Old Aug 21, 2012, 08:05 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by modisc View Post
As Greg pointed out, the 12N4P should be using concentrated winding scheme, which the powercroco site only shows distributed winding scheme. Concentrated winding for 12N4P can have a winding factor of 1.
This is the image from the powercroco link you posted, it shows one phase wound it I understand it right.
I thought it was the first phase on the AbCaBcAbCaBc scheme that I got from the calculator.
But I don't understand the "concentrated" winding, is there an example of that somewhere?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 21, 2012, 09:43 AM
LOULE04 is offline
Find More Posts by LOULE04
Joined Jun 2011
Hello Jack,
I board requests made ​​in France to pocesseur of this engine.
I board a contact in progress. I ais the information I posteraient.
LOULE04 is offline Find More Posts by LOULE04
Old Aug 21, 2012, 02:56 PM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
Jack
I am sorry. I mixed them up.
The above pic you showed is distributed winding.
concentrated winding is the common one: each coil on each tooth.
12N4P is going to use distributed winding , to obtain a winding factor of 1. A normal distributed winding for 12N4P is going to be 0.5, as shown on powercroco winding calculator page.
modisc is offline Find More Posts by modisc
Old Aug 22, 2012, 11:49 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by LOULE04 View Post
Hello,
It semblerais that the winding of origin is like that.
A group of four son and two towers.
When you weigh?
Hello LOULE
It seems that the original windings are "overlapping coils"
Good for 12 slots 4 magnets
(not common for outrunners, common in inrunners)
Try (firstly) some number of conductors per slot and measure Kv
(for example 4 passages per slot)
Then you could modify the number of turns to get the desired Kv
(and choose the right wire diameter to fill the slots)
Another possibility is to use the "non overlapping" scheme
A-B-C-A-B-C-
I don't know the Kv differences for the same number of wires per slot
(but my personal(top-secret) software can do by brute force simulation)
Louis
Antony 92160 France
Fourdan is offline Find More Posts by Fourdan
Old Aug 24, 2012, 09:32 AM
LOULE04 is offline
Joined Jun 2011
Hello,
Photos winding original engine.
AWG 23 (7 wire parallel.)
I do not know the number of turns
A+
Old Aug 24, 2012, 09:37 AM
Jack
USA, ME, Ellsworth
Joined May 2008
If you can count or estimate the strands in one of the coils that will tell you the turns, it will be a multiple of 7 and the multiple is your turn count. I am guessing that it looks like about 21 strands or3 turns. Or maybe even 14 strands and 2 turns?
Jack
Old Aug 24, 2012, 10:00 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Jack
Hello
Good reasoning
I suggest to Loule to wind 6 turns A-B-C-A-B-C-
and to test for Kv (any wire diameter)
No epoxy in order to rewind again for getting the desired(approx.) Kv with the definitive wire diameter.
Interesting exercise !
Winding factor could be slightly less(con) ... but also less transit useless copper(pro) !
Louis
Old Aug 24, 2012, 03:49 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Couldn't it be wound ABCABC wrapping two teeth at a time?
Ron H is online now Find More Posts by Ron H
Old Aug 25, 2012, 05:37 AM
LOULE04 is offline
Joined Jun 2011
Hello,
I think here is a picture in the boninage engine.
With 7 parallel wire of 0.57 (23 Awg) X 2 turns
A +
Old Aug 25, 2012, 06:25 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello,
I think here is a picture ...
A +
Hello Loule
Could you please indicate for this Cyclon
* Stator diameter
* Stator axial height
* Internal diameter of magnets (or airgap)
Thanks for the infos
Louis
Old Aug 25, 2012, 06:33 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello
Not interesting .. problem of copper filling and transits
Non overlapping windings configs are :
AbCaBcAbCaBc
(and A-B-C-A-B-C-) see previous post
Louis
Help! hexTronik 16gram motor rewind ? StewieRC Electric Motor Design and Construction 7 Jul 18, 2012 03:11 PM
Help! Rewinding C20 1550Kv motor, some help needed. AleG Electric Motor Design and Construction 16 Jul 11, 2012 10:58 AM
Discussion Learning to rewind motor, any tips ? StewieRC Power Systems 8 Jun 22, 2012 09:12 AM
Sold Cyclone Power 70MM EDF motor 2500kv hi2nr Aircraft - Electric - Jets (FS/W) 3 Feb 24, 2012 09:09 PM
Discussion How to rewind a cyclon micro ? olof Power Systems 6 Nov 21, 2006 10:26 AM
