Old Nov 19, 2012, 11:24 AM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
My scrachbuilt mini soapbox tricopter. The airframe cost $3 minus the landing gear
http://www.rcgroups.com/forums/showthread.php?t=1773322
Mini SoapBox Tricopter (5 min 37 sec)
rcbif is offline Find More Posts by rcbif
Old Nov 19, 2012, 11:35 AM
jamiedco is offline
Find More Posts by jamiedco
South Africa, GP, Alberton
Joined Sep 2012
nice build . i wana build a small quad for messing around with coz the same thing happens when i crash my big fpv quad . i might even build a tri for the fun flying
jamiedco is offline Find More Posts by jamiedco
Old Nov 19, 2012, 01:58 PM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Thanks Dave.
I ordered a few sheets of this magical G10 to see what it was all about. I was disappointed to find it was less stiff, more expensive and a little heavier than the five layer 5mm birch ply I can buy at Michaels craft store. It would be better for surface wear and pivot hole strength etc I think.
I should be getting some aircraft grade ply today which is expensive but has five layers in the 3mm version so I want to see how that compares.
I quite like being able to just hack away with the jigsaw. I keep changing the design anyway.
phil
Originally Posted by Birdman4498 View Post
Hi Phil, I had mine cut by Eric (DialFonZo). He posts in this thread and resides in Quebec. He has a CNC set-up that I believe he built himself. I sent him a photo of a mockup on how I thought it was going to look and then emailed him a scanned copy of a paper cut out I had done with the dimensions on it. I don't have a cad and probably wouldn't be able to use it anyway. I tried doing a wooden prototype but was not as accurate as yours in the cutting so after seeing some of Eric's work I decided to go straight to the G10. I am very happy with the results. I think once I ream the props and balance rather then drill, (which I noticed did put them off centre) the jello will be gone completely.
Dave
Captain3D is offline Find More Posts by Captain3D
Old Nov 19, 2012, 02:02 PM
Captain3D's Avatar
Joined Jan 2012
http://www.youtube.com/watch?v=4ELjk6ISfJI
Wow that is tiny. Love it.
phil
Old Nov 19, 2012, 06:12 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
More soapboxes :)
It's a busy picture, but here are my two just completed soapbox quads. A friend said the electronics were a "clean install". Pun intended I think. LOL
One has a CC3D, DT750 motors with 10x4.5 props. The other is a CC, DT700 motors and 11x4.7 props.
2400RDR is online now Find More Posts by 2400RDR
Old Nov 20, 2012, 01:46 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Very nice. What kV motors are they and what battery are you using please?
Doh - found most of the info
Steveis is offline Find More Posts by Steveis
Old Nov 20, 2012, 02:22 AM
jamiedco is offline
Joined Sep 2012
Silicon Vibration Dampener Testing (1 min 1 sec)
I am testing the new dampneres . The Quad feels alot more precice since adding them . but i think there is a little jello in the video . please comment with what you think .
bearing in mind that im flying with slightly damaged props .
one is not straight anymore and two have small bits missing on the ends
and none have been balanced .
for more check out www.jamiedco.com
Old Nov 20, 2012, 03:15 AM
dogz85 is offline
Find More Posts by dogz85
Australia, VIC, Shepparton
Joined Jun 2008
not sure if this counts, i used some of the boom leg holders from rusty to make a h-copter. super light and super fun
dogz85 is offline Find More Posts by dogz85
Old Nov 20, 2012, 02:38 PM
Captain3D's Avatar
Joined Jan 2012
I think I see a little but it is hard to tell as the video does not play at a good frame rate. Looks like 15fps or less to me.
phil
Originally Posted by jamiedco View Post
http://www.youtube.com/watch?v=ohWkZTPRydg&feature=plcp
Old Nov 20, 2012, 02:57 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Nice! Do you have any details on the yaw mechanism that you can share?
-K
kad is offline Find More Posts by kad
Old Nov 21, 2012, 01:39 AM
Steveis is offline
AVR Dude
Joined Jul 2011
-K
Check out post #41 in this thread: -
http://www.rcgroups.com/forums/showthread.php?t=1308047
Also search the web for rcexplorer
Old Nov 21, 2012, 02:43 PM
diakatche is offline
Find More Posts by diakatche
Joined Jul 2009
I"ve used silicone dampers before with little success. The definitely damp out the high-freq vibrations from the props but tend to increase low freq oscilations. In one case I had a resonance problem where the camera was visibly shaking, even though the rest of the rig appeared completely stable.
Silicone dampers depend greatly on the weight/load on them, size and thickness of the material, and attachment method.
With that said, I have had great success just using RC helicopter canopy mount grommets. Drill the holes a bit oversize, insert the grommet, use washers and bolt it lose and they seem to absorb all the high freq vibrations but keep everything attached solidly.
diakatche is offline Find More Posts by diakatche
Old Nov 21, 2012, 10:14 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Build or bust tonight.
brontide is offline Find More Posts by brontide
Old Nov 22, 2012, 01:35 AM
jimbob69 is offline
Find More Posts by jimbob69
jimbob69's Avatar
United Kingdom
Joined Jul 2012
Remade the little spider quad I did a few weeks back after beating it into the ground several times,
Tried it with a longer main body first as you can see from the pencil marks on the plate but although it flew pretty well it had tons of twist in it so pushed the arms tight together to help keep the frame more rigid, feels better in the hand so far,
Will mount the cc3d and the esc's tonight and maybe a tester at the weekend if this crazy storm ever moves away!!
Will be putting an earplug gopro plate on the front too.
340mm wide 310mm long, I never use auto level so the symmetry doesn't matter.
I really like the spidery layout for LOS flying, really helps orientation.
jimbob69 is offline Find More Posts by jimbob69
Old Nov 22, 2012, 06:58 AM
Great_Dane is offline
Find More Posts by Great_Dane
Woof!
Denmark, Region Zealand, Roskilde
Joined Oct 2012
@jimbob69: that's a sweet li'l thing
I see, that you didn't put screws/bolts through the booms. Are you simply using standoffs at each side of the booms? Maybe a picture from the side would help a bit
Thanks for sharing
Great_Dane is offline Find More Posts by Great_Dane
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
