Australia
Joined Jun 2010
Hobbyking Dynamic-s vs ASK-21
Hi
I'm just trying to decide on my next glider purchase. So I was wondering if anybody had any thoughts on which is the better glider between the Dynamic-s and The ASK-21. Both seem to get reasonable feed back from what I've read so far. Mick DynamicS - http://www.hobbyking.com/hobbyking/s...arehouse_.html ASK21- http://www.hobbyking.com/hobbyking/s...dproduct=19699 |
Australia
Joined Jun 2010
Apparently the Dynamic-S is a clone of the Blaze from what i've read.
The Blaze is discussed in detail here- http://www.rcgroups.com/forums/showthread.php?t=1194905 Mine should arrive within the week if all goes well. Mick |
Australia
Joined Jun 2010
Well the Zephyr certainly fits the fun factor catagory, but it needs a regular pre-flight inspection due to a few problems. 1. The new type rigid EPO used on the Zephyr has some bonding issues with epoxy mostly, but CA as well. The wing mounts fall out from the factory, as do the servo horns. Basically everything that was glued from the factory has the potential to fall out. I even had a wing mount fall off that I had re-epoxy without taking any foam with it. Its CA'd now as well as taped. 2. The low wing design means that the wing catches on landing putting pressure on the wings to separate. Landings are hot if there is no head wind so care must be taken if you dont want to repair. Many of us have fitted body or wing skids to offer clearance from snagging. Programming spoilerons for deployment in calm weather landings is helpfull. Flaperons cant be used safely for landing due to the low wing design. Flaps hit first. 3. Foam control surface hinges split readily 4. Setting your elevator servo at 100% rate will tear the control surface. 5. Battery space is limited, so battery research is required. 6. 80mph is its top speed. This can be achieved with stock 3s setup. 4s setup results in battery space issues as well as a severe flutter beyond 80mph. A simple thrust tube on 3s can get it to terminal speed. Thats the negatives, but if you know all that and correct/modify its a great little aircraft. Its a little nerve wracking at first until you get used to the turbine like sound. Its quick, aerobatic, and stable though if you fly within the limits of the airframe. I tend to fly a combination of gliding with a few high speed low passes. Landing is where most care is needed, and keeping a bit of power on through the turn like with all EDF's is a good idea. The Zephyr is still a favorite in my hanger to date. Mick |
Joined Mar 2012
I have both the dynamic s and zephyr v70. Both are fun but the zephyr doesn't really slope and has a pretty steep glide slope.
For windy days I often bring the dynamic s, it can climb like nothing else and I can keep it airbourne for 2 hours on a single 2200mah battery with a bit of wind. In terms of maintenance I agree the zephyr is a bit more needy and for my money feels more fragile because of the wing attachment design. On the other hand with the exception of a three point landing the dynamic s has only needed a new esc (stock one lasted about 15-20 flights from memory). If my zephyr gets destroyed I won't replace it, the dynamic s on the other hand would be missed when it is too windy for anything else I have. |
Thanks Mick and Groden. Good and useful feedback. The ducted fan sound is tempting, but might upset the more genteel members of my sailplane club. Plus I noticed on sloping that landing seems to be the trickiest part due to rotors and ground effects. I might go for a Speedy "crunchie" instead then. I'm told people slope with their Radian Pros, but it still seems light and a bit sluggy in flight.
Cheers! |
Australia
Joined Jun 2010
A friend of mine at the field is always reccomending his Super Dimona as good aircraft cable of both speed and gliding ability. I'm still flying EPO so far.
Link- http://www.hobby-lobby.com/superdimona.htm |
i'm new to gliders and have no real idea what to look for and how to get the max time out of a single 3s 2200. any tips would be greatly recieved. |
I had my second flight today with my Dynamic-S and had a ball. This is a new kind of plane and flying experience for me and I like it! Before this I have been flying my Hanger9 60" P-51, a very scale and fast warbird and my H9 80" Piper Pawnee. I had a great flight today in a good blow which it loved. Spent some time gliding around with a hawk who really seemed to like my bird as it was silent, like him...Between powered flight and gliding I flew approximately 35-45 min. way more than my usual 12 min. of powered flight, and much more relaxing. I believe I may be a convert to this way of flying. Like alot of other owner's my plane need's lot's of down trim on the port wing. It seem's as thought he starboard wing is thicker which would be heavier. Nothing look's twisted or out of whack. It has me in a pickle as of this time. As I have never flown a V-tailed plane, it crossed my mind to think that it somehow could be to blame, although I don't know how, unless it had something to do with the rudder configuration of which I am not well schooled. Dave/ZZ
Latest blog entry: My wind killer
Well I'm upto 15 mins flight times and then I have to land as I'm just not used to flying for so long.
I don't have any telemetry as only use a dx6i so that doesn't help with flight times. I am yet to fly in any winds over 7mph so can't say if that's gonna help or not.. This is also my first venture into a glider/warmliner and I have to say I love it, I'm even looking into a super sky surfer as my next plane. I have had to add some weight to the tail as its not possible to push the Lipo far enough back and still make sure the Velcro catches, and I also have a fair amount of trim on but I noticed one of my tips was a little twisted. I'm gonna order eagle tree guardian for it and see how that effects my flight times. |
| Thread Tools | |
| Discussion Hobbyking Ask 21 2m EP | barchiola | Electric Sailplanes | 2 | Jun 18, 2012 10:57 PM |
| Discussion Hobbyking ASK 21 2600mm Glider - good for first glider | Charlescd | Electric Sailplanes | 27 | Apr 26, 2012 12:47 AM |
| Discussion Hobbyking Piper Cub vs Dynam Piper Cub For First Plane? | HempfieldHunter | Beginner Training Area (Aircraft-Electric) | 2 | Apr 25, 2012 12:54 PM |
| Discussion Multiplex Blizzard vs. Hobbyking Dynamic S | sr71blackbird | Electric Sailplanes | 2 | Apr 22, 2012 12:43 PM |
| Discussion ASK-21 EPO motorglider from Hobbyking | GMB48 | Electric Sailplanes | 3 | Feb 17, 2012 09:17 PM |
