Espritmodel.com Heli Air
Old Oct 19, 2012, 07:18 AM
Alpha Whisky
Queensland - Australia
Joined Jan 2006
Originally Posted by flymess View Post
Simple QHOR with corflute fuse. Simple but effective
As a matter of interest, what motor, lipo and ESC are you using here. I was going to go and order a G-25 motor ex HobbyKing here in Oz and take it from there ... existing 3S lipo around 2000 Mah and ESC maybe a Plush 40 ....
Alan W
AlphaWhisky is offline Find More Posts by AlphaWhisky
Old Oct 19, 2012, 07:59 AM
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
Alan W
AW,
Your Battery and ESC sound like they are good for this type of plane. I'll have to look up that motor. You only need a park flier sized elec motor. Lower Kv = bigger prop size. Better for you to look up dedicated threads about motors because I'm a bit random, and just try anything until it crashes (or burns up)
flymess is offline Find More Posts by flymess
Old Oct 19, 2012, 08:27 PM
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
QHOR looking good codger
i'll race ya. could be good for combat
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Oct 20, 2012, 06:18 AM
Corflute Codger
flymess's Avatar
Joined Feb 2011
Who is this Madman and when will he leave me alone?
You've got nothing close to the QHOR for manouverability(I give up with spelling) . Go fast fella, I'll catch you on the next lap. If you last that long!!!!
Old Oct 21, 2012, 12:03 AM
Joined Aug 2012
powered combat wing
here is a vid of one of my corflute combat wings a bit fast for combat but all the more interesting.
Fast EP corflute combat wing. (4 min 17 sec)
Old Oct 21, 2012, 06:35 AM
Corflute Codger
flymess's Avatar
Joined Feb 2011
Time for more combat, comrade. Now is the time to return to the "Zip-Tiger". Build it and die MF.
Use your best skills to make a plane that kills. I'll be!
Old Oct 22, 2012, 06:07 AM
Nitro2Burn's Avatar
Australia, NSW, Chittaway Bay
Joined Feb 2005
I am pretty busy leading up to this weekend as am going away large scale racing but will do you a plan as soon as I get back. Off the top of my head though the wing panel is 3 foot wide and 480 deep, fold it in half so it is only 240 deep and then I use 1 full length piece for the ailerons that I simply cut later to make into 2 seperate ailerons. I normally measure along the coreflute in distance (ie millimeters) and across the coreflute in segments (ie 7x 5mm segments instead of 35mm as it wont add up to 35mm
Nitro2Burn is offline Find More Posts by Nitro2Burn
Old Oct 22, 2012, 06:50 AM
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Originally Posted by steve wenban View Post
Adrian built and flew this at last years slope fest
Wow, that looks pretty amazing. But I think you gotta take the "S" out of SPAD for that one!
Early on in my rc plane life (only a few years ago really) I built a Mugi. It was way too fast for my abilities at the time, but heaps of fun! And tough. Ditched it 4 times out of 5 trying to get it in the air. Best effort was full throttle side arm launch, Mugi inverts itself and I managed to continue the roll and continue flying. Lucky there were some friends there to witness it!
aerophilia is online now Find More Posts by aerophilia
Old Oct 22, 2012, 07:01 AM
Nitro2Burn's Avatar
Joined Feb 2005
OK so here is a quick start on a fuse, I cut the coreflute 630mm long and mark across it 6-1-11-1-13-1-11-1-6 segments. Each single segment (1) marked as a full length black line in the pic is cut away from the top surface only, this leaves the outer skin but then allows the coreflute to fold easily. The sides fold up onto the bottom, making the last bottom piece segment also a side piece segment, hence why it is longer than the sides, and the same goes for the top.
I do all my measuring from the tail and is as follows, 100mm distance cut in for the horizontal stab and cut aways to have the rear taper in (this is done for structural strength). 160mm distance cut for vertical stab, this cut is only cleaning up the very edge of the half segment prior to the first full segment on the coreflute. 260mm the end of the wing saddle, you can see the shaded areas are what I cut out but I have omited the shape of the wing saddle once the top of the fuse segment is removed, to make this shape I usually just lay the wingtip on the side of the fuse and trace with a texter. 500mm distance to start of wing saddle. 600mm distance to start of fuse. from her to 630mm is little "shark teeth" I cut out and fold inwards to make part of the firewall that holds the ply to the plane.
To make the box section stick I use contact cement and place 3mm ply under the front section (500mm-600mm) and the same between the wing saddle and vert stab (160mm-260mm), I do cheat here and I will try and do a few more pics tomoz as I had a mate cut the ply plates with a laser cutter to save me time and the rear one has servo holes cut out of it.
Hope this is a helpful start
Old Oct 22, 2012, 01:04 PM
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
At this years slope fest phil did a fantastic job on a corro eagle
http://www.rcgroups.com/forums/showp...postcount=2046
steve wenban is offline Find More Posts by steve wenban
Latest blog entry: been there and back
Old Oct 22, 2012, 08:01 PM
Joined Aug 2012
one of these days i will build something good looking out of flute might go a pelican just to be different.I hear Andrews eagle still did not perform a good as hoped though it looked great when i saw it fly "shortly" at sandy headland did Phils fly nice
Old Oct 22, 2012, 08:16 PM
Joined Dec 2003
no both had control problems I'm sure they'll sort out before next years event
Old Oct 24, 2012, 01:18 AM
Joined Aug 2012
thanks bundy bear
one of my first corflute edfs
sorry for the brothers edit the edf sounds better
early stages of corflute building
whats your rum?
corflute/coroplast rc edf bundy jet (2 min 20 sec)
like the launch stance
guess my rum
Old Oct 29, 2012, 02:15 AM
Corflute Codger
flymess's Avatar
Joined Feb 2011
It's time to retire "pinky". It's had it's share of hard crashes (probably 20 or more), is still flyable but not as sweet as it was. Give you some pics of it now, a plan to make one, and some pics of the build of it's replacement. Don't let Pink put you off. That's just the colour of the plastic adhesive I used for orientation. This thing is no "sheila", it's a very versatile screaming jet which can be flown slow too.
Old Oct 29, 2012, 07:15 AM
Corflute Codger
flymess's Avatar
Joined Feb 2011
more pics of delta build. Note lots of small cable ties. Glue is messy and slow.
I use thick skewers to strengthen the rear of the plane. The central piece of corflute between the skewers is glued because it needs to be strong. Be sure to cut this piece so that the flutes run diagonally when compared with the base. The hinge for both elevons is made by cutting out one flute on the underside . The hook nosed blade in the pic is perfect for this job
Discussion Aussie Swift build photos and video GregK Slope 43 Dec 18, 2008 03:00 AM
Discussion Do I scratch build a 30's Aussie cruiser? windward Scale Boats 14 Jun 01, 2008 01:52 PM
Discussion Aussie only build a foamy comp thread :D woodsy Australia 132 Apr 08, 2008 07:06 AM
Discussion Aussie Aussie Aussie!!! madhun1 Life, The Universe, and Politics 7 Jul 20, 2007 09:08 AM
Yippee! Aussie Aussie Aussie Cranky1 Batteries and Chargers 6 Jun 03, 2004 08:09 AM
