Old Aug 17, 2012, 01:17 PM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
what filler to use on abrams tank
hi all
going to be modifying the hull, deck and turret on the 1/12 abrams, get rid of all the stuff thats not on the real thing, i will be using plasti-card but i dont know what filler to use
will car/auto body filler work ?
regards nick
nick30head is offline Find More Posts by nick30head
Old Aug 18, 2012, 09:37 PM
FreakyDude is offline
Find More Posts by FreakyDude
FreakyDude's Avatar
Canada, ON, Barrie
Joined Jul 2011
Yes it will. I suggest you use glazing putty though and not a Bondo type material. Glazing putty sands easy and it will only take a few layers to fill in some holes. Sold in tubes where you get your autobody filler.
Originally Posted by nick30head View Post
hi all
regards nick
FreakyDude is offline Find More Posts by FreakyDude
Old Aug 21, 2012, 05:36 PM
R/CJohn is offline
Find More Posts by R/CJohn
Wilson
Peterborough Ontario Canada
Joined Feb 2008
Hey Nick
Auto body filler will work but be cautious, when the filler cures it heats up and will warp and melt the plastic. Your best bet is to use plastic filler for plastic models like squadron filler.
Auto filler is good if you want the look of damage
John
R/CJohn is offline Find More Posts by R/CJohn
Old Sep 02, 2012, 05:33 PM
nick 30
nick30head's Avatar
Joined May 2009
thanks for replys guys, i ended up using body filler, i used a bit less hardner so it cured over a few days, i was lucky as there was no melting or warping however the sanding did make a few marks so it will add to the effect, just got to install the bulldog/pershing gear boxes now to go along with the tiger sprockets and tracks
nick
Discussion 1/12 abrams tank mods nick30head RC Tanks 2 Aug 10, 2012 01:38 AM
Discussion @1st century abrams 1/6 scale tank.. broken dirtyfist RC Tanks 0 Mar 30, 2012 11:08 PM
Discussion M1A1 Abrams RC Tank with real Abrams Sounds! Blitzkrieg65 RC Tanks 8 Sep 07, 2010 04:43 AM
Discussion what filler are you all using on depron? lawn jockey Pusher Prop Jet Models 4 Apr 27, 2006 10:09 PM
