Old Sep 30, 2012, 11:53 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
For me, more important would be selecting a finish which will hinder the seasonal change of moisture content within the wood and make it easy to clean up glue spills while preventing accidental bonding to model parts without contaminating model surfaces.
loNslo is offline Find More Posts by loNslo
Old Sep 30, 2012, 11:56 AM
CafeenMan is offline
Find More Posts by CafeenMan
Florida
Joined Dec 2001
Well, I've yet to get any glue on my fixtures so I don't worry about that too much. If you want durability then polyurethane is probably the way to go. Then wax the fixtures with a good furniture paste wax.
CafeenMan is offline Find More Posts by CafeenMan
Old Sep 30, 2012, 01:08 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Points well taken - thanks.
Staining is an art unto itself. A particular stain will penetrate different wood, well, differently, and deliver different results. A particular stain can show more say red in one wood than another. Two different stain on two different words can come out looking very close to one another.
When I laid-out my cutting schedule of the fixtures, I challenged myself to leave as little waste as possible. The result was that I ended-up with several 1/4" to 3/8" 10"-15" strips. I pulled out several stains I have on-hand in my shop and tested them on the scrap strips. I've decided on Minwax's Puritan Pine for the fixtures. It really penetrated well, and it brings-out the grain of the birch. And, being that I'll be banding the building board's edges with oak, I like the match.
Why all this staining and fancy finishing? Maybe it will hide the infractions of my model building!
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Oct 08, 2012, 12:12 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Bought a length of hard maple to mill the fixtures presses and a few other things.
The fun part of this project is that I am using my acquired woodworking skills into the R/C flying hobby.
I started with a 5' long by 6+" wide X 4/4 (just over 3/4") length of hard maple. The board was cut in half length-wise to two 24+" boards. Each board was fed through my jointer to establish a clean, square edge. Oversize strips were milled using my bandsaw to minimize kerf waste. If I had milled the boards using my table saw, each cut would have consumed a 3/16" kerf as opposed to the 1/32" kerf of the bandsaw. In other words, the table saw -vs- the bandsaw: the table saw creating a 5:1 loss ratio over the bandsaw. The sequence was:
- squaring the board through the jointer/planer
- cutting the (oversized) width through the bandsaw
- repeat...
Of course, I lose a bit of the board when it is re-squared each time after it is fed through the bandsaw.
Now I have to break-out the planer and bring these strips to specification.
EJWash
Old Oct 08, 2012, 01:59 AM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
That is some really hard material.
I also work back and forth between the table saw and band saw. This often helps to minimize warpage.
Old Oct 08, 2012, 02:08 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Yeah it is. Feed into the bandsaw was s l o w. Results are good though. Minimum waste was the goal.
EJWash
Old Oct 09, 2012, 12:50 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Hard maple milled to spec.
Finished the fixture presses feet. Ended-up with 47 of them. No chance of all of them being in use as one time, but now I have enough extras to last a VERY long time.
EJWash
Old Oct 09, 2012, 04:29 AM
mikempp is offline
Find More Posts by mikempp
United States, FL, The Villages
Joined Nov 2008
I bought a kit from him, love them, the last model i built has to be the straightest model i hav ever built thanks to his system. very happy with my purchase.
mikempp is offline Find More Posts by mikempp
Old Oct 09, 2012, 07:06 AM
Florida
Joined Dec 2001
Very nice, EJ. I love working with hard maple. If you have saws that can cut it properly then you get the smoothest wood and it is very hard. It finishes beautifully. I definitely prefer closed-grain woods. That's why my stuff is maple and cherry and never oak or other open grain woods. Just don't like them.
Mike - Thank you for the kudos. I really appreciate it! What did you build?
Old Oct 09, 2012, 10:47 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
CafeenMan,
Thanks.
I like working with hard maple too. It comes out of the planer so nice. Just a couple of passes with the sander and you're done. Tough as steel too!
EJWash
Old Oct 09, 2012, 10:48 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Mike,
How about posting some pics of your System in action?
EJWash
Old Oct 11, 2012, 12:21 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Milled the bridge press blocks. Ended-up with 24 of them. Probably will never use that many at one time, but here they are...
EJWash
Old Oct 11, 2012, 06:54 AM
Florida
Joined Dec 2001
Don't feel bad. I have about 50 - all cherry or hard maple with clamp pads to go with them. I also made rotating clamp pads and press bolt adapters.
Old Oct 11, 2012, 08:11 PM
Jerseydog is offline
Find More Posts by Jerseydog
Jerseydog's Avatar
United States, NJ, Carteret
Joined Apr 2011
Ejwash1 I was wondering do you have a sketch of the jig you made for drilling the holes on the fixtures? I was wondering what are the distance between the holes. I just bought a drill press and will like to put it to good use.
Jerseydog is offline Find More Posts by Jerseydog
Old Oct 11, 2012, 11:08 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Jerseydog,
No sketches of the jig, but I spaced the press holes 1" on-center.
EJWash
Discussion Magnetic Building Board chawkins Sailplane Talk 7 Aug 18, 2012 09:44 AM
Sold GP magnet building Board warbirdguyn951 Aircraft - General - Miscellaneous (FS/W) 3 Jun 19, 2012 12:01 AM
Wanted Building Clamps for a Magnetic Building Board stevster Aircraft - General - Miscellaneous (FS/W) 1 Jun 14, 2012 07:29 AM
magic magnet building board system jojo Electric Plane Talk 16 Jul 27, 2008 11:29 PM
Beware of Great Planes Magic Magnetic Building Board System Red Baron 47 Electric Plane Talk 8 Jul 19, 2001 10:24 PM
