Old Aug 17, 2012, 09:29 AM
chawkins is offline
Find More Posts by chawkins
PBR Sailplane
chawkins's Avatar
United States, MI, Midland
Joined Jul 2012
Magnetic Building Board
I have seen here some folks using a magnetic board for building. Where can I find these? Been googling it, but not having much luck.
chawkins is offline Find More Posts by chawkins
Old Aug 17, 2012, 09:39 AM
chawkins is offline
PBR Sailplane
chawkins's Avatar
Joined Jul 2012
Actually started thinking "outside the box" Found magnets at Harbor Freight. Now to locate come 16 gage steen for the bench top.
Old Aug 17, 2012, 11:11 AM
Mr Smith1 is offline
Find More Posts by Mr Smith1
Mr Smith1's Avatar
United States, AZ, Scottsdale
Joined Jul 2011
I noticed those there the other day and thought of the same app.....then thot it would be too much hassle....pins, ceiling tile, bricks, and a small square....
Mr Smith1 is offline Find More Posts by Mr Smith1
Old Aug 17, 2012, 11:24 AM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
I have not made the conversion to the light yet,
http://www.rcgroups.com/the-builders-workshop-131/
http://www.rcuniverse.com/forum/forumid_180/tt.htm
http://www.airfieldmodels.com/inform...oard/index.htm
Enjoy,
jcstalls is offline Find More Posts by jcstalls
Old Aug 17, 2012, 09:44 PM
rmmoorejr is offline
Find More Posts by rmmoorejr
So that's how you throw a DLG!
USA, NC, Sugar Grove
Joined Dec 2009
I got mine from Tower hobbies many years ago. I still use it but I now have a steel door as a building table and it works well also.
rmmoorejr is offline Find More Posts by rmmoorejr
Old Aug 17, 2012, 10:17 PM
leaktech is offline
Find More Posts by leaktech
Balsa + glue + bluesky= fun
leaktech's Avatar
Phoenix AZ USA
Joined Jan 2009
Latch magnets here....
http://www.allelectronics.com/make-a...-MAGNET/1.html
Sheet steel here....
http://www.industrialmetalsupply.com/Locations
Magnet fixture ideas here.
I use a laser line tool to shoot a straight line on the steel without the plan. Set the magnets on the line and butt the bottom spar cap and sheeting to the magnets and use a second magnet to hold the cap down. I also make rib spacing/ square blocks to keep the wing accurate. Most plans are off a little so my wings are straighter now. This technique will change the order of construction steps in the instructions. I pop the wing off the steel to add epoxy in the joiners then do the final sheeting and LE. With laser cut ribs this method will make straighter wings.
leaktech is offline Find More Posts by leaktech
Old Aug 17, 2012, 10:56 PM
AndyRice_WI is offline
Find More Posts by AndyRice_WI
Helmet...check!!!
AndyRice_WI's Avatar
United States, WI, Prairie du Sac
Joined Sep 2010
I got the Airfield Models one... it's pretty good. Nice magnets and everything is built very nice.
AndyRice_WI is offline Find More Posts by AndyRice_WI
Old Aug 18, 2012, 09:44 AM
faa51408 is offline
Find More Posts by faa51408
Joined Feb 2007
Those AllElectronics magnets look like a great deal! I bought a big bag of cabinet latches from the auction site for about the same price and had to cut the plastic body out of each one. Get some good gel CA or Goop and glue the sides on the magnet so they won't come apart. For a magnetic board, the first one I had was a bulletin board purchased from Walmart for $9. I found out after a couple weeks that the cardboard backing would warp severely, turning my building board into a huge white potato chip. Get one of the better heavy duty bulletin boards from Staples or Office Depot, they'll stay flat and when not being used for building, hang it on the wall so you can post your RC to-do list.
faa51408 is offline Find More Posts by faa51408
Sold GP magnet building Board warbirdguyn951 Aircraft - General - Miscellaneous (FS/W) 3 Jun 19, 2012 12:01 AM
Wanted Building Clamps for a Magnetic Building Board stevster Aircraft - General - Miscellaneous (FS/W) 1 Jun 14, 2012 07:29 AM
magic magnet building board system jojo Electric Plane Talk 16 Jul 27, 2008 11:29 PM
Great Planes Magic Magnet Building Board cdw3423 The Builders Workshop 20 Feb 16, 2005 12:18 AM
Beware of Great Planes Magic Magnetic Building Board System Red Baron 47 Electric Plane Talk 8 Jul 19, 2001 10:24 PM
