Tupolev model 91
I have not posted in quite a while and never in this particular forum, but, hope that possibly I could get some input or let me know if this is the wrong sub-forum.
While flipping through one of my Russian aircraft books (actually in a couple of my books...I like Russian stuff...) I came across the Tu-91. For several years I had wanted to build one of these http://ram-home.com/ram-old/tu-91.html, but, just haven't had the motivation until recently. My thoughts were that this design had broadly pattern plane-like proportions, but, also had some dihedral in the outer wing panels for stability as I am a competent but not awesome pilot. My plan was for a wingspan of around 850mm to about maybe a meter. This would be about 1/16 to 1/18 scale. Construction is to be hot wire cut foam (the only thing I have used for scratch building). I was further planning to use low temp covering film over the foam for a stressed skin construction with carbon fiber reinforcing in critical spots such as the wing spar. I have thought about enlarging the tail surfaces by 15 percent and using a high lift airfoil on the main wing along the lines of the A-10. In fact I had planned to just copy the GWS A-10 airfoil. I want something that has the definite "flavor" of the full scale and still slows down pretty well. The contra rotating props should cancel out any torque as well. At this point I have most parts ordered, but, am waiting on the motor system. This is to be a contra-rotating brushless setup; really only because it looks cool as there is no efficiency to be gained that way. The first motors I ordered http://www.hobbypartz.com/88e-mc351-...e3-1550kv.html did not come with the nice spinners like it was supposed to so I have some on order from EBay http://www.ebay.com/itm/AEO-Model-15...11%26rk%3D2%26 as well as a lower KV version with two blade props http://www.ebay.com/itm/AEO-Model-11...item1e6ec99125. Both these come with nice spinners and that is important to me that it looks sorta scale. It might be overly difficult to try and make something totally scale, so, this is an acceptable compromise for me. I could really use any input/suggestions that the group here could offer as it has been several (5 or more...) years since I last scratch built anything. If this one works out I may consider building a larger one around a contra-rotating setup Hobby King sells which would be around 1.8 meter span. Thanks in advance for any help you can provide. |
[QUOTE=DR. JOY;22482220]
http://www.rcgroups.com/forums/showthread.php?t=1669382 http://www.rcgroups.com/forums/showthread.php?t=1672171 http://www.rcgroups.com/forums/showthread.php?t=1661701 http://www.rcgroups.com/forums/showthread.php?t=1252568 A thorough search will dig up even more. It's an interesting scale subject, and while you may not see a butt-load of comments, rest assured the scale folk hereabout will be looking in to see how you deal with any design dilemmas! James |
[QUOTE=Deuce;22482771]
I can foresee some problems but its the ones ya don't see that get me. I did just get back from picking up my thin ply for templates and man has it gotten expensive since my last purchase. I make my templates from ply covered in aluminum tape to give a smoother surface and cut. I adhere the templates to the foam with the UHU Por like glues on the template only. It holds it in place securely but can be easily removed. As far as covering the foam I have to decide between my original plan of low-temp covering or silkspan with thinned polyurethane varnish, odorless mineral spirit and gorilla glue suspension. That gives hard finish to the foam, but, is heavier than using the econokote. On the plus side it is lighter than fiberglass and gives a smoother surface. At any rate; I have the butcher paper, ruler and marker out and am going to go ahead and start finalising some plans (no CAD for me!). I will use the motor I have on hand to get started with thrust testing etc. I plan to post some pics of the equipment I have on hand later. |
Australia, NSW, Bungendore
Joined Jan 2005
Interesting aeroplane Dr J. I have no experience with foam being a balsa junkie but trying any new techniques on the minor parts seems a good way to go
![]() I'll be interested to see how the Contra rotating props work out as there are quite a few post-WW2 designs that are appealing. Keep the pictures and commentary coming - as James said, you may not get a truck load of input as you are 'outside the box' a little but we will be observing ![]() Pat |
Latest blog entry: A Big Move.....
I at least got the main wing plan view templates cut out today. I have also (after some input from the more scientific minds on the forum) come back to the Clark "Y" airfoil section. Now I just have to scale them and cut them out. I will try and get some of the wing blanks cut tomorrow, but, have family obligations and that comes first.
I am looking for some more opinions. I have retracts ordered. These are the ones http://hobbyking.com/hobbyking/store...idProduct=7701. I also have these struts on hand from a different vendor http://hobbyking.com/hobbyking/store...in_Trike_.html.
As I am still waiting on the retract units I am faced with the question of whether it is worth adding them or just go with fixed gear and save them for a different model. Essentially; is the lowered drag from the retracts offset by the weight of the system (87 gm for the struts and 88 gm for the retract kit if we believe the HK website). This is about 6 ounces more or less: I would say not a trivial amount of weight at this scale. This does not take into account the mounting plates for the wings etc. Granted it would be more scale and look quite cool to have the landing gear suck up out of sight with fancy sort of scale struts.......... I want some opinions. Would you go with a simple lighter fixed gear or go for the whole setup? Maybe I could use the struts in a fixed gear arrangement or alternatively just use the retracts without the fancy oleo's. Despite the fact that I have been flying for about 17 years or so I have limited experience with retracts and only have used them on ARF's where they are already installed. As always I really appreciate any ideas or thoughts. I do not think I am getting out of my depth here, but, I do like to try new things. In my previous planes I have just used simple fixed gear, so, this is a little bit of a departure. I do have some really small Robart mechanical gear here somewhere. Perhaps that would be a better plan? I do have to find them first. |
laminating the balsa blocks for the cowling/cockpit area. Additional pics of several contraprop units. Just got two from HK today and assembled them. They are for a future project. Also time to do a mid project workbench cleanup. Also carving and sanding away all the balsa that doesn't look like an airplane.
Still interested in any suggestions about retracts versus fixed gear. Slowly making progress. |
| Thread Tools | |
| Sold SAITO FA-91 Glow model engine, 4 stroke | moe money | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Aug 01, 2012 04:24 AM |
| Discussion Phoenix Models Edge 540 91-1.20 size | Nikolizer1 | 3D / Fun Fly Fuel Planes | 2 | May 21, 2012 09:35 PM |
| Sold O.S. FS-91 II Surpass (Pump) NIB Model #35910 | hobbyfun100 | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | May 16, 2012 08:44 AM |
| Discussion E.C.J Tupolev Tu-95 'Bear' | jeffhines2673 | Electric Warbirds | 14 | May 13, 2012 12:05 AM |
| Discussion phoenix models edge 540 91 1.20 somewhat "review" | out of stock | 3D Flying | 6 | May 04, 2012 08:48 PM |
