Old Nov 22, 2003, 09:58 AM
t_predator90 is offline
Find More Posts by t_predator90
-=Futaba RuLEz=-
t_predator90's Avatar
Netanya, Israel
Joined Sep 2002
Question
Free 1/2A plans & prices for 1/2A engines?
Hi.
I'm thinking of going into 1/2A planes, and I wanted to know:
Is there anywhere I can get free 1/2A plans form?
Also, how much do .049 engines cost?
Thanx for any input
t_predator90 is offline Find More Posts by t_predator90
Old Nov 22, 2003, 10:42 AM
Lynn S is offline
Find More Posts by Lynn S
Bolivar, TN
Joined Feb 2003
This site has several free plans. The Littlest Stick is a good one but has to be enlarged on a copy machine to be .049 size.
It is for a .010 with a 19 inch wingspan in the original size.
At the 150% size it has a 30 inch wingspan. You do not need incidence in the wing if you have elevator.
http://my.pclink.com/~dfritzke/index.html
At the bottom of the page is a link for a lot of classic 1/2 A plans for $6.00 each.
You can get a Cox .049 Black Widow for around $35 and a AP .061 for $39 The Norvel .049 and .061 are about $10 more.
www.quantummodels.com
Be sure to look at the Ace r/c models at Quantum models.
The Whizard is a great one to start with and uses a .049 engine.
Lynn S is offline Find More Posts by Lynn S
Old Nov 22, 2003, 05:27 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Also you can download many plans for smaller electric motors and must beef up the nose area slightly to allow for 1/8 plywood firewalls or beam mounts to mount the engine to. Figure anything with about 200 to 300 sq inches of area depending on how fast you like to go and how lightly you build.
Go to www.google.com and enter in the search words "free model airplane plans download" but without the quotes and you'll find a lot of links or pages with links.
A lot of the plans offered will be smaller or larger than you want. But a lot of those plans will be DXF or DWG files for CAD. If you take the time to learn how to do basic scaling you can modify the plans to suit whatever size engine you want. Of course sometimes the materials and methods may need modification but if you use other plans of the correct size as a guide it's not that hard to fill in the modifications needed.
Your engine prices may vary based on your location. You are in the best position to say how expensive the engines are in Israel.
BMatthews is offline Find More Posts by BMatthews
Old Dec 10, 2003, 11:36 PM
pgjoh1 is offline
Find More Posts by pgjoh1
Ah nuts, almost made it
pgjoh1's Avatar
Brisbane, Australia
Joined Jul 2002
Hey, some great links there. I am getting into this 1/2A plane stuff too.
Pete
pgjoh1 is offline Find More Posts by pgjoh1
Old Dec 14, 2003, 05:59 PM
Remby is offline
Find More Posts by Remby
1/2a Flyer!
Russell, PA
Joined Sep 2003
Free plans site
Hello,
Look at ...
http://plans.rcmodell.hu/
Everything free, but must look through everything to find the wanted ones. Hope this helps!
Remby
Remby is offline Find More Posts by Remby
Discussion Plans for 1/2A Joystick kf2qd 1/2A Planes 16 Jun 16, 2016 04:59 PM
For Sale 1/2A engines, parts + c/l access.lower prices jim e Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 22, 2007 11:01 AM
Discussion Aerobatic/Fun-Fly or Pattern plans for 1/2A? FlattyFlier 1/2A Planes 34 Jan 15, 2007 05:12 PM
For Sale Lanier Indicator 1/2A engines props jim e Aircraft - Fuel - Airplanes (FS/W) 0 Dec 01, 2006 01:39 PM
FS/FT Cox engines, parts, 1/2A starter ndflicks Aircraft - Fuel - Airplanes (FS/W) 4 Aug 13, 2004 08:57 PM
