Old Nov 22, 2003, 09:46 AM
aeropal is offline
Find More Posts by aeropal
aeropal's Avatar
Joined Jan 2003
"High End" Receivers For "High End" Cams
Although the Hitec Micro 555 and Electron 6 are pretty much the "gold standard" in the lightweight dual-conversion category, FMA Flight Systems Receivers may also reduce the pucker-factor-anxiety associated with using the more expensive multi-megapixel cameras. The two-transmitter signature discrimination test described on page 17 of the White Paper pdf is very impressive.
aeropal is offline Find More Posts by aeropal
Old Nov 22, 2003, 11:06 AM
yb2normal is offline
Find More Posts by yb2normal
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
I am totally jonesing for one of these new systems. The system's ability to 'learn' virtually any aircraft setup simply by waving your hand in front of the heat sensors and moving the transmitter sticks is an amazing leap in functionality.
It wasn't clear to me from the documentation if the new unit will still offer control of the gain 'on the fly'... does anyone know?
Regards,
Bill
yb2normal is offline Find More Posts by yb2normal
Old Nov 22, 2003, 11:45 AM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I have my eye on the the $250 package. As soon as you early adopters help FMA iron out the engr wrinkles I'll take the plunge.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Nov 23, 2003, 02:50 PM
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
"engineering wrinkles"?
Now there is a phrase I don't want to hear while I have $800 worth of stuff in the air
Old Mar 19, 2004, 08:51 AM
aeropal is offline
aeropal's Avatar
Joined Jan 2003
Another contender:
Sky & Technology/enRF
Old Mar 19, 2004, 02:48 PM
RandyK1 is offline
Find More Posts by RandyK1
Fiberglass dont bounce???
RandyK1's Avatar
Zion, Il.
Joined Sep 2002
What about the Berg receivers? The new Berg 6G rx has Transmitter Signal Recognition (TSR) of the receiver learns the characteristics, or the signature of the transmitter, and this makes it compatible with all brands of FM transmitters. It also has Fail Safe (FS) or Signal Hold and Auto-detection modulation polarity shift so the rx will work with pos. & neg. shift radios. It has Digital Signal Processing (DSP) in the servo pulse decoder for optimum performance in even the worst RF environments. All for $79.95, thats pretty good. The new Berg 5 DSP II has everything that the 6G does, execpt the 5 dosnt have Fail Safe and thats only $49.95. Berg rx's are all I use now, and I have never had a problem. http://www.aeromicro.com/berg6g3.htm ...R...
RandyK1 is offline Find More Posts by RandyK1
Wanted looking for high end yamaha piano keyboard Eeeeky Non R/C Items (FS/W) 4 Aug 09, 2007 06:46 PM
Question Ideas for a high power setup? samotage High Performance 41 Aug 01, 2007 08:59 PM
Found Looking for a High wing aileron trainer 4 channel Plane kit.............. mtdoramike Aircraft - Electric - Airplanes (FS/W) 11 Jun 17, 2007 04:43 PM
Wanted Futaba FM and PCM receivers in High Band Jim Frahm Aircraft - General - Radio Equipment (FS/W) 0 Sep 16, 2005 03:27 PM
Two Futaba R149DP Receivers - New (high band) plasmaman Aircraft - General - Radio Equipment (FS/W) 0 Jan 19, 2005 11:03 AM
