Old Oct 09, 2012, 02:44 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
A little over 3 minutes on take 2 before one of the motor mounts failed and the unit crashed down. Thankfully I should be able to work off the wood and re-epoxy a new arm tonight. Needless to say I'm not amused.
The problem with wood, as I'm finding is that it's also very hard to get good, straight squares, so it has a rotational issue that it hard to pin down.
Grrrr
brontide is offline Find More Posts by brontide
Old Oct 09, 2012, 04:54 PM
MrKim is offline
Find More Posts by MrKim
MrKim's Avatar
Belgium, Vlaams Gewest, Maarkedal
Joined Sep 2012
X-Copter Two
Hi again!
A week ago i made a new and smaller quadcopter here are some Pics. Vids. & Specs.
X-Copter Two @ Airfield Maarke-Kerkem (3 min 30 sec)
X-Copter Two NightFlight (08-10-2012) (3 min 40 sec)
-Specs-
Motors: Turnigy 2204-14T 19g Outrunner
ESC: Turnigy 12amp Plush
Props: 8x4,5
Frame: Wood DIY
Batt: Turnigy 1300mah 3S 35C(To low only 4min flight time!)
Board: KK V2 LCD Board & Kaptein Kuk Firmware Update V1.2
Turnigy Receiver Controlled Switch & High Density Waterproof Flexible LED Strip
Question? Feel free to ask!
Kim D.
MrKim is offline Find More Posts by MrKim
Old Oct 09, 2012, 05:50 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I am preparing to build my first quad copter. Just wanted say thanks to all the folks that have helped along the way. Thanks.
Tom
carr52 is offline Find More Posts by carr52
Old Oct 09, 2012, 06:34 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Originally Posted by MrKim View Post
Hi again!
Kim D.
Sweet! I love wood frames.
2400RDR is online now Find More Posts by 2400RDR
Old Oct 10, 2012, 01:51 AM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Originally Posted by brontide View Post
Do they sell it without a seam, or did you glue it together yourself?
It has a glue seal already to be pressed together. Just peel off the cover and it sticks great. Actually I bought this on in OSH hardware.
phil
Captain3D is offline Find More Posts by Captain3D
Old Oct 10, 2012, 05:12 AM
brontide is offline
Joined Sep 2012
Third time's a charm?
Didn't like the lack of stiffness and straightness in the wooden frame so I fabricated a replacement frame for the electronics and did a transplant last night. One boom is wood in order to keep the weight down as one alu boom was more than stiff to prevent any edge to edge torsion all by itself. Whole thing is held together by 4 bolts and lots of zip ties.
Old Oct 10, 2012, 07:14 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
This is my list of parts I think I'll need except I'll be going with a 30 or 40 amp esc. I have my own Tx and Rx and battery. Did I forget anything?
Tom
Motor: http://www.hobbyking.com/hobbyking/s...ess_Motor.html
ESC: http://www.hobbyking.com/hobbyking/s..._ESC_2_4S.html
KK2 Board:
http://www.hobbyking.com/hobbyking/s...trol_Board.htm
Power board: http://www.hobbyking.com/hobbyking/s...ion_Board.html
Plugs : http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
Oh yeah and I too like wooden frames. Thanks for the pics.
Old Oct 10, 2012, 07:31 AM
brontide is offline
Joined Sep 2012
Tom, the links are broken.
Some things off the top of my head looking at my quad.
Does the motor come with a good mount for props, maybe get a "prop saver" for your shaft size.
Wires. Do you have appropriate gauge wire and heat shrink
Servo extensions. You have to plug something from the Rx to the KK2
Screws, bolts, standoffs, locknuts? Cheap from HK and the small metric stuff can be a bear to find in the US.
You probably have bullets, get more than you need.
Battery plug pairs. As always, get spares.
Of course I presume you already have batteries or can source them from a US vendor.
EDIT: Also, props?
Old Oct 10, 2012, 07:37 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Oops, sorry about that.
Motor- http://www.hobbyking.com/hobbyking/s...ess_Motor.html
KK2 board-
Esc- http://www.hobbyking.com/hobbyking/s...dproduct=25365
Old Oct 10, 2012, 07:40 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
http://www.hobbyking.com/hobbyking/s...ustomer=667550
This is suppose to be a link to my HK wish list.
Old Oct 10, 2012, 07:41 AM
brontide is offline
Joined Sep 2012
No good, sites says no items in the list. :-)
Old Oct 10, 2012, 08:27 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Do these links work on your end?
Old Oct 10, 2012, 08:30 AM
brontide is offline
Joined Sep 2012
Yes, these do.
Old Oct 10, 2012, 08:38 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I'm planning on making my frame using carbon fiber tube, plexiglass and aluminum. I'll try re-inserting the links for the motor and KK2. Board and other bits I'll be using.
Motor
http://www.hobbyking.com/hobbyking/s...dProduct=12920
Flight control board
http://www.hobbyking.com/hobbyking/s...dProduct=24723
Esc
http://www.hobbyking.com/hobbyking/s...dProduct=25365
Power board
http://www.hobbyking.com/hobbyking/s...dProduct=23140
Old Oct 10, 2012, 09:52 AM
highviz is offline
Find More Posts by highviz
Joined Mar 2009
Motor
Esc
Power board
Mmm- personally I would not use plexiglass (acrylic plastic) as it is very brittle and will not take kindly to any impact - If you want a clear plastic go for polycarbonate as it is much tougher. Otherwise use a reinforced plastic (grp etc) to get strength with lower weight.
Again only my observation, but the 1400Kv motor you list might not be ideal - you will have to run pretty small props to keep the amps down with that sort of rpm/volt. On a lightweight quad I'll go up to 1200Kv, but for most applications I tend to use 750 - 900Kv motors.
- Just my thoughts, but don't let my comments stop you experimenting ........
Malcolm
highviz is offline Find More Posts by highviz
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 92 Jul 16, 2016 04:49 PM
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
