Old Aug 18, 2012, 07:24 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
mirage 2000 jepe with huuuge power !
hi there ! just wanna share some stuff i did on my second mirage 2000 flyfly / jepe modified with the big het motor ever for a 90mm set up the 700-83-1445kv
this kong size motor is on 12 cells on a het fan (soon with the new vasa fan14 blades and reinforced 90 mm )
will produce almost 7000 watts, witch is already at 3400watt on 10s (on a 100mm-120mm fan)
esc is a non-burnt -yet ice castle 160hv v2
here's some pics of mods and esc location
by the way i'm trying to make a mirage 3 last generation or a kind of"cheetah" ....
flyfly model just don't produce single seat mirage ...
i have to make the deal with the "biplace" one
so if anyone's already did some mods to make this mirage into single seat ,every pics are welcome !!!
let's go for the first pics...
gianni sanchez is offline Find More Posts by gianni sanchez
Old Aug 21, 2012, 07:47 PM
Joined Jan 2012
her's some more details of my build
does anyone already used this motor on 12s ??
i expect a lot of power and big top speed from it
but i would appreciate some feedback
so here's the mods i made to get the cheetah -mirage 3 look as close as possible
made some new leading edge ,pod nacells, reduce air intake to get the right fsa , thin trailing edge, lenght rudder and change angle of it, thin nose, and more to come
it's already coated with fibeglass and epoxy (2 coats)
Old Aug 22, 2012, 05:51 PM
Joined Jan 2012
does anyone has interest in this plane with this bunch of power?
does even someone used that set up on a light jet?
is there somebody here?????
i will attempt to finish this model soon and will post some more pics and videos of maiden flight as soon as i get this airborne....if at least one people has interest...!
Old Aug 22, 2012, 06:46 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
I have not finished my cockpit, yet, but you can see what I am doing to make it a single seat. I used Deprom foam to fill in rear window panels and now I just need to fill in some lines with Spackle. I have not touched it in a couple of months, I guess I should at least finish this part to see how it looks.
http://www.rcgroups.com/forums/showthread.php?t=1561219
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Aug 22, 2012, 07:32 PM
Joined Jan 2012
looks great!
although u would like to find a way to make the top of the mirage (from cockpit to tail)witch is mor flat than the dual seats
by the way ,your pilot tuck well in the cockpit witch is this one?
thanks for the pics it'll helps me anyway
Old Aug 22, 2012, 08:11 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
WOW a Mirage with a vasa 14 90mm on 12 cells that will be fast and it should hand lauch right out of your hands! Nice work!
BadLemon is offline Find More Posts by BadLemon
Old Aug 22, 2012, 08:50 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Want to race my parkzone? loser get's the other's plane.
capt soap is offline Find More Posts by capt soap
Old Aug 23, 2012, 10:47 AM
CRCJA is offline
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Pilot
It is a Hawker Hunter Pilot from Hobby King for 90MM fly-fly Hunter. I think I trimmed a little of the bottom, I don't remember now.
http://www.hobbyking.com/hobbyking/s...dProduct=15224
Ralph
Old Aug 23, 2012, 07:01 PM
Joined Jan 2012
thanks for the link, i've order it
my plan is to try to get the look of a cheetah (upgraded Mirage III-D2Z for south africa)
of if i can mod well into a single seat this would go to a kfir/f 21 mods
all the helps are welcome!
by the way i already have a mirage jepe fiberglassed with vasa 90mm with 700-68-1200kv on 12 cells and it's already a reallly faaaaaaast jet!!
can't wait to see how this one will fly!!
Old Aug 27, 2012, 05:32 PM
Joined Jan 2012
hey! some update here!
i got lil' time to get further on my mirage
build some canard ,fiber them with coat of PUand paint first coat of primer...
i also changed mind for the final shape , and ,because it' ll be very hard to build a truely scale kfir or even a cheetah , i decided to come onto mirage 5 witch shapes are closer from mirage 2000
by the way i did some research on the net and finally found that mirage 5 got some canard in the past too!! in some country , and the best is there were "canard "mirage 5 in belgium !witch is my country too
even better; there were also dual seal mirage 5
kfir don't have dual seat and cheetah is pretty ugly on dual seat because of the lengthed nose!so that get me some work off to do !!!
so here's the pics , that would talk better than words...
Old Aug 29, 2012, 12:41 AM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
great thread, thats going to be a powerful setup
evo101 is online now Find More Posts by evo101
Old Aug 29, 2012, 02:58 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
will produce more than 4000watt, witch is already at 3400watt on 10s (on a 100mm-120mm fan)
Here's the Het 700-83-1445 on 10s in a 16lb F-86.
http://www.rcgroups.com/forums/showp...&postcount=628
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 29, 2012, 04:49 AM
Joined Jan 2012
wow ! very cool sabre indeed!
16lbs!!!! the mirage won't be more than 7lbs fully loaded i think!
let's hope the fiberglass will do the job ...
Old Aug 29, 2012, 08:07 AM
Joined Dec 2008
To your question:
"here's some more details of my build
but i would appreciate some feedback "
NO! It's only rated from 7-10s. At 12s you will most likely fry it.
http://shop.rc-electric-jets.com/HET...00-83-1445.htm
I had crunched a few numbers last week trying to find the loaded Kv of a few of the Het motors, this was one of them. On average they are about 85% of unloadedKv. So figure around 1228Kv X pack V. On 10s@3.85V per cell, gives you over 47.7K rpm. Now he was using the Jetfan 90 in the F-86, but if you noticed his numbers, ( 121 amps max, 4.4kw max.) you won't get much more for Kw. Don't get me wrong, 4.4Kw is nothing to sneeze at, but for more top end, you might have to squeeze down exhaust dia. a little at a time. Once you get past the sweet spot, amps will GO up. Will be watching progress.
Here's another with the Het 700-83-1445Kv on 10s. System specs in first part of video.
http://www.rcgroups.com/forums/showp...&postcount=766
Old Aug 29, 2012, 12:32 PM
tomme21 is offline
Find More Posts by tomme21
tom
tomme21's Avatar
USA, LA, Natchitoches
Joined Apr 2004
watching this closely
tomme21 is offline Find More Posts by tomme21
Question who makes this mirage 2000? out of stock Electric Ducted Fan Jet Talk 3 Jul 27, 2012 08:01 AM
Found if someone has a crashed fly fly mirage 2000 I need a vertical fin sherlockshah Aircraft - Electric - Jets (FS/W) 1 Jul 12, 2012 09:11 PM
Discussion Riccs Mirage 2000 Ace_Brat Electric Ducted Fan Jet Talk 6 Jun 21, 2012 01:05 AM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 11:10 AM
