Old Oct 02, 2012, 11:20 AM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
no this is with 9305 HET fan
i don't know if it 'll last forever but it keeps the 56000rpm for the moment
i have to say that i balanced the rotor with specific tools and spin perfectly
gianni sanchez is offline Find More Posts by gianni sanchez
Old Oct 02, 2012, 11:34 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Was this the motor you used? 700-83-1445 on 12s?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 02, 2012, 02:31 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I'm waiting for the maiden vid
pavcon is offline Find More Posts by pavcon
Old Oct 02, 2012, 03:30 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Gianni what type of primer did you use on the glassed foam?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Oct 02, 2012, 03:33 PM
pavcon is offline
Joined Jan 2010
Whos Gianni ? ? ? ELLHNAS RE???
Old Oct 03, 2012, 05:22 AM
GeorgeStyriaII is offline
Find More Posts by GeorgeStyriaII
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
Hi Gianni,
cool projekt!
I´m working also on a fast and funny 12s version of this jet...
Regards
George
(Is it ok for you, when i post some pics here? If not, i delete.)
GeorgeStyriaII is offline Find More Posts by GeorgeStyriaII
Old Oct 03, 2012, 03:28 PM
Joined Jan 2012
this is the HET motor 700-83-1445kv 12cells on 90mm Het fan, normally 10 cells on 110-120mm fan as we talked about together few posts before, i've decided to not use the jet fan witch i've heard this won't keep the 12cells set up
robert, i'm using PU primer , or also fuller to fill last cavities from fiberglass, spray putty from Motip work well too!
or any PU paint u could find should do the job
George! very clever mods u did here!!!nice job on the single seat mods!feel free to use this thread for your bullet! the more mirage in the air ,the best it is !
and as i say i enter in a very busy periods for work and worst, the weather is crap for the moment so it'll takes me a while to go at the field again
i keep on posting pics and maybe get the weathering process on the jet if i have time to do it
Old Oct 04, 2012, 03:57 AM
Joined Dec 2008
C/N is using these in his 144" T-38 TALON
http://www.rcgroups.com/forums/showp...postcount=2387
don't know where you may have heard that, but I am planning to use 12s on mine , somewhere between 4.5-5Kw.
Old Oct 04, 2012, 06:18 PM
Joined Jan 2012
don't think is the same motor we talk about
corsair nut use the 1200kv on 12 cells (witch i already use in 12s in another mirage 2000 jepe)
that set up works fine and pretty fast ,but this one is just hair dryer compare tothis 700-83-1445kv , we talk about 7000watts here not 3300watts, more than double so....
here's the ice castle data after first test, u can read almost 7000watts , 168A and 56000rpm
witch is a bit more for all numbers in flight ,
so that's why i don't think the jet fan wont keep that numbers and rpm's!!
when the 1200kv is not a problem altrough for this fan
Old Oct 10, 2012, 05:34 AM
Joined Sep 2011
some progress
Hi,
now the "Lander TV systeme" is fixed...
And there is enought space for 2x 6s5000mah batteries...
George
Old Oct 10, 2012, 02:31 PM
Joined Jan 2012
that sounds good!
what's your motor/fan set up?
Old Oct 10, 2012, 02:57 PM
Joined Dec 2000
Hey Gianni i spoke with jp today. he likes your cheetah!
Old Oct 10, 2012, 03:56 PM
Joined Jan 2012
here's the latest pictures before maiden
i'm in a slow process to finish it ,weathering,decals, etc,...
can't wait to fly again with this beast!!
Old Oct 11, 2012, 03:40 AM
Joined Sep 2011
that sounds good!
Hi Gianni,
i will use a Jetfan90 V2.
The motor schould have about 1200kv (HET 700/68/1200) or maybe i try a "softer one" - HET700/60/1120kv (than i can use it in the future in a lite twin MiG )
I have also a JF90 with a HET700/68/1400 laying around - but 12s wouldt be more than "NOS" to this
George
Old Oct 11, 2012, 06:42 PM
Joined Jan 2012
yes i think the 68-1400 would burn pretty quick on 12cells
i have a jet fan in another mirage for test with a 68-1200kv on 12cells
well .... it's a good fan but push way under the vasafan i've tested just before on the same mirage , vasa is a really efficient fan ,also amps hungry, but best for speed trials
i have a video witch i'll upload soon to show how it goes with the jetfan
Question who makes this mirage 2000? out of stock Electric Ducted Fan Jet Talk 3 Jul 27, 2012 07:01 AM
Found if someone has a crashed fly fly mirage 2000 I need a vertical fin sherlockshah Aircraft - Electric - Jets (FS/W) 1 Jul 12, 2012 08:11 PM
Discussion Riccs Mirage 2000 Ace_Brat Electric Ducted Fan Jet Talk 6 Jun 21, 2012 12:05 AM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
