Old Nov 24, 2012, 04:02 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Will do. Thanks again subaru. For now I'm justgoing to use the stick method. It works so I have no complaints. I just have to be on a verylevel surface when I activate it. I was looking around on the web and found a really nice frame and gimble for $60. So I ordered it. I may use the parts from my Aerosky H100. Also the H100 Tx has a proportional knob on ch5 so I can rotate the camera slowly.
Tom
http://www.valuehobby.com/multicopte...unt-combo.html
carr52 is offline Find More Posts by carr52
Old Nov 24, 2012, 06:26 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by carr52 View Post
Will do. Thanks again subaru. For now I'm justgoing to use the stick method. It works so I have no complaints. I just have to be on a verylevel surface when Iactivate it. I was looking around on the web and found a really nice frame and gimble for $60. So I ordered it. I may use the parts from my Aerosky H100. Also the H100 Tx has a proportional knob on ch5 so I can rotate the camera slowly.
Tom
I have a buddy who uses that same frame and gimbal, and they both work very well. I have seen his quad take some very long tumbles and survive quite well.
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 24, 2012, 06:30 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
I wonder where the YouTube video is for lactivating.
As a note, you only need to calibrate level, you can activate at any angle and it should work ( well that's the theory at least )
brontide is offline Find More Posts by brontide
Old Nov 24, 2012, 07:47 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
With my flying skills I need all the help I can get.
Tom
Old Nov 24, 2012, 07:49 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
"Iactivating" yep I had to change that. LOL.
Tom
Old Nov 24, 2012, 10:57 PM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Follow up flight video for my folding quad for 10" props...
Folding Frame - 10" prop first flight and jello test (2 min 39 sec)
Still getting some jello. Still tweaking. Its flying nice enough though.
phil
Edit: Excuse the shorts. I was just about to go running and had to get the test flight in first of course.
PS: Forgot to mention the onboard GoPro has a Sunnex 60 FOV lens (non Fisheye)
Captain3D is offline Find More Posts by Captain3D
Old Nov 25, 2012, 12:20 AM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
Originally Posted by acicuecalo View Post
Hi I'm new on this group and I like to build multirotors and robots. I'm from Spain and this is mi scrach built H-Quad:
ESC TURNIGY Plush 25amp Speed Controller
FCB Hobbyking KK2.0 Multi-rotor LCD.
RC RX FrSky D4R-II CPPM mode.
Slow Fly Electric Prop 11x4.7 de hobbyking.
HexTronik DT750 Brushless Outrunner 750kv.
GoPro Hero HD.
Video TX ImmersionRC 5,8 Ghz.
Skew Planar Wheel Antennas from Circular Wireless
LCD FatShark.
[IMG]http://carabaza.es/wp-content/uploads/2012/11/2012-11-16-21.47.56-1024x768.jpg[/IMG
Flight: 18 minutes whith LiPo Turnigy NanoTech 3 cells 8400 mAh and 1300 mAh for video TX and GoPro:
[URL="http://www.youtube.com/watch?v=3xsmJywUEMQ"]http://www.youtube.com/watch?v=3xsmJywUEMQ[/URL
Nice, what is the distance between motors and what sort of weight is it. It has simular equipment specs to my build.
BrownOut is offline Find More Posts by BrownOut
Old Nov 29, 2012, 06:20 PM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
My frame isn't totally scratch built so I hope people don't mind me joining the thread. I've used the flyduino centre plates that warthox designed along with some carbon fibre arms I made myself. I've used wooden dowl inserts to reinforce the centre of the hollow carbon fibre where i have the bolts running through to mount the motors. The carbon fibre arms are about 1/3rd lighter than the aluminium they replace and 2cm longer with a motor to motor distance of 45cm.
It weighs 624 grams total with the 3cell 2200mah lipo and 430 grams without.
