Old Aug 18, 2012, 10:53 AM
LOULE04 is offline
Find More Posts by LOULE04
Joined Jun 2011
Rewinding motor cyclon
Hello to all,
I ais recovered engine cyclon 5000 home Electronic-model engine manufacturerbrushless French.I must repeat the winding for the same KV as the original one a knowledge env 5000 KV.It is a stator has 12 teeth and 4 magnets.Could you me idiquer windings a content so that the diameter of the wire used.Thank you in advance for your help.Cordially Laurent.Designer French and I through a translator "BING"
LOULE04 is offline Find More Posts by LOULE04
Old Aug 18, 2012, 11:31 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
It seems that Google 'translate' might work a bit better :-)
Measure the thickness of wire you removed and buy new wire to match?
Bare is offline Find More Posts by Bare
Old Aug 18, 2012, 12:10 PM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
Originally Posted by LOULE04 View Post
Hello to all,
you maybe talking about a 12N4P inrunner. in that case, you will be using distributed windings: http://www.tuning.powerditto.de/
choose "Mega 22-45-1,5E"
Above link is for 18N6P motor with distributed winding, which maybe a little bit difficiult.
modisc is offline Find More Posts by modisc
Old Aug 18, 2012, 05:24 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Can you post a link to the motor? At a dealer or maker?
google translation:
Pouvez-vous poster un lien vers le moteur? À un revendeur ou le fabricant?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 19, 2012, 03:05 AM
LOULE04 is offline
Joined Jun 2011
Hello,
The stator windings is naked without!
Hello,
It is an outrunner
[QUOTE=jackerbes;22483901]Can you post a link to the motor? At a dealer or maker?
google translation:
Jack[/QUOTE
Hello,
Sorry but the manufacturer no longer exists. The only dealer is HERE
@+ Laurent
Old Aug 19, 2012, 07:26 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Ceux ressemble Outrunners brushless typiques. Et si je comprends bien que vous avez déjà tous les fils dépouillé du stator.
Et vous voulez de l'aide pour revenir en arrière? Est-ce la question?
Est-il un de ces trois vu là-bas? Modèle 22, 32, ou 42?
Vous parlez d'un Kv 5000 (Trs / V), qui ne semble pas possible ou approprié. Savez-vous ce que le Kv est?
Autres informations à connaître serait:
1 - Le nombre de tours sur chaque bras stator.
2 - Qu'est-ce que le vent était d'origine (probablement dLRK)
3 - Comment il a été mis fin (Delta ou Wye)Those look like typical brushless outrunners. And If I understand right you already have all the wire stripped off of the stator.
(translated by google)
Is it one of those three seen there? Model 22, 32, or 42?
And you want help to rewind it? Is that the question?
You mention a 5000 Kv (Trs/V), that does not seem possible or correct. Do you know what the Kv is?
Other information to know would be:
1 - The number of turns on each stator arm.
2 - What the original wind was (probably dLRK)
3 - How it was terminated (Delta or Wye)
Jack
Old Aug 19, 2012, 07:47 AM
LOULE04 is offline
Joined Jun 2011
Re,
The kv of the motor was originally a 4750 kv. I wish I could rewind to get the aproximately mm kv.
I was unfortunately not more information. rather it ressembmerait the Cyclon car5000.
Old Aug 19, 2012, 08:07 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Then it is this motor:
http://www.mt-modelisme.com/2552:mot...n-car-5000.htm
Can you count the magnets inside of the magnet housing? And confirm that it is a 12 arm or 12 notch stator?
Those will help to get you close in choosing a turn count for rewinding. The motor probably only had 5 or six turns of wire on, does that sound about right?
Ensuite, il est de ce moteur:
Pouvez-vous compter les aimants à l'intérieur du boîtier de l'aimant? Et je confirme que c'est un bras de 12 ou 12 stator cran?
Ceux-ci aident à vous aider dans le choix de fermer un compte tour pour le rembobinage. Le moteur probablement eu que 5 ou six tours de fil sur, ça sonne à peu près juste?
Jack
Old Aug 19, 2012, 08:13 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
[QUOTE=LOULE04;22487156]Hello,
Hello,
It is an outrunner
google translation:
Jack[/QUOTE
Hello,
@+ Laurent
You need to post somes pics of the motor. 12N4P outrunner is not common. If so, it should also be using concentrated winding, probably.
Old Aug 19, 2012, 11:41 AM
LOULE04 is offline
Joined Jun 2011
Hello,
Here are pictures of four rotor magnets and the stator has 12 teeth.
I board also listed the branches of the stator.
Old Aug 19, 2012, 11:53 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Hello,
very clear!.
In this case, you will be using concentrated winding.
here is an ideal example from Powercroco: http://www.scorpion.powercroco.de/12N4P3530.html
this design is really rare ^^
Old Aug 19, 2012, 01:45 PM
Jack
USA, ME, Ellsworth
Joined May 2008
If you translate the last post there it says:
"..The engine worked, but the results were not so convincing that it would have been worthwhile to pursue the matter further..."
Maybe that is why they are so rare?
I notice that if you go to the winding scheme calculator and enter 12 slots and 4 poles it offers a winding scheme of AbCaBcAbCaBc:
http://www.powerditto.de/bewicklungsrechner.html
That has a low winding factor of 0.5 but maybe it is the only way to get a 5000 Kv motor out of that stator that an ESC can keep up with as far as the permutation frequency? I am guessing here if that was not obvious..
Jack
Old Aug 20, 2012, 11:33 AM
LOULE04 is offline
Joined Jun 2011
Hello,
It semblerais that the winding of origin is like that.
A group of four son and two towers.
When you weigh?
Old Aug 21, 2012, 06:51 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Hello,
When you weigh?
I assume this picture is a 0.5T winding. by the way, i dont think the picture shows the right winding scheme for 12N4P, i mean the label "start and end" is wrong. Please refer to powercroco's maga motor. Link is in my previous reply.
Old Aug 21, 2012, 06:55 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Jack
As Greg pointed out, the 12N4P should be using concentrated winding scheme, which the powercroco site only shows distributed winding scheme. Concentrated winding for 12N4P can have a winding factor of 1.
Help! hexTronik 16gram motor rewind ? StewieRC Electric Motor Design and Construction 7 Jul 18, 2012 04:11 PM
Help! Rewinding C20 1550Kv motor, some help needed. AleG Electric Motor Design and Construction 16 Jul 11, 2012 11:58 AM
Discussion Learning to rewind motor, any tips ? StewieRC Power Systems 8 Jun 22, 2012 10:12 AM
Sold Cyclone Power 70MM EDF motor 2500kv hi2nr Aircraft - Electric - Jets (FS/W) 3 Feb 24, 2012 10:09 PM
Discussion How to rewind a cyclon micro ? olof Power Systems 6 Nov 21, 2006 11:26 AM
