Espritmodel.com Heli Air
Old Aug 17, 2012, 09:35 PM
js32257's Avatar
Joined Dec 2011
How long does your 450 w/ torque tube take to spool down?
This obviously depends on headspeed, blade weight, pitch and I'm sure other things but I think it mostly depends on how "smooth" everything is.
I've been working on "smooth" for two weeks and I'm curious what the rest of you can pull off.
So...
I don't care what your throttle position is etc.
The only "rule" is be on the ground with your blades moving and then enable throttle hold.
How long does it take for your blades to stop moving?
28 seconds for me and I know I can go higher as I'm only at 60% throttle but this is how I want my throttle at low stick.
js32257 is offline Find More Posts by js32257
Old Aug 17, 2012, 09:49 PM
Joined May 2006
with a TT heli 450 size.. the blades are really free moving.. spool down maybe a couple of seconds.. but i really don't measure.... But I am pretty sure that the head is really free moving ad smooth as the blades can be blown by the wind if pointed against it
the TT is smoother by a few turns i guess against the belt of a BA
BA/PRO (0 min 24 sec)
soneebee is offline Find More Posts by soneebee
Old Aug 17, 2012, 09:54 PM
Joined Jan 2012
41 secs to a complete stop with my pro.
electrojolt is offline Find More Posts by electrojolt
Old Aug 18, 2012, 06:31 AM
js32257's Avatar
Joined Dec 2011
Based on your your videos and pics...I'd be surprised if someone beats that.
Old Aug 18, 2012, 08:22 AM
Joined Jan 2012
Thrust bearings on main shaft helps.. Also helps main bearings last longer. I have over 100 flights on very cheap mains on my pro and they are like new.
Old Aug 18, 2012, 10:42 PM
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
My Tarot 450 sport with TT is really free spinning. The idea is to land in stunt or idle up 2 with zero pitch and then hit throttle hold. also some 335mm or 345mm blades with more weight would make it spin longer.
barnstorm100 is offline Find More Posts by barnstorm100
Question how much does your 450-600 quad weigh RTF? STANG KILLA SS Multirotor Talk 7 May 11, 2012 09:20 PM
Discussion How long does Temp calibration take? rkenosha Hoverfly Technologies 5 Feb 24, 2012 06:31 AM
How long does it take to charge up your micros? Ni-Mh? Lipo? gotime242 Micro Helis 6 Oct 20, 2005 08:44 AM
How long does it take you to type www.ezonemag.com in your browser? e-sailpilot86 Life, The Universe, and Politics 14 Sep 08, 2005 02:04 PM
Question How long does it take to charge your LiPo? neuroblade Batteries and Chargers 24 Jul 26, 2005 01:24 PM
