Old Sep 24, 2012, 02:14 AM
AERIAL MADMAN is offline
Find More Posts by AERIAL MADMAN
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
On another note folks please obtain your corflute through legal means as we do not condone
getting caught and there are many ways to get free corflute.
make friends with your local bottleshop as they may have old stock they will never again use.
drawback sheets are only 900-600mm hence the previous post
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Sep 24, 2012, 09:57 PM
flymess is offline
Find More Posts by flymess
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
copied AM's sloper. Now for some combat when the wind picks up
flymess is offline Find More Posts by flymess
Old Sep 25, 2012, 02:12 AM
Joined Aug 2012
Bring it on Codger,i believe zip ties are illegal under regulation madman 243.
not to worry i will find the weak point and i am sure to find the planes too.
Old Oct 05, 2012, 06:04 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
To win combat, first you have to be in the air. I think that's one of the rules. Sitting in the pits sniffing glue DOES NOT COUNT
Old Oct 07, 2012, 05:37 AM
AlphaWhisky is offline
Find More Posts by AlphaWhisky
Alpha Whisky
Queensland - Australia
Joined Jan 2006
Corflute ...?
I came across this thread when surfing through here earlier today.....
O/D corflute models look to me to be a whole lot of inexpensive fun. What sort of glue do you guys use on these. I guess plastic tape may have a use here? Also, what do you use for spars?
Alan W
AlphaWhisky is offline Find More Posts by AlphaWhisky
Old Oct 07, 2012, 10:03 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Alan W
AW,
They are real cheap and really fun because you are not scared of breaking the plane so you get more adventurous. I'm a bit of a "hot-glue" fan because it's so quick, but you can go with epoxy if you like. I usually scruff up the part to be glued with something abrasive (wet'n'dry, sandpaper, or even steel wool) because corflute is very smooth and glossy. If you use advertising signs like I do you will need to remove some of the print because it will come away with the glue and your joint will fail. I am also a fan of cable ties to hold wings together because they are quick and you can easily open your wing up again if you need to.
Spars are whatever you want to use. Some of the small wings just use thick bamboo skewers. Also used plastic or fibreglass rods from old kites. You can go for carbon fibre for lightness and these can be slid inside of the flutes.
hope that helps
Old Oct 08, 2012, 12:09 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
here are some pics to give hints on how to make very simple planes
Old Oct 08, 2012, 12:49 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
here is a plan for the simple pusher jet. very crude drawing, I just hope it explains itself. If not, please ask questions. This thing screams with the right motor and is excellent for combat. It can take many crashes but doesn't like Gum trees
The wing top is only cut to size after it has been folded over. It will form it's own aerofoil shape if held down with clamps or some weights. Warming it with a hair dryer or heat gun will help, but it will melt if it gets too hot so be carefull. The most difficult part is cutting the hinge for the elevons, but once you've done it once it gets easier. CG is where it needs to be to fly well. Just experiment, it can handle a crash, I know!
Old Oct 09, 2012, 03:41 PM
Joined Aug 2012
anybody out there seen how fast they can push their corflute plane i have had a couple of attempts at this with some interesting results like it ripping itself apart mid air i will try to upload the vid,would like to get some best guesses for speed
time to try again
AM
Old Oct 09, 2012, 04:37 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Hey I just found this thread and love the simplicity! Roger I never knew you made so many powered palnes! That combat sounds like fun, would be great to take along to the slope some time when theres not much wind!
josh18 is offline Find More Posts by josh18
Old Oct 09, 2012, 06:01 PM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
Here is a pic of the air boat i built. It now also has a top skin and has an os 60 fsr which is being a real pita
scrub monkey is offline Find More Posts by scrub monkey
Old Oct 10, 2012, 03:00 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Electric's good, sniffer
Old Oct 10, 2012, 01:29 PM
Joined Aug 2012
thought i would share a pic of my air boat too obviously elec though and plenty of power at half to three quater throttle it wants to fly so i have been considering an flying version
Old Oct 10, 2012, 03:50 PM
Joined Aug 2012
fast corflute wing
here is the link to my fast corflute wing that rips itself apart,any ideas on how fast it was going?best guess
i am currently building a smaller wing with a similar setup i have a typhoon 2w18
not in use so i will give that a run on 4s with a 5x5 and if the plane lives through it i have left plenty of room for 6s to fit
Wing rip (3 min 3 sec)
Old Oct 10, 2012, 04:39 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
love it, especially the echo when it tears apart. Bet all the birds in the trees went "thank for that"
Discussion Aussie Swift build photos and video GregK Slope 43 Dec 18, 2008 03:00 AM
Discussion Do I scratch build a 30's Aussie cruiser? windward Scale Boats 14 Jun 01, 2008 01:52 PM
Discussion Aussie only build a foamy comp thread :D woodsy Australia 132 Apr 08, 2008 07:06 AM
Discussion Aussie Aussie Aussie!!! madhun1 Life, The Universe, and Politics 7 Jul 20, 2007 09:08 AM
Yippee! Aussie Aussie Aussie Cranky1 Batteries and Chargers 6 Jun 03, 2004 08:09 AM
