Old Nov 18, 2012, 01:26 AM
Don McCullough is offline
Find More Posts by Don McCullough
SBSS, SVSS, SCCMAS, EBRC
Don McCullough's Avatar
United States, CA, San Jose
Joined Jan 2004
I just finished my build of Sean's Aerotestra quad. This was a very easy build. At first I was concerned about getting all of the FPV equipment. With some cable management it worked out great. The only parts sticking out into the wind are the antennae, sonar module, and FPV (later Contour HD) camera.
In order to carry the extra equipment I did some very minor mods to the suggested installation. This quad has more powerful motors to handle the added weight. Just to make sure, I added small holes in the case to provide extra cooling (see picture). Wiring was eased by lengthing three ESC wires with 6" servo extensions. This allowed me to bundle all the wiring on one side with a removable cable tie. Access to the battery was very easy. The MinumOSD was mounted to the back of the ArduPilot, further reducing wiring.
The configuration of the Aerotestra is well suited to FPV. The controller/gyro is mounted far away from equipment and there is no metal to affect the gyro or compass.
Great job Sean in this design. Top notch product.
Don
Don McCullough is offline Find More Posts by Don McCullough
Old Nov 18, 2012, 02:15 AM
jamiedco is offline
Find More Posts by jamiedco
South Africa, GP, Alberton
Joined Sep 2012
very nice build captain . what vibration bobbins are you using .
jamiedco is offline Find More Posts by jamiedco
Old Nov 18, 2012, 08:29 AM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Thanks Jamiedco. Especially after seeing your great build. I think you can see its influence on mine :-) I am using the QAV500 bobbins...
http://www.getfpv.com/featured/orange-rc-bobbins.html
But also just got some of these PC HD dampeners to try...
http://www.performance-pcs.com/catal...ducts_id=23379
They are a little stiffer but might work well.
cheers...phil
PS. You mentioned 9 x 6 props in your video. I know APC make an E prop in counter rotating pairs at 9 x 6.
http://www.apcprop.com/SearchResults.asp?Search=9x6+e
phil
Captain3D is offline Find More Posts by Captain3D
Old Nov 18, 2012, 08:44 AM
bakon is offline
Find More Posts by bakon
I Toast Planes
bakon's Avatar
Joined Jul 2010
My first scratch built hex designed by yours truly. Took about 3 weeks on and off of designing and building.
bakon is offline Find More Posts by bakon
Old Nov 18, 2012, 08:46 AM
jamiedco is offline
Joined Sep 2012
thanks captain . i will check it out now . i am making my own bobbins from silicon and cornstarch . i wana try them out tomorrow .
Old Nov 18, 2012, 09:57 AM
biggles uk is offline
Find More Posts by biggles uk
BNUC-s
biggles uk's Avatar
Joined Feb 2012
can someone help with my tuning, I'm on a kk2 board and so far I've got I gain right up to 320 and I am still not getting the low speed oscilation that I am expecting. Am i missing something?
biggles uk is offline Find More Posts by biggles uk
Old Nov 18, 2012, 10:46 AM
seanheadrick is offline
Find More Posts by seanheadrick
Joined Nov 2012
Don
Hey don,
That looks great. Great feedback. I appreciate you taking the time to document your build. I hope I can join you when you get to flying.
Looks like the production is beginning and delivery should begin by weeks end. I will post a full description under a "new product" heading in the next day or two.
seanheadrick is offline Find More Posts by seanheadrick
Old Nov 18, 2012, 11:31 AM
jamiedco is offline
Joined Sep 2012
biggles .
you need to drop it right down and then raise it 5 or 10 at a time till it osculates . i had the same thing with my tricopter
Old Nov 18, 2012, 01:36 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
What do you mean by ocilate and why would you want it to? Is that a end point for your settings or something? I just received all my parts and the KK2 from HK so I'm starting my quad build. Need all the help I can get. Thank you for your help.
Tom
Update: just came in from giving the tricopter a try. Its alive. I just played around with the gyros until was stable. It doesn't try to auto stabilize. The manual says it is suppose to. I'll just have to keep working on it. At least it flys. This is my first attempt at a multi rotor.
carr52 is offline Find More Posts by carr52
Old Nov 18, 2012, 07:31 PM
Captain3D's Avatar
Joined Jan 2012
Took it out for a flight. AUW 1750g on 9" props. Still getting a bit of jello but I didn't balance the props. I also found out that I don't need to hang the batteries out the back to balance like my other quads so I can save a bit more weight there.
First Flight on new, anti jello, frame and Sunnex lens modded GoPros (3 min 34 sec)
I will be redesigning as this evolves until I get it just right.
Cameras:
These are GoPro Hero2's (for Stereo) with the Sunnex lens mod to give a square picture.
DSL945D-650-F2.5
http://www.optics-online.com/EnterOrder.asp?ID=4446
http://www.optics-online.com/OOL/DSL/DSL945.PDF
The horizontal FOV is 60 as compared to the Hero 2 on 'medium', which I had used before, at 127. I like the square frame but the more 'zoomed in pic' mean you have to fly very slow to get something watchable.
phil
Old Nov 18, 2012, 08:23 PM
Birdman4498 is offline
Find More Posts by Birdman4498
Birdman4498's Avatar
Canada, ON, Ajax
Joined Jul 2011
X650 Spyder
That looks realy nice Cap't and I didn't really notice the jello you commented about, flies very nice. Here is mine out of X650 parts and a frame I drew up and was able to have DialFonZo to cut out for me. I am very happy with the outcome and has the portablility and size I was looking for.
X650 Spyder Quad maiden outside flight (4 min 22 sec)
X650 Spyder quad outside maiden (9 min 28 sec)
Birdman4498 is offline Find More Posts by Birdman4498
Old Nov 19, 2012, 02:55 AM
Captain3D's Avatar
Joined Jan 2012
Looking good Birdman. I see the slight Jello in mine viewing full res but I think I can tame it.
When you have something cut is it laser? cnc? Does it have to be from G10 or can they do ply as well? And what type of file do you have to create? CXF? and cost?
cheers...phil (still wearing out the jigsaw)
Old Nov 19, 2012, 02:57 AM
jamiedco is offline
Joined Sep 2012
i have a cnc machine at work but i know of a few guys who cut stuff in china and its well priced .
if you want me to send you there details pm me .
Old Nov 19, 2012, 03:44 AM
jamiedco is offline
Joined Sep 2012
Getting Braver With FPV (1 min 32 sec)
i have slight jello but i think that's just the props . i tuned the quad in crazy strong winds so there is no oscillation in low wind any more
Old Nov 19, 2012, 06:46 AM
Canada, ON, Ajax
Joined Jul 2011
Hi Phil, I had mine cut by Eric (DialFonZo). He posts in this thread and resides in Quebec. He has a CNC set-up that I believe he built himself. I sent him a photo of a mockup on how I thought it was going to look and then emailed him a scanned copy of a paper cut out I had done with the dimensions on it. I don't have a cad and probably wouldn't be able to use it anyway. I tried doing a wooden prototype but was not as accurate as yours in the cutting so after seeing some of Eric's work I decided to go straight to the G10. I am very happy with the results. I think once I ream the props and balance rather then drill, (which I noticed did put them off centre) the jello will be gone completely.
Dave
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
