Old Oct 05, 2012, 11:31 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
60W shld be fine! I do that with a 20/200W without needing to push that extra button.
What helps will be melting some solder on the thicker part of the tip and bring it to the bullet.
Perhap you shld drop off solder on the bullet and wire side first. As much as needed but not a blob of ball formed.
Then with the hot solder clinging onto the gun now, make use of the hot solder to transfer the heat to the bullet (becoz the bullet has bigger volume to absorb the heat faster), rather than relying on the heat from the tip to heat up the bullet to melt the solder.
The melting solder carries almost the same temp as the tip but transfer the heat to the bullet more effectively then jus the tip alone as it is in liquid state. Try again..
prodriverex is offline Find More Posts by prodriverex
Old Oct 06, 2012, 06:09 AM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
One other thing about soldering is that the tip of the iron has to be good. When the iron is hot and you melt some solder on the tip, the solder should flow and "wet" the tip. If the solder just forms a blob and doesn't flow out, you may as well forget it- you'll just be frustrated trying to solder with a tip like that.
Buy a new tip, learn how to tin and clean it, and it'll last a long time and give you nice results.
2400RDR is offline Find More Posts by 2400RDR
Old Oct 06, 2012, 06:16 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
That's the point, it was an 18w that was claiming to be "equivalent to" a 60w, if I had a 60w the thing would be wired up by now. I hate marketing. The only connecter that I could not do was the huge 8awg on the battery, it just wicked the heat too quickly to get the job done.
brontide is offline Find More Posts by brontide
Old Oct 06, 2012, 04:13 PM
2400RDR is offline
Joined Feb 2009
This conversation made me curious, so I went out to look at the iron I use for my heavy soldering- wiring harnesses, soldering Dean's connectors to 12 AWG wire and so forth. I was sure that it was a 35 watt, but it turned out to be a 25 watt iron. It does have a large chisel type tip.This iron does those heavy tasks no problem.
If you're going to be doing soldering, you really need to bite the bullet and get a good iron like a Weller and some decent tips that are sized for the job you're doing.
Rick
Old Oct 06, 2012, 04:16 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
This is the soldering Iron I use:
http://www.ebay.com/itm/60W-Solderin...item3a73bbd784
Came to me in a couple days, and has been working great! It heats up in a couple minutes, and makes soldering a very quick job! You have to be quick, or else you're going to mess up whatever your soldering (unless its heavy gauge).
The XT60 connectors I am usually very quick with. I tin the wire ends, and the connector, then let them cool. Then i'll hit them quick with the soldering iron to combine the two.
I need a 20-25w or something adjustable because you cannot solder to PCB boards with this thing.
This is the next Soldering station I want to buy: http://www.hobbyking.com/hobbyking/s...arehouse_.html
Im just upset I didn't buy one when they were in stock. I saw this exact same model, under a different brand name, for $119 at my local Fry's Electronics. Too bad too, cause Fry's will match Internet Prices, however I doubt they'll honor the price of another Brand.
AcroFPV is offline Find More Posts by AcroFPV
Old Oct 06, 2012, 06:11 PM
brontide is offline
Joined Sep 2012
I got it soldered this afternoon, even got one full pack through it before I did a tumble and bent one of my alu arms. Electronics are fine and I'm going to bang it out tonight and see if its salvageable. In the market for a frame that takes 11 props. As much as scratchbuilding can be fun, flying is more fun. :-)
Old Oct 06, 2012, 06:56 PM
The Engineer
Singapore
Joined Dec 2009
11? How so? Must be a big one coming!
Old Oct 06, 2012, 07:48 PM
brontide is offline
Joined Sep 2012
Yep, frame is a loss, time to rebuild. Electronics are fine, but two of the motor mounts were loose and needed to be tightened. Not going to stay up all night, I have a marathon to run in the morning.
Old Oct 06, 2012, 07:58 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
This is why I didn't decide to drill holes in my alum. arms.
Old Oct 06, 2012, 08:19 PM
brontide is offline
Joined Sep 2012
Next up, h quad build, but unfortunatly I need my sleep tonight.
Old Oct 07, 2012, 11:11 PM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Good luck on the Marathon brontide. What time are you going for?
I have been working on a few more frames this weekend...
The bigger one has 10" props with Tiger AT2216 1250kv motors and will run off a pair of 3s batteries. The small one in progress is an idea for running 8" props on 4s with the same motors. I am trying to build the smallest quad that can carry all the stereo camera and FPV gear. Although small it will still weigh about 1.8kg
cheers....phil
Captain3D is offline Find More Posts by Captain3D
Old Oct 08, 2012, 02:15 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Ditch the CD casing use a plastic RC Car body it would look perfect for a covering.
cheers....phil
speedactyl is offline Find More Posts by speedactyl
Old Oct 08, 2012, 06:13 AM
brontide is offline
Joined Sep 2012
3:32:22, not as fast as I had hoped, but still a personal record.
Old Oct 08, 2012, 06:28 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
+1!
those frames look like they were made for that!
dutchcommando is offline Find More Posts by dutchcommando
Old Oct 08, 2012, 09:27 AM
Captain3D's Avatar
Joined Jan 2012
Nice. I am going to make another attempt at breaking 3:00 at LA in March, It is proving elusive :-)
About the CD case...I love the geeky home made look of that round case. But do you have some examples of quads with car bodies?
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
