Hi All,
here is mine xquad... It's made of an aircraft hexacopter frame whit wood arms. Before: A képet az RcPilot.hu tárolja.On the way ![]() A képet az RcPilot.hu tárolja.Finished: A képet az RcPilot.hu tárolja. A képet az RcPilot.hu tárolja. A képet az RcPilot.hu tárolja.I use KKboard, with Xcopter 4.7 firmware. Saxon |
Joined Apr 2012
Been perusing this thread to check out ideas for a new design... thought I'd post mine from a while ago... as simple as it gets but it worked great. cheap and simple to rebuild- perfect for learning and lots of crashing
uk
Joined Feb 2009
Good engineering practice in such instances is to use two different materials for the nut and bolt. However, its unlikely you will easily get pure aluminium nuts and bolts, the more commonly available and normally used alloy nuts and bolts should be ok. You will also get oxidisation with aluminium which can also ultimately lock them up well. You can use a spring washer to stop nuts coming undone or if careful a splash of retainer (not thread loc). |
Joined Sep 2011
This little quad is one of a kind. It's constructed from parts from a Bluesky RC micro-hex. I decided to use only four motors, so I repositioned two of the arms as shown.
The controller, motors and ESCs came from a Turnigy mini-quad V2. It flew great for a while, but after a few bumps and bangs into various walls, the frame more or less crumbled into bits. I repaired it with carbon splints, but eventually it had to be put out of its misery. The controller is a KK2.0 running firmware 1.4. This is a darn good controller but the big surprise is how much more stable this quad is than its predecessor, the mini-Turnigy. Perhaps it's the much greater stiffness, or perhaps the configuration happens to hit some sort of sweet spot. In any event, the flight characteristics are excellent; on takeoff, it just rises straight up and hangs wherever you park it. Perfect for flying around inside the house, and its small size means that you can fly through doorways without coming too close. |
| Thread Tools | |
| Discussion Show Us Your Hoverthings FPV Frame | scrape | Multirotor Talk | 2063 | Today 12:26 AM |
| Discussion Show us your workshop | bazman | The Builders Workshop | 40 | Jan 03, 2013 08:55 AM |
| Discussion Show us your favorite hi-res FPV video | compuatic | Video Piloting (FPV/RPV) | 6 | Oct 12, 2012 05:47 AM |
| Discussion Show us your RC orders! Lets see how much we spend :O | Koo | Electric Plane Talk | 37 | Oct 02, 2012 04:11 AM |
| Discussion Show Us your US Navy Ship ! | Chophop | Life, The Universe, and Politics | 54 | Apr 18, 2011 09:31 AM |
