Old Aug 29, 2012, 03:28 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
Originally Posted by CoolerByTheLake View Post
To your question:
"here's some more details of my build
does anyone already used this motor on 12s ??
i expect a lot of power and big top speed from it
but i would appreciate some feedback "
NO! It's only rated from 7-10s. At 12s you will most likely fry it.
http://shop.rc-electric-jets.com/HET...00-83-1445.htm
I had crunched a few numbers last week trying to find the loaded Kv of a few of the Het motors, this was one of them. On average they are about 85% of unloadedKv. So figure around 1228Kv X pack V. On 10s@3.85V per cell, gives you over 47.7K rpm. Now he was using the Jetfan 90 in the F-86, but if you noticed his numbers, ( 121 amps max, 4.4kw max.) you won't get much more for Kw. Don't get me wrong, 4.4Kw is nothing to sneeze at, but for more top end, you might have to squeeze down exhaust dia. a little at a time. Once you get past the sweet spot, amps will GO up. Will be watching progress.
Here's another with the Het 700-83-1445Kv on 10s. System specs in first part of video.
http://www.rcgroups.com/forums/showp...&postcount=766
i 'm half agree with u ...
this are numbers for up to 100-120mm fan isn't it?
the 700-83-1445kv is basically designed for such a fan in 10 s ,so after talks with several people ,that won't be a big deal for the motor to work on 12cells on a "small "90mm fan, i 'm not 100% sure of course, and that's why i 'm half agree.
i actually ordered some jetfan 90mm and plan to swap my het fan to this one before first flight..
here's 700-83 spec pdf file
thank to share your opinion
take alook at this too
http://www.extremerc.com.au/estore/i...b19933995d4997
gianni sanchez is offline Find More Posts by gianni sanchez
Old Aug 29, 2012, 03:56 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Here's a link for the JetFan 90 using the Het 1445Kv, 3rd row down on far right.
http://www.rcgroups.com/forums/showp...&postcount=578
should give you a better idea of what you will get.
I too have a Jetfan 90, going to go in this. http://www.rcgroups.com/forums/showthread.php?t=1635049 A long way to go yet. I am looking into a Neu motor, 1524/ 2D or if I want to balls to the wall this one.1527/1Y. These motors are under rated and could get up to 1000Kw more than listed.
http://www.castlecreations.com/produ...rs/nm1500.html
Won't need a motor till next year, but want to get a better idea on what I want.
I wish you the best, on your project.
Mark
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 29, 2012, 05:37 PM
Joined Jan 2012
i have to say i'm impressed by the work done on your f 86!!
thanks for the link and data , witch i already got the jetfan ones ,
i think i'll gonna double ask and check for this 12s set up
i just don't wanna burn a 250euros CC hv 160 and 150euros het motor!!
tankks again
Old Sep 11, 2012, 02:10 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
waiting for the maiden.
pavcon is offline Find More Posts by pavcon
Old Sep 11, 2012, 06:00 PM
Joined Jan 2012
me too! haha!
i 've almost finish all the mods ,and will post latest update tomorrow
i plan to maiden at the end of the month , i'm going on holliday on sunday so..., won't be possible before
Old Sep 12, 2012, 01:18 AM
pavcon is offline
Joined Jan 2010
Arrrgh.. So the maiden of my stumax powered hk viper 90 will be before urs...
Old Sep 13, 2012, 07:46 PM
Joined Jan 2012
some update here!
here's the last thing i did on my mirage
second layer of epoxy and glass,modify (lenghtened)and instal tail , build inlet cones and fiberglass them ,...
as u will see on the last picture ,the weight is about 2kg3 with servo's esc and motor/fan
so that's not bad at all !should be around 3.7kg with batteries
perfect for a 6kg thrust set up !!
Old Sep 13, 2012, 10:17 PM
pavcon is offline
Joined Jan 2010
I wish I had your building skills. well done man
Old Sep 17, 2012, 06:30 PM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
that looks great
evo101 is online now Find More Posts by evo101
Old Sep 29, 2012, 04:48 PM
Joined Jan 2012
got back to work on this one and almost done everything to get it ready for maiden
let's hope i'll have time to do the first flight tomorrow !!
i already "bench tested" it and i reach almost 7000watts! with a draw of 168A burst ...57000rpm for the fan for the static test , witch i suppose it'll be a lil' higher when airborne
can't wait to see it in the air !
Old Sep 30, 2012, 03:40 PM
Joined Jan 2012
i've maiden it today !!! was a succesfull flight and ...wow holly crap!!!!!!!
this is as fast as a bullet!!much more than the "already fast" 1200kv het motor 12s!!
hope to find the time to do a video and try to find a guy nervous enough to follow this dart!
and will post some pictures of the first flight
Old Sep 30, 2012, 04:13 PM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
i love this mirage, i just hate all the mods needed to get her moving nicely, i would love to see a nicely priced fiberglass mirage 90mm...lets see some vid!!
kremecheze is offline Find More Posts by kremecheze
Old Sep 30, 2012, 04:15 PM
daggad is offline
Find More Posts by daggad
Aalesund, Norway
Joined Jun 2012
Love your workshop !!
Looking forward to film and pics as well...
daggad is offline Find More Posts by daggad
Old Oct 01, 2012, 05:01 PM
Joined Jan 2012
u know it take effort to transform an original 600w shell into a strenghfull 7000w jet!!
that's the price to pay
thanks for compliments!!
i'm heading into a fulltime work for customers now and the weather here begin to be crapy , but as soon as i have a hole in the day , i'll go to test it again , i guess it 'll takes a while....
by the way at the first flight the mirage didn't have to be trimmed or just few correction needed and that's it !! that mean everything positioned perfectly , canards included!!
Old Oct 01, 2012, 11:55 PM
Joined Dec 2008
Not sure what you used here, was it the JetFan with the 700-83-1445 on 12s?
Question who makes this mirage 2000? out of stock Electric Ducted Fan Jet Talk 3 Jul 27, 2012 07:01 AM
Found if someone has a crashed fly fly mirage 2000 I need a vertical fin sherlockshah Aircraft - Electric - Jets (FS/W) 1 Jul 12, 2012 08:11 PM
Discussion Riccs Mirage 2000 Ace_Brat Electric Ducted Fan Jet Talk 6 Jun 21, 2012 12:05 AM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