The flight controller is a scratchbuilt arduino nano multiwii based board. The arduino nano is handy because it means it has built in USB.
teslahed is offline Find More Posts by teslahed
Old Nov 29, 2012, 06:27 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
Originally Posted by teslahed View Post
My frame isn't totally scratch built so I hope people don't mind me joining the thread. I've used the flyduino centre plates that warthox designed along with some carbon fibre arms I made myself. I've used wooden down inserts to reinforce the centre of the hollow carbon fibre where i have the bolts running through to mount the motors. The carbon fibre arms are about 1/3rd lighter than the aluminium they replace and 2cm longer with a motor to motor distance of 45cm.
Nice! id consider anything that has all the components bought individually and then assembled to be scratch built. frame,motors, escs etc
sirbow2 is offline Find More Posts by sirbow2
Old Nov 29, 2012, 06:35 PM
teslahed is offline
Joined Jul 2008
I think i'm good then, thanks
I am looking at designing and building my own centre plates. I know a guy locally who just built himself a laser cutting machine. It may be a little while before i manage to get that working though - need to learn CAD first
Frame - warthox centre plates, own design arms.
Motors - Turnigy SK3 2822s (nice and light at 31grams, 1275kv 8 amps max)
ESCs - 20 amp rctimer flashed with SimonK (will upgrade to something lighter in the future these are just what i had spare)
Props - RCtimer full carbon 8"
Radio equipment - just the standard turnigy 9x stuff with the radio running er9x firmware.
Home made arduino nano based multwii flight controller with MPU6050 gyros and accelerometers.
I was aiming for a good power to weight ratio for stunt flying rather than the most possible power - I'm starting to think they fly nicer that way, although it could be personal preference.
Old Nov 29, 2012, 06:41 PM
brontide is offline
Joined Sep 2012
Scroll saw and some printouts as templates have gotten me from rectangular plates to more custom looks. Heck, many of my designs are just from folding paper and then using a ruler and some random curved surfaces.
High thrust to weight also usually means much more throttle headroom for the FC to play with for control. My current favorite bird is based on turnigy 3020 1300kv, 8x4x3 ( soon to be 9x4.7 ) with an AUW of less than 700 even with a 4Ah battery. Quite zippy and can fly on 2s as well.
Old Nov 29, 2012, 07:33 PM
teslahed is offline
Joined Jul 2008
I bet that does accelerate well. Do you have any video?
Here's mine, although i've not quite finished PID tuning it yet;
New Carbon Fibre 'Warthox' Flyduino quadcopter frame (7 min 48 sec)
Old Nov 30, 2012, 12:18 AM
jimbob69 is offline
Find More Posts by jimbob69
jimbob69's Avatar
United Kingdom
Joined Jul 2012
Nice flying teslahed!! Love those lazy loops haha, I still haven't built a super light sport frame yet, it's on the list though.
jimbob69 is offline Find More Posts by jimbob69
Old Nov 30, 2012, 10:07 AM
acicuecalo is offline
Find More Posts by acicuecalo
acicuecalo's Avatar
Spain
Joined Sep 2007
Hi.
Distance between left and right motors (from axle to axle) = 405 mm.
Distance between front and rear motors (from axle to axle) = 420 mm.
Quad Copter weight is 1050 g.
Total weight of Quad Copter, 8400 mAh 3 cells Lipo, GoPro Camera, Video TX 5,8 Ghz and 1300 mAh 3 cells Lipo for video Tx is: 2080 g. Flight time is 18 minutes with this setup (complete FPV gear GoPro).
Name: 2012-11-30 16.59.58.jpg
Description: Total weight H-Quad with FPV gear.
acicuecalo is offline Find More Posts by acicuecalo
Old Nov 30, 2012, 10:13 AM
brontide is offline
Joined Sep 2012
My current favorite bird is based on turnigy 3020 1200kv
Crap, the Turnigy 3020 1200kv motors are just eating themselves. Looks like I need to pick a new type or learn to rewind. I'll probably try and rewinding since I like the size and weight and I was hoping to put in a new shaft anyways since 5.5mm mount sucks.
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 92 Jul 16, 2016 04:49 PM
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
