec 16, 2012 11:14 AM
Discussion KK2.0 Hexacopter with Stabilized Gimbal? Foam boy Multirotor Electronics 3 Nov 07, 2012 05:55 PM
Question Can I run my KK2 board & ESC's off my Bench Power Supply? AcroFPV Multirotor Electronics 18 Aug 16, 2012 12:44 PM
Found Need 2 Avroto 2814's and 2 DJI 30A ESC's Goanna Aircraft - Electric - Multirotor (FS/W) 1 Apr 19, 2012 12:32 AM
Sold DJI F450 Frame with Motors and Esc's ROCKY2 Aircraft - Electric - Multirotor (FS/W) 1 Feb 26, 2012 10:20 PM
