Old Nov 30, 2012, 11:25 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by acicuecalo View Post
Hi.
Distance between left and right motors (from axle to axle) = 405 mm.
Distance between front and rear motors (from axle to axle) = 420 mm.
Quad Copter weight is 1050 g.
Total weight of Quad Copter, 8400 mAh 3 cells Lipo, GoPro Camera, Video TX 5,8 Ghz and 1300 mAh 3 cells Lipo for video Tx is: 2080 g. Flight time is 18 minutes with this setup (complete FPV gear GoPro).
Attachment 5339786
Good looking build. Do yourself a favor and get rid of the metal hardware holding the motor mounts to your arms, and replace them with nylon nuts & bolts. You will save yourself the hassle of trying to find new mounts when you crash.
AcroFPV is online now Find More Posts by AcroFPV
Old Nov 30, 2012, 11:58 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
I would really like to go more than a few days without having to rebuild one of my quads, please?!
brontide is offline Find More Posts by brontide
Old Nov 30, 2012, 04:05 PM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
If you're going more than a few days between having to rebuild... You're not flying it hardcore enough!! Lol...
fallingdown is offline Find More Posts by fallingdown
Old Nov 30, 2012, 05:43 PM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
Hi.
Thanks, ive been looking at using smaller batteries than you so ill do some math with the bigger ones. Your getting some good flight time.
BrownOut is offline Find More Posts by BrownOut
Old Nov 30, 2012, 06:24 PM
brontide is offline
Joined Sep 2012
Tonight's scratchbuilding insanity brought to you by 30 gauge magnet wire. One phase down, 2 to go.
Old Nov 30, 2012, 06:27 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I wish I could do this, I really and truly do. Care to share where you purchased the wire and how you determined the KV? I have some 750kv motors and would like to rewire them to 1500kv.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 30, 2012, 06:40 PM
brontide is offline
Joined Sep 2012
Radio shack has a set of magnet wire for $9. I'm just rewinding to match the existing motors, but if I understand the theory right you would double the strands ( or use a thicker wire ) and half the turns.
I'm using the wiring scheme from this page since it appears to be what I took off.
http://www.bavaria-direct.co.za/mode...Calculator.htm
My first phase took about 45 minutes tested ok ( no stator short ).
Old Nov 30, 2012, 06:47 PM
Joined Aug 2009
Thank you, A thousand more Thank you!!!
Old Nov 30, 2012, 08:52 PM
brontide is offline
Joined Sep 2012
Double check, I now think I might have had thr backwards.
Old Nov 30, 2012, 08:59 PM
Joined Aug 2009
I did and you are correct.
Old Dec 01, 2012, 12:02 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
sooo, what is backwards :P
sirbow2 is offline Find More Posts by sirbow2
Old Dec 01, 2012, 05:30 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
lol
External Power ? only as good as the length and the weight of the wire.
require heavy lift multirotor for this to work.
flight duration depends where you plug into.
speedactyl is offline Find More Posts by speedactyl
Old Dec 01, 2012, 05:44 AM
brontide is offline
Joined Sep 2012
Might be great for maiden flights with noobs. That will prevent flyaways.
Old Dec 01, 2012, 05:45 AM
Joined Aug 2009
LOL,
Actually, this is nothing to laugh at but it is a great novelty! There are some great applications for this.
Old Dec 01, 2012, 09:22 AM
sirbow2 is offline
Emress
Joined Nov 2011
not to mention if this is to be the permanent power method, the motors can lift other things!
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
