Old Aug 18, 2012, 12:32 PM
flyrcusa is offline
Find More Posts by flyrcusa
Joined May 2012
Build Log
ARTTECH/HOBBYKING PITTS,foam scratch build
hello pilots.this scratch build is based around the shape of the arttech or HK pitts.the foam i use is the foamboard from walmart.and i remove the paper from both sides.the technique im using is one that i hope will be successful in all areas of flight.some parts/tail feathers etc,is 2pcs laminate that is roughly 9to10mm depending on expansion of gorilla glue.also are sanded to airfoil.the wings are a 2pcs type of build up to a airfoil.my goal is to get input from everyone and eventually make a kit that is cheap easy to build and fun to fly.with the down turn in the new home sales.ive gone from extra money for the hobby to extra money for the electric bill.
on this my first is the arttech pitts. with close to 35in, extra in the wing area and alot less weight.it should fly nicely.so please feel free to comment give input,and use any or all of what you like.i hope to end up with a package that would sell cheaper than you could go out and buy the foam.
thanx and enjoy
flyrcusa is offline Find More Posts by flyrcusa
Old Aug 18, 2012, 12:35 PM
flyrcusa is offline
Joined May 2012
the pic showing on 1st post is a mockup to place the struts.they will be 10mm foam with a air foil shape to min, drag
Old Aug 18, 2012, 12:43 PM
flyrcusa is offline
Joined May 2012
finished and ready to assemble
Old Aug 18, 2012, 12:51 PM
flyrcusa is offline
Joined May 2012
bottom of wing with 3/16 spar.possible serious overkill on pins
Old Aug 18, 2012, 08:56 PM
flyrcusa is offline
Joined May 2012
WING caps pretty straight forward.i was worried that the tops would warp the wing from bending over the spar,but i used the screen spline roller to kinda score it at the spar.then kinda helped it take shape before glueing
Old Aug 18, 2012, 10:11 PM
flyrcusa is offline
Joined May 2012
the fuse sides are simple also.the doublers are identical for each side except the aft.doubler at the tail feathers is only on one side.
Old Sep 21, 2012, 02:21 AM
rodair is offline
Find More Posts by rodair
What goes up must come down..
Canada, QC, Saint-Laurent
Joined Jan 2002
is this thread still active?
rodair is offline Find More Posts by rodair
Old Sep 21, 2012, 08:06 PM
flyrcusa is offline
Joined May 2012
Yes,im very sorry.my computer has been in the shop.will have the rest of the build up soon.thanx
Old Sep 26, 2012, 12:55 PM
flyrcusa is offline
Joined May 2012
im getting close to fuse asembly,and time to start thinking of push rods,servo tray,and batt tray or how ever you perfer to secure your batt.this is kit v2.when v3 is ready all off these issue will be ironed out.but as always to each his own.
Old Sep 26, 2012, 12:57 PM
flyrcusa is offline
Joined May 2012
im charging my camera batts now and will have this thread rolling again soon.sorry for the delays.
Old Sep 26, 2012, 03:54 PM
flyrcusa is offline
Joined May 2012
IN these pic's you see the F/2 doubler for the aft fuse.doubler is only glued to one side,and before glueing.i sand it down from 5mm to 1 to 2mm at the rear to follow the lines of the aft fuse.the extra F/2 you see just below is just a extra.in the kit it will come with 2 of everything.
Old Sep 26, 2012, 08:17 PM
flyrcusa is offline
Joined May 2012
here is the push rod guides for the tail feathers.a little sloppy, but its a prototype and im getting used to gorilla glue.it seems to be a awesome all around glue.i brought the tubes out at around 5/8' belowe ele.
Old Oct 07, 2012, 10:16 PM
flyrcusa is offline
Joined May 2012
fdw,fuse tail mockup
Old Oct 08, 2012, 11:02 AM
rodair is offline
Joined Jan 2002
Very nice! :-)
Old Oct 21, 2012, 08:14 PM
flyrcusa is offline
Joined May 2012
thanx rodair.sorry things are slow.im now on the V4.this one in the thread is V3.same build but with a few up grades.now instead of dowels in the wing spars.im useing aluminum arrows.archery arrows.this weight to strength is very nice and i am going to do a follow after i put the last few post on this thread.the arrows also give it a nice foil slightly thicker.which does give extra lift.thanx again
Discussion Whacky Goose 83" Foam Board Scratch Build GravyBones Scale Kit/Scratch Built 1 Aug 17, 2012 09:24 PM
Discussion F-15 foam first time scratch build, parts list, help wanna go faster Foamies (Scratchbuilt) 5 Jul 27, 2012 12:03 PM
Build Log Nieuport 17 foam scratch build sweeteye Scratchbuilt Indoor and Micro Models 29 May 30, 2012 08:54 AM
Discussion HobbyKing Pitts Model 12...Longest ARF build ever? JetPlaneFlyer Electric Plane Talk 20 Jun 10, 2011 07:37 PM
Build Log build thread,sapac/exceed/arttech/blitz/pitts S2A biplane guitaramp68 Foamies (Kits) 1 Aug 18, 2010 07:35 PM
