Old Aug 19, 2012, 01:00 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Nice work Dave!
That plane looks great!
johannlochner is offline Find More Posts by johannlochner
Old Aug 19, 2012, 01:50 AM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Thanks for the photos
I haven't seen sheet wax used before?
Could you give more details of its use and purpose.
Cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 19, 2012, 02:00 AM
dutchydawg1 is offline
Find More Posts by dutchydawg1
dutchydawg1's Avatar
Nor. Cal.
Joined Jan 2004
I like it !
dutchydawg1 is offline Find More Posts by dutchydawg1
Old Aug 19, 2012, 02:51 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
I learned how to use sheet wax while working in Grumman's Composites tooling dept. It come's in thickness's from .010-.250. and it come's with out an adhesive back or not. On the Tango I'm using it to give me a wing fairing joggle and a joggle for the nose cone. It save's you from doing alot of sanding on the plug in some cases. I'd rather spend time wet sanding the mold down to 2000 grit. And then compound it. The wax is very versitile and can be used for alot of different application's. go to freemanplastics.com I think. I'll double check that. Thank's for the compliment's.
prodjx is offline Find More Posts by prodjx
Old Aug 19, 2012, 02:54 AM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
I'm sorry freemansupply.com they have alot of neat tool's too.
Old Aug 19, 2012, 09:41 AM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Nice work! I've used sheet wax in the past but never thought of covering the entire plug and cutting bits out to create the step downs. Hmmm... ideas spinning through my head about how I could have used that to create the canopy frame on the 109. Oh yeah, I'm keeping that.
slopeiron is offline Find More Posts by slopeiron
Old Aug 19, 2012, 10:32 AM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
I remember using the wax to simulate a built up area of a lay up and making what we called a locating template that would go on the final lay-up between the bag and the actual part. A vane attempt to make bagged part look like an injection molded part, it worked so so.
Old Aug 19, 2012, 06:09 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Sheet wax?
I like the way you have made the mould feet! I will copy that.
However, I'm still a bit puzzled by the use and application of the "sheet wax".
Is it pressed onto the plug to do the job of a more conventional release system? Or has it something to do with the final shaping of it?
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Aug 19, 2012, 10:37 PM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
In the Tango's case any sort of irregularities in the plug can be blended you can even wet sand it. Just the warmth of your hand can make it stick to the plug. Of course I like using the the wax that has adhesive on one side. It also made it easier to put joggle's where I wanted to. Even though it is wax I still apply PVA just as a precaution. The backing paper has a shinny side that can be used to rub the wax and make it shinny as well.
Old Aug 20, 2012, 07:26 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Tango Drawings
Thanks Dave for Posting, I am so far behind you!!!! Here is what Dave started with!!!
Guess I will be busy cutting some wings and spar tubes-
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Aug 21, 2012, 02:05 AM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
You want to make a few of those wing set's. Today I pulled it apart, the plug is still intact. I won't post a photo or 2 yet till I totally detail the mold's. Basically they came out alright but I'm going to fill a void in the wing seat area while I'm detailing the other mold half. I hope to have a fuse done by the W/E, and a wing fairing to go with it. BTW thank's for the compliment's you did a nice design job.
Old Aug 21, 2012, 08:45 PM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
Ok the rough part of the mold's are done, I still have some area's to detail and make it look pretty.
Rave Giant Airliner Dancing With Stormy Weather At a Great Flight Field RcLento Foamies (Scratchbuilt) 1 Jul 22, 2012 10:47 AM
Sold great beginers radio.2x futaba skysport 4's and 2 jr quatro and more crash8384 Aircraft - General - Radio Equipment (FS/W) 5 Mar 30, 2012 05:53 PM
Discussion AP- Acrobats & Dance guyg Aerial Photography 4 Mar 10, 2012 05:18 PM
