well seems I struck out
Dear Customer, Quote:
Hi guys,
I started a review on the Quebec Aerotow Association website. You can check it out here. http://www.quebecaerotowassociation.com/ In all fairness to RCgroups. I'll be copying everything as I go along here. Here is part 1 with the Manual. After having some problems getting the sailplane shipped to me in Canada. I finally received it on September 26th 2012. I ignore if there really exists a problem concerning the box size with U.S.P.S. All I know is that I received several e-mails cancelling my order because the box was over 40 inches in length. After some persistence, several phone calls and a few support tickets the sailplane got shipped. I must admit that I had given up and even started shopping for another model. The main problem was that all of the recommended hardware was already purchased from Hobbypartz - the sister company of Nitroplanes. Hopefully this scenario did not happen and everything ended well. The actual box measurements are 61.5 inches long x 15 inches wide x 8 inches high. Approximate weight is 10 lbs. I've had larger and heavier boxes shipped from the U.S to Canada but that was several years ago and certain companies may have put some limitations since then. A good example is Lipo Batteries. The box came in perfect condition and is very well packaged. The sailplane will not suffer any damages from normal shipping conditions. The fuselage is held in place by 2 small boxes at each extremity. This keeps the fuselage in the center of the box away from dents and at the same time the small boxes contain the hardware required to complete the Masala. Each wing section was individually packed in a plastic bag. The hard ware is also split amongst several bags and at first glance seems to be very good quality. On the Nitroplanes review thread there are several mentions of this sailplane being the OK Models Masala or it being the V-Pro Masala. I have not seen any info or parts at this point that would let me believe that this is made directly by OK Models for Nitroplanes. In any case... It's an amazing clone if it's not made by them because it sure looks the part. |
| Thread Tools | |
| For Sale Sharpwind 3.3 meter | Mauihiflyer | Aircraft - Sailplanes (FS/W) | 4 | Apr 23, 2012 03:52 PM |
| Discussion HELP NEEDED with a robbe ASW 24, 3.3 meter glider kit | ncornish_uk | Scale Sailplanes | 1 | Feb 17, 2008 01:19 PM |
| WTB: 3.45-meter Full D-Box Graphite Wing | Sled Driver | Aircraft - Sailplanes (FS/W) | 0 | Apr 23, 2004 08:24 PM |
