Old Jan 28, 2013, 09:53 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Squared-up four of the 3-1/2" fixtures and attached presses to them. Glued one of the Waco's center section spars in place to give the presses a go.
I'm sure that there will be challenges using this system. It is not a catch-all solution to building and I did not throw away my building pins. But it is simple, and I'm already enjoying it.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Jan 29, 2013, 07:18 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Originally Posted by EJWash1 View Post
Just had to give the board a go Tom, haven't decided if I'm going to dive into the Waco head-long yet or not. I still have to square the building board fixtures.
The board does feel pretty natural though.
EJWash
You've got a start on the WACO. If you put it aside now, the parts will get lost.
TomCrump is offline Find More Posts by TomCrump
Old Jan 29, 2013, 10:07 AM
CafeenMan is offline
Find More Posts by CafeenMan
Florida
Joined Dec 2001
On the bit about raising and lowering your bench...
Every time I see an ambulance stretcher rolled into our hospital I think something like that would be pretty awesome. They can support a lot of weight but they aren't the most rigid things in the world. But I think an adaptation (someone mentioned scissor jack) would work well - particularly if they had some kind of tube-in-tube legs at the corners that could be clamped.
CafeenMan is offline Find More Posts by CafeenMan
Old Feb 05, 2013, 08:02 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
I think I've found an avenue to a vertical adjustment.
The table in the pics adjusts from 24" to 48", but I can't see needing more than a 8"-10" swing. Though having more than that would be available.
Now all I need to do is figure out a design for the base, maybe with drawers.
EJWash
Old Feb 05, 2013, 09:59 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
That looks like a motorcycle lift which has been adapted. It will likely not be rigid enough to provide a stable platform.
loNslo is offline Find More Posts by loNslo
Old Feb 05, 2013, 11:39 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thought about that. Hopefully the local Harbor Freight has one assembled and on the floor. I'll be able to see it up close. A rock solid surface isn't necessary.
EJWash
EJWash
Old Feb 05, 2013, 11:40 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
EJWash
Old Feb 05, 2013, 11:41 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Old Jul 29, 2013, 10:41 PM
T_om is online now
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
No updates from you in a long time, but reading this thread was a pleasant way to spend this evening. Thanks.
Hope you are into building your model now that you have the pro-style bench complete.
Tom
T_om is online now Find More Posts by T_om
Old Jul 30, 2013, 11:35 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Hi Tom,
The building board went right into use. I'm currently building a Dave Platt Waco YMF-3 on it:
http://www.rcgroups.com/forums/showthread.php?t=1806391
The building board is sitting on top of my woodworking bench. I still have to come-up with an adjustable height system for it and band it with some sort of wood.
EJ
Old Jul 30, 2013, 12:27 PM
T_om is online now
The Junk Man
Joined Jul 2006
Great to hear.
Tom
PS: I am a woodworker and my vacuum bag setup came from Joewoodworker too.
Old Jul 30, 2013, 12:29 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Cool!
Is there a pic of it on the website?
EJ
Old Jul 30, 2013, 12:38 PM
T_om is online now
The Junk Man
Joined Jul 2006
I built two. The venturi system first (and I use it the most because it is SO light, small, and fast). http://www.joewoodworker.com/veneering/v2-about.htm
And this one for smaller bags (4x6 and smaller) since I had a nice GAST pump sitting around (my 30 year box is overflowing.) . http://www.joewoodworker.com/veneering/EVS/concept.htm
In both setups I just use lengths of capped 4" PVC pipe as vacuum chambers and they work fine.
Tom
Old Jul 30, 2013, 12:49 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thought about the venturi system just to save (precious) storage space. Harbor Friehgt had a sale on the air tanks though, and I had all the other "stuff" (except the pump and fittings) so I went with the tank style.
Fun stuff!
EJ
Old Aug 14, 2013, 07:38 AM
Koarl is offline
Find More Posts by Koarl
Joined May 2010
Looks awesome! Congrats!
Does anybody know a source for these magnets in europe? I couldn't find any.
Koarl is offline Find More Posts by Koarl
Discussion Magnetic Building Board chawkins Sailplane Talk 7 Aug 18, 2012 09:44 AM
Sold GP magnet building Board warbirdguyn951 Aircraft - General - Miscellaneous (FS/W) 3 Jun 19, 2012 12:01 AM
Wanted Building Clamps for a Magnetic Building Board stevster Aircraft - General - Miscellaneous (FS/W) 1 Jun 14, 2012 07:29 AM
magic magnet building board system jojo Electric Plane Talk 16 Jul 27, 2008 11:29 PM
Beware of Great Planes Magic Magnetic Building Board System Red Baron 47 Electric Plane Talk 8 Jul 19, 2001 10:24 PM
