Old Dec 06, 2012, 04:39 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
The stilts didn't effect my flying at all, but they did break on the first hard landing. All four broke in the same spot. The updated landing gear is the pool noodle. I dont expect to have any problems with them.
AcroFPV is online now Find More Posts by AcroFPV
Old Dec 06, 2012, 06:49 PM
installerblizz is offline
Find More Posts by installerblizz
This is a hobby. READ UP!!!!!!
installerblizz's Avatar
United States, FL, Bradenton
Joined Jun 2012
This is my second build. It's a big step up from the 10g motors and 5" props my first one used. Vertical ascent is crazy fast on this thing. I haven't tuned the KK2 for it yet, but it's already super stable. My goal was to build the cheapest quad possible using 10" props and 3s LiPo. (with the KK2.0 I already had)
Thrust to weight ratio: 3.3 to 1
Flight time is still unknown. I flew it hard for 8 minutes and didn't hit 3.3v. Maiden was this morning.
EMax GF2215/25 motors
Hobbywing Skywalker 20A ESCs
Gemfan 10x4.5
DIY birch frame (with screws with rubber caps for legs LOL)
KK 2.0
HobbyKing 6ch TX/RX
GForce 4000mah 3s batteries
I am more than pleased with the results.
installerblizz is offline Find More Posts by installerblizz
Old Dec 07, 2012, 07:50 AM
Sonicg is offline
Find More Posts by Sonicg
Hong Kong
Joined Sep 2011
This is my very first rc build. Its the rcexplorer tricopter with the modified plans from Colorex, to fit 12mm arms.
Specs:
12mmx 12mm wooden arms, 1.5 glass fiber body
KK 3 board, DT750 motors and APC slowfly 10x4.7
HK A30 esc's with Simon K firmware
MTM about 500mm and auw 915 gram
Devo 8s tx, AX801 rx
Planning to maiden it tomorrow, depending on the weather.
A strange thing I already noticed is that the servo is twitching, even when the board is not armed, is that normal?
Sonicg is offline Find More Posts by Sonicg
Old Dec 08, 2012, 06:34 AM
Sonicg is offline
Hong Kong
Joined Sep 2011
The maiden flight was not very succesful. When I try to lift off, the tricopter spins counter clockwise. I tested the gyro's and they are correct. I also tested the rudder input and that's also correct. When I adjust the yaw and roll pot on the board nothing changes. Anybody any idea what can be wrong?
Old Dec 08, 2012, 08:15 AM
jimbob69 is offline
Find More Posts by jimbob69
jimbob69's Avatar
United Kingdom
Joined Jul 2012
U need to reverse the yaw input on the board, don't know how to do this on that board but that's what u need to find out,
On the kk2 it's from 100 to -100 or something like that.
Nice tricopter!!! Hope you get it in the air soon
jimbob69 is offline Find More Posts by jimbob69
Old Dec 08, 2012, 05:24 PM
blackmoon is online now
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
My ghetto AcroQuad 450gr with batteries
Naze32 FC
Hobbyking 10A
Turnigy L2205-1350 Brushless Motor (100w)
blackmoon is online now Find More Posts by blackmoon
Old Dec 08, 2012, 05:46 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
mini QuadH
For some indoors FPV
160mm motor to motor / 240mm diagonal
67g pine wood frame
FC: openpilot CC3D
Motors: Turnigy C2020 3500KV (on the way)
Props: 5x3 GemFan
ESCs: Himodel 10A
LiPo: 3S Nanotech 950 mAh
Receiver: Spektrum AR500
AUW: 270g
+FPV
Camera: Keychain, VTx: 5.8gHz powered by a 120mAh 1S LiPo
eyesonsky is offline Find More Posts by eyesonsky
Old Dec 08, 2012, 06:00 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
67g pine wood frame
FC: openpilot CC3D
Props: 5x3 GemFan
ESCs: Himodel 10A
AUW: 270g
+FPV
wouldn't 5" prop a bit too big for 3s+3500kv?
jy0933 is offline Find More Posts by jy0933
Old Dec 08, 2012, 06:24 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Depends on the motor. Since this is a 60w motor 5x3 might be too much, a 4x2.5 might be a better fit. Would love to see a review once its flying.
brontide is offline Find More Posts by brontide
Old Dec 09, 2012, 08:03 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
I dont know. Its my fisrt mini quad DIY build.
Thanks for the advice.
I also have order 3000kv http://www.giantshark.co.uk/m160612-...-p-404951.html
maybe better for this setup?
I cant find where buy 4x2.5 CW and CCW props, any shop idear?
Old Dec 10, 2012, 03:53 AM
Bird of Pray is offline
Find More Posts by Bird of Pray
Joined Oct 2011
Self made Scorpion Y650 looks like the HK Scorpion
http://www.youtube.com/watch?feature...&v=9RPSqE3ZjZI
for more Pic ore information look at the Board:
http://fpv-community.de/showthread.p...0-Y3-Wood-Made
Bird of Pray is offline Find More Posts by Bird of Pray
Old Dec 10, 2012, 01:55 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
my suggestion will be something like 1800-2200kv for 3s/// or 2s for your motors
Old Dec 11, 2012, 12:21 AM
Sonicg is offline
Hong Kong
Joined Sep 2011
Do you mean the Yaw gyro? I checked the yaw response and it seems correct, it turns in the opposite direction of the movement; push tail to the right, motor moves to the left.
Old Dec 11, 2012, 09:33 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
67g pine wood frame
FC: openpilot CC3D
Props: 5x3 GemFan
ESCs: Himodel 10A
AUW: 270g
+FPV
The keychain cams have live video output now? hows the quality?
KillerCut is offline Find More Posts by KillerCut
Old Dec 11, 2012, 10:29 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
I use a keychain cam as my FPV camera and the quality is great.
here's some video from it:
FPV is hard (2 min 48 sec)
You have to get the V2 808 cam, and make sure its not some fake 808 knockoff. This is where I got mine:
http://www.ebay.com/itm/180937263580...=p5197.c0.m619
It will only do video out, not audio.
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 92 Jul 16, 2016 04:49 PM
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
