Espritmodel.com Heli Air
Old Sep 08, 2012, 09:42 AM
Why do I bother with this crap
Tallahassee, FL
Joined Feb 2009
Originally Posted by prodriverex View Post
Here's my humble built using scratch Al rod..
Too heavy to fly nevertheless..
rated 600gm thrust motor each and 4S 3450mAh pack..
Back to drawing board now with version 2 using CF.. yah no longer using scratch CF.. brand new..
Slow flyer props would probably help too- something like a 10x4.7, depending on the KV of your motors. The props you have on there look to be pretty steep on the pitch.
Nobody said it, but it's a cool looking rig
2400RDR is offline Find More Posts by 2400RDR
Old Sep 08, 2012, 10:49 AM
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
looks killer!
but those props look like they will kill your motors.. get some slowfyer props with a max pitch of 5 and she will be flying soon!
dutchcommando is offline Find More Posts by dutchcommando
Old Sep 08, 2012, 11:09 AM
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Thanks dude! Yea you are right, i was amateur 6 mths ago with the spares. Got those aggressive pitch without knowledge..
Motors are 960Kv.
prodriverex is offline Find More Posts by prodriverex
The Engineer
Singapore
Joined Dec 2009
Originally Posted by dutchcommando View Post
looks killer!
Really? Ok will do it this week if time permits..!
Old Sep 08, 2012, 01:32 PM
Videonet's Avatar
Argentina, CF
Joined Oct 2011
Originally Posted by Nick_P View Post
Here are a couple of mine.
Very funny the last picture, very portable for to see the news walking
Videonet is offline Find More Posts by Videonet
Old Sep 08, 2012, 06:24 PM
Joined Nov 2008
Here my latest build. It's 330 size with some led's at the front as anywhere past 50m currently is a 50/50 gamble on whether I'll stay airborne or not. Alu arms with black heat shrink around them to make the whole thing look uniform / to intergate the led's nicely. Shame I've got 5 days of 12 hour shifts ahead as I'm dying to take it out for a spin
giek2000 is offline Find More Posts by giek2000
Old Sep 09, 2012, 01:21 AM
The Engineer
Singapore
Joined Dec 2009
Idea came with these spare rods lying around..
Started with using foam board and cross-joint..
Ok, this is weird..
The lander:
I got this idea after seeing those commercial quad with that curvy legs like spider design.. But i can't find a suitable spring to dampen the movement..
So after much pondering, these shocks came to mind:
The black foam board was ditched to make way for dual layers of Al plate for a very stiff structure. The third piece on top holds the electronics and it is dampen using special vibration dampening mount bought from farnell.
The custom built battery holder will go under the belly..
Bot some black foam tape to cushion the pack for whatever reason I do not have as to why i need to cushion them.. haha
Oh oh.. the the battery tray is too wide.. didnt measure this portion.. just eyeball guessing
Alright, we flip it this way..
That's better
Old Sep 09, 2012, 01:25 AM
The Engineer
Singapore
Joined Dec 2009
This is the motor I used. Trying to get a cheap and good one.. this cost around $17. So is the board.. Still kind of ex overall..
After some static run and one outdoor run.. the shaft is screwed. Have to change 3 of them. Lousy. Or probably like what dutchcommando said, the prop probably harmed my motor..
Old Sep 09, 2012, 03:47 PM
triple_b's Avatar
Duarte, CA
Joined Jun 2008
Hexacopter
Details on my scratchbuilt hexacopter that I completed about a month ago.
Frame: 0.063" Garolite-G10/FR4 cut on Phlatprinter3
Booms: 16mm OD aluminum
Boom Blocks: quadframe.us 16mm boom blocks
Flight Control: ArduPilotMega 2.0 Board & Case
Software: Arducopter 2.7.1
External GPS: uBlox LEA-6
Sonar: MB1200 XL-MaxSonar-EZ0 Ultrasonic Range Finder
APM Telemetry: 3DR Radio Telemetry Kit - 433 MHz
Motors: 6x Tiger MT-2216 900kV
ESC: 6x eRC "Rapid Drive" 25A Brushless ESC
Battery: 3s-5000mAh
TX: Flysky 9x w/ ER9X firmware with Frsky DJT Module & FLD-02
RX: Frsky D4R-II RX using CPPM
Weight with battery, no camera = approx 1.7 kg
RAM Hexacopter Mark 1 Flight Video (2 min 32 sec)
Hexacopter Test Flights (Using Arducopter 2.7.1) (8 min 11 sec)
triple_b is offline Find More Posts by triple_b
Old Sep 10, 2012, 10:38 AM
United States, OH, Columbus
Joined Jan 2011
Could probably easily lift that weight with 4 motors at that weight? Nice frame.
Battery: 3s-5000mAh
[/QUOTE]
FlyingRodent is offline Find More Posts by FlyingRodent
Old Sep 10, 2012, 10:39 PM
triple_b's Avatar
Duarte, CA
Joined Jun 2008
Thanks. Six motors might be a little overkill but I wanted to have some headroom for FPV gear or a gimbal. That and I just wanted to build a hexa so this is what I came up with. Buying six motors and esc's was kind of painful though. My next build will probably be a quad.
Old Sep 12, 2012, 07:27 PM
Canada, ON, Kincardine
Joined Feb 2009
Wooden tricopter
Foam quadcopter
Helno is offline Find More Posts by Helno
Old Sep 12, 2012, 08:46 PM
Joined Feb 2012
foam? how does it fly?
like the concept
Old Sep 12, 2012, 09:26 PM
anchorage alaska
Joined Sep 2006
rock solid frame, the most stable quad iv flown
600mm motor to motor
40-08 motors
20A esc 12 X4.5 props
multiwii FC
salxman12 is offline Find More Posts by salxman12
Old Sep 12, 2012, 09:27 PM
Joined Feb 2009
It fly's quite well. Less stable than my Tri but easy enough to control.
Once I have more time on it I think I will install some aggressive firmware to see if it will flip.
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2064 May 20, 2013 07:08 PM
Discussion Show us your workshop bazman The Builders Workshop 40 Jan 03, 2013 08:55 AM
Discussion Show us your favorite hi-res FPV video compuatic Video Piloting (FPV/RPV) 6 Oct 12, 2012 05:47 AM
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 37 Oct 02, 2012 04:11 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 54 Apr 18, 2011 09:31 AM
