Tallahassee, FL
Joined Feb 2009
http://www.rctimer.com/index.php?gOo...1&productname= Here's the shaft: http://www.rctimer.com/index.php?gOo...8&productname= And while you're at it, you may as well get some of these: http://www.rctimer.com/index.php?gOo...1&productname= If you're feeling intrepid, you can just buy some 4mm drill rod and roll your own. Here's an article on doing that: http://www.rcgroups.com/forums/showthread.php?t=1240725 The only caveat is that you'll have to grind the little flat on the shaft for the grub screw in the motor bell, but if you're up to the rest of this, that shouldn't be much of a stretch. Lastly, for more than you ever wanted to know about DT750 motors, here's a cool, long thread: http://www.rcgroups.com/forums/showthread.php?t=777998 Mostly about rewinding, but there's lots of other interesting stuff in there, including info on where to get bearings should you need to replace them. Brushless motors are really interesting- they can be kept running forever by replacing certain key parts. Unless you kill one badly by crashing hard on it. But we don't do that, do we? ![]() Rick PS- Good props at RCTimer also. NFI- I just like them. |
I bought these bearings when I bought all my other stuff: http://www.hobbyking.com/hobbyking/s...dProduct=11521
They worked perfectly for my new DT750. Thanks for those links 2400RDR, i have been looking for some place that competes with HK on prices, and the free shipping is a bonus too But I looked and didn't see any props in the 11x4.7 size. Which props are you using on your DT750's??
Tallahassee, FL
Joined Feb 2009
http://www.rcgroups.com/forums/showthread.php?t=1719446 A friend of mine bought some from him and said the service was great. Cheap shipping too. Rick |
Tallahassee, FL
Joined Feb 2009
One other benefit I forgot to mention about those prop adapters is that the mounting shaft for the prop is 6 mm, which makes it a perfect fit for the GemFan props that most of us use. No need to futz around with those little plastic adapter rings.
Rick |
The DT700 and DT750 are great motors but there are some great alternatives without the hassle. personally I have had great success with the RCTimer 2836 series motor without having to change the shaft or balancing them.. But lets not get into a flaming battle over which is better, what ever works best for the given scatchbuild.
United States, MA, Swansea
Joined Oct 2009
Back on topic, here is a quad I am building for acrobatic flight. I made the frame out of Lexan which is really really tough stuff, and aluminum framing I found at work that was part of a sliding cabinet door of some sort. It has a nice channel on the bottom that the doors would slide in. I really like it because it strengthens the arms. I milled the ends down in a Bridgeport so I could mount it within the lexan, and also for the motors. Just the frame with no electronics weighs 346g. Not too bad, it's pretty light to me, hope it works good!
I just need to order motors, which just went out of stock ![]() ![]()
Here are my MWC White Quad
and my Bloggie-Copter Y6
CU Eddy |
Joined Aug 2012
Joined Aug 2012
Hi, was told I should post here.
My intro thread is here: http://www.rcgroups.com/forums/showthread.php?t=1722381 video:
pics: ![]() ![]() ![]() ![]() ![]() ![]()
| Thread Tools | |
| Discussion Show Us Your Hoverthings FPV Frame | scrape | Multirotor Talk | 2064 | May 20, 2013 07:08 PM |
| Discussion Show us your workshop | bazman | The Builders Workshop | 40 | Jan 03, 2013 08:55 AM |
| Discussion Show us your favorite hi-res FPV video | compuatic | Video Piloting (FPV/RPV) | 6 | Oct 12, 2012 05:47 AM |
| Discussion Show us your RC orders! Lets see how much we spend :O | Koo | Electric Plane Talk | 37 | Oct 02, 2012 04:11 AM |
| Discussion Show Us your US Navy Ship ! | Chophop | Life, The Universe, and Politics | 54 | Apr 18, 2011 09:31 AM |
