United States, NY, Albany
Joined Sep 2012
Yes, that was a real pain, I'm going to try and find some therabands so I can attach it better than the crappy orings. There was no properly sized adapter so I had to bore out the 5mm adapter. 8x4x3 was chosen based on ecalc showing that combo to be more efficient. Battery is 3s 4ah, but I think I can get almost 20 minutes on a much smaller pack.
Couldn't find anything that said motor minimum. Where would that be? By the way I'm using a DX6i if that makes a difference. By rechecking the esc calibration do you mean redo the steps the 4th video show for holding down the 1st and 4th button on the FC while I plug in the battery? Did that.
Tom Update: Found a setting on the FC called minimum throttle. I raised it to 20 and things seem ok now. I found that under misc settings. I know more when I can get it outside tomorrow. Was also wondering should I set the rates and expo low rates and high expo. Thanks for the help. Tom |
I really dont know how to do any of that. Even the self level thing. I saw on the FC that it is off. Do I have to put another wire on ch5 or something? I'm guessing by now you've figured out I'm new at this. I don't have the cable or what ever you need to connect to the computer.
Tom |
the kk2 board should have come with v1.2 firmware, and it kind of sucks. 1.4 & 1.5 have GREATLY improved the auto-level feature. Its truly a night & day difference. |
Taking another shot at a folding quad. This one is to accommodate 10" props and a Medium gopro FOV.This makes the main body longer which allows the legs to fold inwards but also makes it more difficult to get that body ridgid enough.
It not quite working on the stiffness side of things. I know if I glue the wood layers it will be super stiff but that defeats the replaceability aspect of components. Maybe I glue one side to the inner core and leave the other side bolt on. Maybe screw in to save weight. phil |
Joined Mar 2009
My folding X8 Octo has 1 5/8" (42mm) spacing between top and bottom plates and is very rigid. The plates are 2mm ply with a thin glass / epoxy coating for durability. Motor to motor spacing is 800 mm. Malcolm |
Well heres what I've got so far. The frame is made from CF arrows I got at Wal Mart and the rest is light plywood and epoxy.
Tom
| Thread Tools | |
| Discussion Show Us Your Hoverthings FPV Frame | scrape | Multirotor Talk | 2064 | May 20, 2013 07:08 PM |
| Discussion Show us your workshop | bazman | The Builders Workshop | 40 | Jan 03, 2013 08:55 AM |
| Discussion Show us your favorite hi-res FPV video | compuatic | Video Piloting (FPV/RPV) | 6 | Oct 12, 2012 05:47 AM |
| Discussion Show us your RC orders! Lets see how much we spend :O | Koo | Electric Plane Talk | 37 | Oct 02, 2012 04:11 AM |
| Discussion Show Us your US Navy Ship ! | Chophop | Life, The Universe, and Politics | 54 | Apr 18, 2011 09:31 AM |
