Old Nov 03, 2012, 08:33 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
You need the duct tape. It is like the force. It has a light side, a dark side, and it holds the world together
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 03, 2012, 09:39 AM
flymess is offline
Find More Posts by flymess
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
Mmmmm......
flymess is offline Find More Posts by flymess
Old Nov 03, 2012, 09:51 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
BTW, this one will go with 1800mAh 3cell Batt, 40A ESC, and just to ease it in, a 2900kv heli motor.
Flying this morning, after I crash!
VELCRO to hold the battery in place is how I go.
Old Nov 03, 2012, 10:01 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Didn't get to maiden "chucky" this morning, but just want to say that the nose cone is not essential for this thing to fly. It is essential for this thing to crash and survive.
The cone spreads and absorbs any impact (crumple zone) and if it gets too damaged it is simple to replace.
Also a note about the elevons. They are big but can be trimmed down if wanted, depends on your flying style. I chamfer the ends so that when I perform one of my cartwheel landings, it's the strong points of the plane that take the impact.
Old Nov 04, 2012, 11:59 PM
AERIAL MADMAN is offline
Find More Posts by AERIAL MADMAN
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
go hard and why not
why on earth would you want smaller control suraces!
go BIG just dont give as much input, until you want it.
as for the nose cone i can say it makes corlute wings nearly impossible to break.
well almost
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Nov 05, 2012, 01:30 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
hit a snag with battery placement. The sleek new nosecone and the snazzy hatch don't cut the mustard so gone back to the original type of cone with the flutes running across the plane. Gives a higher profile which might not look as good but is needed with my battered and swollen batts. I score the corflute with a phillips-head screw driver where it is to be folded over. Tape or ziptie cone to bottom of plane then the hatch cover is squeezed to fit in the cutout section of wing top which is now 50mm wide. The cover should be able to hold itself closed. If anyone wants more details just ask and I'll try to get better pics.
place a strip of strong tape across the hinge line or it will eventually break.
Old Nov 07, 2012, 11:31 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Did maiden today. First 3 hand launches weren't very good, but after a couple of adjustments, mostly throttle(about 3/4 , got it in the sky). Seemed to be very stable. Its a lot straighter than "pinky". It was very windy and 1 year ago I wouldn't have tried, but it flies good if you like fast electric. All landings were flat with no damage
Old Nov 14, 2012, 01:48 PM
Joined Aug 2012
corflute 70mm edf jet
my latest corflute jet build
I have had some experience with different jet shapes and designs but i wanted to build one with a sealed pointy corflute fuselage while profile jets are fun i wanted to build something a little cooler.
and here we go
the jet is 900mm long 600mm span
the wing section must have the flutes running across the wing
I took a piece of 900mm by 600mm flute and measured out the general shape of what i wanted the wing-tail section to look like nothing exact just add nose,wings,tail and done then measured an extra 2-3cm on the leading edge of the wing for folding later,you could fold more exposed edges if you wanted.
Old Nov 14, 2012, 02:23 PM
Joined Aug 2012
once you have your shape right fold under the 20-30mm on the leading edge of the wing and glue you could use clamps but beware they will leave marks on it,i used a big sleal tool box epoxy them and folded them over with the box on top =totally flat.
then mooved onto the upper fuse it is 550mm long 40mm wide on top 50mm high and i have left 20mm around the edge to fold under after it has had the flutes removed on the inner side.
your hight pretty much determines your angle at the nose so it is up to you where you finish your nose angle mine was 140mm back from tip.
Old Nov 14, 2012, 09:42 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
next installment please!
Old Nov 14, 2012, 11:52 PM
Joined Aug 2012
upper fuse
next i bent the upper fuse over to its final shape and placed lines where the overlap will be to be trimmed and the join line is straight to meet mid fuse correctly.
once desired shape was attained it was trimmed and glued with epoxy.
there are only 3 materials in this build,corflute.epoxy,paint and there is your airframe
Old Nov 15, 2012, 12:04 AM
Joined Aug 2012
up and mid join
whilst doing the join for mid and upper fuse i found it better to kind of tack it in place before properly applying glue and tucking overlap flap to the underside last
not all at once.
before this point best to think about cutting flutes for control surfaces as the mid fuse can no longer lay flat.
Old Nov 15, 2012, 12:13 AM
Joined Aug 2012
lower fuse
if you cant work it out forget the jet
Old Nov 15, 2012, 10:15 PM
Joined Aug 2012
fuse top bottom complete
with the fuse joined i am almost done with airframe,just a couple of rudders any shape you please.the motor is to be positioned with relevance to the battery size and setup you use,best to think about this at early stages but cut later.
Old Nov 16, 2012, 09:02 AM
Joined Aug 2012
airframe
just the gear to go in and away i go.
when the weather permits
Discussion Aussie Swift build photos and video GregK Slope 43 Dec 18, 2008 03:00 AM
Discussion Do I scratch build a 30's Aussie cruiser? windward Scale Boats 14 Jun 01, 2008 01:52 PM
Discussion Aussie only build a foamy comp thread :D woodsy Australia 132 Apr 08, 2008 07:06 AM
Discussion Aussie Aussie Aussie!!! madhun1 Life, The Universe, and Politics 7 Jul 20, 2007 09:08 AM
Yippee! Aussie Aussie Aussie Cranky1 Batteries and Chargers 6 Jun 03, 2004 08:09 AM
