Old Sep 24, 2012, 10:46 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
haha i see teh kitteh.
sirbow2 is offline Find More Posts by sirbow2
Old Sep 24, 2012, 10:49 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
LOLZ myz to! black and white on da left..
dutchcommando is offline Find More Posts by dutchcommando
Old Sep 25, 2012, 01:03 AM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
Originally Posted by prodriverex View Post
Finished the frame just. Working on the electrical now..
Frame with motor and cable weigh 577gm.
Are those the nx-4006, nx-4008, etc? What size prop are you going to rock?
fallingdown is offline Find More Posts by fallingdown
Old Sep 25, 2012, 01:40 AM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
4008, on 1147
prodriverex is offline Find More Posts by prodriverex
Old Sep 25, 2012, 04:38 AM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Originally Posted by Boykintom View Post
Here's my wood frame quad. Looks kinda clunky, but it flies well, and transmits far less vibration from the motors to the center of the frame than my glass fiber hex. The controller is a Crius AIOP with GPS module wired to the board.
Great looking woody! I love wooden quads. In fact I'm wondering if there should be a subforum for them. That way we wouldn't be annoying all those guys that think alu/ fiberglass/ CF is the only way to go.
Did you have much trouble getting the GPS to work with the Crius, and how well does it hold? A friend of mine is busily trying to work that out just now with his AIOP.
Rick
2400RDR is offline Find More Posts by 2400RDR
Old Sep 25, 2012, 03:25 PM
highviz is online now
Find More Posts by highviz
Joined Mar 2009
Here's my selection of scratch built multis. Started with the Tricopter a year ago and they have been multiplying since! All have plywood centre plates which are then epoxy / glass covered - apart from the Tricopter which is left bare wood.
The X8 Octo is shown in the general line up with a simple test undercarriage, but now has a combined 3 axis camera mount and undercarriage. The mount is fitted with quick release fasteners, the legs unplug, and the octo arms fold for compact packing for transport.
Malcolm
highviz is online now Find More Posts by highviz
Old Sep 26, 2012, 06:43 AM
FlyingRodent is offline
Find More Posts by FlyingRodent
United States, OH, Columbus
Joined Jan 2011
Malcolm
Not scratchy at all!. Looks so good as if it were a production frame! Can you give us more photos? Details on the plug n play, motor mounts, gimble source (home made?).
Looks like you have a favorite motor...
FlyingRodent is offline Find More Posts by FlyingRodent
Old Sep 26, 2012, 07:17 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Malcolm
The motors look like DT7x0's; if I might inquire what's the props, power, and flight time on that beast?
brontide is offline Find More Posts by brontide
Old Sep 27, 2012, 10:33 AM
Hyptomenos is offline
Find More Posts by Hyptomenos
Joined Aug 2011
Poison arrow. The arms are made from aluminum arrows. Very light. Too much flex in the plywood deck, and the small diameter of the arms made it difficult to mount the motors.
https://sphotos-a.xx.fbcdn.net/hphot...35031746_n.jpg
Hyptomenos is offline Find More Posts by Hyptomenos
Old Sep 27, 2012, 06:56 PM
giek2000 is offline
Find More Posts by giek2000
Joined Nov 2008
Finally had some time to take my latest out
MWC 340MM QUAD (3 min 35 sec)
giek2000 is offline Find More Posts by giek2000
Old Sep 27, 2012, 07:55 PM
benybee is offline
Find More Posts by benybee
Indonesia, Lampung, Sukarame
Joined Dec 2009
Originally Posted by sleziak View Post
Turnigy Talon Hexcopter frame
HobbyKing Multi-Rotor Control Board V2.1 flashed with Hexacopter firmware
6x HobbyKing Red Brick 30A ESC flashed with simonk's firmware
6x Turnigy D2830-11 1000kv motors
3x Turnigy 2200mAh LiPo (6600mA total)
10x4.5 props
Flies like a dream, 30minutes + flight time with all 3 batteries connected
[IMG]http://i.minus.com/i3g2vTKwq1Yjr.jpg
sorry kinda OOT but i need help..
hi sleziak, you flashed Red Brick 30A ESC with simonk's firmware right?
witch .hex file did you use?
did you take the photograph of the PCB
thanks b4
benybee is offline Find More Posts by benybee
Old Sep 28, 2012, 02:16 AM
xardinen is online now
Find More Posts by xardinen
Joined Aug 2011
Originally Posted by speedactyl View Post
Slightly imbalance setup . FC Eagle N6
3pcs 30 A esc 850kv motor on 9x4
1pcs 50A esc 950kv motor on 8x4
test flight of Quadcopter with external power
range is only as good as the length and weight of the cable it will look better if it were a NAZA but I use the EagleN6
http://www.youtube.com/watch?v=b6ZFSDLhTdM
always funny till someone yank out the power cord
What kind of external power supply do you use if I may ask? It's a good idea to use while you configure your FC.
xardinen is online now Find More Posts by xardinen
Old Sep 28, 2012, 07:09 AM
sleziak is offline
Find More Posts by sleziak
Joined May 2011
thanks b4
I used this tutorial:
http://polakiumengineering.org/?p=1112
Regards
sleziak is offline Find More Posts by sleziak
Old Sep 29, 2012, 02:17 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
12v 7ah pb battery but you can also use a regulated 12v 3a powersupply. N your right best use when testing and config the FC that way you wont use your lipo cycles
speedactyl is offline Find More Posts by speedactyl
Old Sep 29, 2012, 08:04 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
This is my mini UFO quad. Spec is here: -
http://www.rcgroups.com/forums/showthread.php?t=1666155
Steveis is offline Find More Posts by Steveis
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 57 Apr 23, 2016 06:03 AM
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 01:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 10:16 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
