Old Oct 29, 2012, 09:08 AM
flymess is offline
Find More Posts by flymess
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
more pics of delta build
flymess is offline Find More Posts by flymess
Old Oct 30, 2012, 01:12 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Place the servos against the skewers on the outside (inside will be the prop slot) after holding down the wing top, for clearance. As you can see I use zip ties to hold them in place but they will still wobble so I also use a little glue.
Work out where to put electrics and keep wires clear of prop slot. You can use velcro or double sided tape to hold the Rx and I add a zip tie for the heavier ESC.
Cut a little access hatch in the wing top before zip tying it down. Use your own dimensions but I went with 100mm back from nose, 100mm long, and 20mm cut into each side. You can hinge them just like the elevons, or just fold them back. Doesn't matter which, because the plan is to make a nose cone that will cover the hatch.
Cut the prop slot (can be cut from plan but I left it to make sure it was going to be in the right place, even then I mucked it up and mine is only 150mm wide so will be limited to 5" prop) You can cut it to suit what size prop you want but allow for it when you attach the skewers.
Old Oct 31, 2012, 04:58 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Pinky lives
Had a close look at my long time flyer "Pinky", because I thought it had seen too many crashes and was a goner. But, because it's a SPAD, all it needed was a little more glue to make it right. The servos, after many crashes, were twisting a little under strain so didn't have as much authority as they should have. some hot glue to secure them and it flew well again. Make this plane if you want something simple, and to learn how to fly fast on the cheap. Honestly, this thing can take a crash!
Old Oct 31, 2012, 10:38 AM
AERIAL MADMAN is offline
Find More Posts by AERIAL MADMAN
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
you know i am not a fan of dry larger for my builds and it makes all the difference you know
but new "PINKY" is looking good,is there enough airfoil to move the servos forward and hide them though the pushrods would be longer and there is two layers of corflute overlaping in there isn't there so servo arms would not reach through?
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Oct 31, 2012, 05:34 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Was confused by this statement, but just realized you must be referring to the beer on the corflute sign I'm using. I didn't even read what is says because when I see a sign I think "what can I make from that?"
The servos can be located inside the wing if desired. There is plenty of space under the aerofoil for them, but I went for external location for simplicity and ease of repair/replacement. There is a lot of room for variation in this design. It wasn't carefully planned and drawn up with consideration given to wingloading, airflow, turbulence, drag, ect. It's was more like "wonder if it will fly if I do THIS"
Anyone who decides to make this "little ripper" can change whatever they like with the details, it's the basic airframe that makes it a good flyer.
I wonder if "little ripper" might be a better name than "Pinky" ? might have been used before, but if not, that's what I'll call this new one.
Old Oct 31, 2012, 07:49 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Time to make the vert stabs or fins. On pinky they were a bit random, about 100mm high and swept back to look cool. This time they are going to be the same height but a bit longer to start with because I want to see what happens. Maybe I will not need the V-tail.
You can see that the fins are held on with 2 zip ties (smallest you can get). They are not glued and can pivot down flat which is good when you throw it in the car. Push a thin skewer into the end flute of each wing top and also that part of the fin that sits on top of wing (you might need to sand them down a bit to get them in). Trim them flush with edges of corflute then poke holes thru' the wing and attach them at the end of the wing top with the ties. they should snap down when pushed and snap back up when lifted. pictures explain better
Old Oct 31, 2012, 09:09 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Have just attached the vert stabs so here' the pics. I slide a piece of skewer cutt-off under the ties to prevent them from wearing thru' the corflute. There are a lot of zip ties used in this build so use the smallest you can get that will fit, except when mounting the motor because it will need to be strong.
Where you put the ties is up to you. I went for 40mm back from LE and about the same forward of wing top rear. This little part of the build really adds strength to the whole plane so pull those little ties nice and tight
Old Oct 31, 2012, 11:10 PM
Joined Aug 2012
looks great i think you can leave the v tail off it
chuck it in the car how about chucky paint it orange and put evil eyes on it
Old Nov 01, 2012, 01:15 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Motor mount.
There are a lot of opinions but mine is simple. I use a length of Aluminium, 20mm x 3.00mm flat bar. A whole metre costs 5 or 6 $, but we need only about 80 or 100 mm. I use a standard cross style mount as a template to drill the holes. position the motor on the mount so you can see where to bend it, allowing room for the motor to spin. Then bend the bar in a vice to an angle of about 85degrees. I'm still working with thrust angles but I find the plane wants to pitch up under acceleration if the angle is 90degrees. Anyway it can be bent again to get it right after a couple of flights. Big strong cable tie is used at the back of the mount because that's where the thrust hits. The forward tie doesn't need to be as strong because it just keeps the mount straight. Use skewers in the flutes of the wing top under the motor mount to prevent it being squashed. Do the same with a small length of corflute that goes underneath the plane. See pics
This mount is located for a heli style motor, the red one. If you use a motor like the gold one you will need to mount it forward more so that only the prop is hanging over the prop slot
Old Nov 02, 2012, 08:48 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
If anyone is actually following this build I would really like some feedback on this bit. The nose cone can be made in a couple of ways.(maybe more). There are advantages and limitations to both. What do you want, sleek, cool looking? Or functional, easy access?
I know what worked so well with "pinky" but because it's a new version I thought I'd try the other option. The folds didn't work out so good but you will get the idea I hope.
I also stuff a bit of foam into the nose to cushion the battery when you have those "hard landings"
any duplication of pics is accidental or deliberate
Old Nov 02, 2012, 02:41 PM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
I'd go functional. Unless you want to open it midair from so much speed. That could always be an aim
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 02, 2012, 07:46 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Some pics of nose cone and hatch flap. This is a bit experimental at this stage. The flap is hinged. It is held down with, you guessed it, skewers! Hope the pics explain. Pls ignore the shadow that makes the wingtop look wonky
Old Nov 02, 2012, 08:28 PM
Joined Aug 2012
chucky looks great,no not working for you how about zippy works on two levels?
are the vert stabs glued or is it a fold away job
looking like a maiden flight is imminent
Old Nov 03, 2012, 08:19 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
I don't know 1/2 what you're saying but I do like "Chucky" as a name for this plane.
btw the stabs are:
Old Nov 03, 2012, 08:25 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
SM This thing is so fast that you couldn't open a window if you were in it. It's shear speed that keeps everything held down (that and zipties)
Discussion Aussie Swift build photos and video GregK Slope 43 Dec 18, 2008 03:00 AM
Discussion Do I scratch build a 30's Aussie cruiser? windward Scale Boats 14 Jun 01, 2008 01:52 PM
Discussion Aussie only build a foamy comp thread :D woodsy Australia 132 Apr 08, 2008 07:06 AM
Discussion Aussie Aussie Aussie!!! madhun1 Life, The Universe, and Politics 7 Jul 20, 2007 09:08 AM
Yippee! Aussie Aussie Aussie Cranky1 Batteries and Chargers 6 Jun 03, 2004 08:09 AM
