Old Dec 02, 2012, 10:08 PM
Parift is offline
Find More Posts by Parift
Joined Aug 2012
Originally Posted by Zaitsevsky View Post
Guys, pay attention to the Ecilop policy:
If you copy this principle of camera stabilization, each technical or marketing text related to your product(s) must mention the name of the technology's author and an active link to Ecilop.tv (Camera rotation control by Aleksey Zaitsevsky, Ecilop.tv ).
You have copied 13/14:
The key advantages of Ecilop drones compared to other commercial light multi-copters (the list was compiled at the end of 2011):
1. The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.
2. The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.
3. The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.
4. Absence of a hard connection with the servo-unit prevents camera jerks and jitter.
5. Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.
6. Precise balancing of the camera mount makes it possible to use lightweight and fast servo-units.
7. Electronic gyroscopes are installed on the stabilizable part of the camera mount and prevent swaying.
8. Soft shock absorbers suppresses vibrations in a wide range of frequencies.
9. Shock absorbers are installed on the same level with rotation axis, which prevents camera swaying during maneuvering.
10. Onboard electronics is installed on the platform with shock absorbers. The increased weight of the platform makes it more stable.
11. Autopilot accelerometers are better protected from vibrations and therefore produce more accurate results.
12. The matching of the vertical center of mass of the drone with the rotor rotation plane decreases drone swaying during maneuvering.
13. The leaning of rotor blades towards of the drone's center improves stability and widens the camera's viewing angle.
14. The camera is fastened using a lens clamp. This type of fixture is more reliable, compact and weighs less than an underlying platform.
Translation of the patent application
6、Your sixth reason is:“Precise balancing of the camera mount makes it possible to use lightweight and fast servo-units.”
Sorry again:You should learn more in Electronics.
Repeat again:You make a big mistake.You buy a lock tail gyro and tell everybody you are the inveror of it!
Please check the details of your mistake here:
http://www.rcgroups.com/forums/showp...4&postcount=88
To the Mechanics,please check here:
http://www.rcgroups.com/forums/showp...3&postcount=90
Parift is offline Find More Posts by Parift
Site Sponsor
Old Dec 02, 2012, 10:13 PM
Parift is offline
Joined Aug 2012
7、Your seventh reason is:“Electronic gyroscopes are installed on the stabilizable part of the camera mount and prevent swaying.”
Sorry to tell the same words for the third time.
YOU SHOULD LEARND MORE IN ELECTRONICS!
And,one more question.
Do you know some thing about the basic principle of a lock tail gyro?
Site Sponsor
Old Dec 02, 2012, 10:22 PM
Parift is offline
Joined Aug 2012
8、Your eighth reason is:“Soft shock absorbers suppresses vibrations in a wide range of frequencies.”
According to your statement,this thing should be true:
Nobody set a soft damping mount in the camera mount before.
Only after your great product came out.
EVERYOEN COPY YOUR GREAT IDEA!
OK,then you are the greatest people in the world!
Then can you tell me ,why a great people like you can make such a mistake?
--You buy a lock tail gyro and tell everybody you are the inveror of it!
Site Sponsor
Old Dec 02, 2012, 10:25 PM
Parift is offline
Joined Aug 2012
9、Your ninth reason is:“Shock absorbers are installed on the same level with rotation axis, which prevents camera swaying during maneuvering.”
Please explain the difference between your great idea and that of the steadicam balancer first.
Site Sponsor
Old Dec 02, 2012, 10:26 PM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Ok, so you are an engineer, right?
This plastic camera mount is 100% copy from the Ecilop V1203.
You are talking about damping, but there is a rigid connection with a screw, so it is not a damper, but just a soft gasket. And what is this gasket for?
Ecilop battery platform allows to place the battery centered each time (position is fixed from both sides). How to place a battery to the same position each time on your mount?
Originally Posted by Parift View Post
5、Then let's check for the overall design of the frame.
Please check the appearance first.
Your fifth reason is:“Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.”
But many products could do the same thing before your great product came out.
EG:The camera mount of XA.
MANY MANY CAN DO THE SAME THINF!
NOT ONLY YOU!
Then let's check the details.
To see if you did everything better than the ZeroUAV.
Camera tray
①The one from ZeroUAV can be adjusted from left to right.
②The one from ZeroUAV has a special damping mount.
③That of yours,can not be adjusted from left to right,and has no any daming mount.
2)Battery platform
①The one from ZeroUAV can be adjusted in both directions:Holizone and Vertical
②The one from your product can only be adjusted in one direction.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Dec 02, 2012, 10:33 PM
Parift is offline
Joined Aug 2012
10、Your tenth reason is:“Onboard electronics is installed on the platform with shock absorbers. The increased weight of the platform makes it more stable.”
1)Sorry to tell the same words for the fourth time.
I can not beleave that a GREAT MAN like you can have the qualification to tell everybody that ZeroUAV copy your great idea about onboard electronics.
2)
"The increased weight of the platform makes it more stable."
Are you the first people who discover this true?
EVERYONE KNOW IT!
SIR!
Site Sponsor
Old Dec 02, 2012, 10:39 PM
Parift is offline
Joined Aug 2012
11、Your eleventh reason is:“Autopilot accelerometers are better protected from vibrations and therefore produce more accurate results.”
Sorry to tell the same words for the fifth time.
The single electronic parts in your product is bought from others.
So how can you talk about the "Autopilot accelerometers"
Site Sponsor
Old Dec 02, 2012, 10:44 PM
Parift is offline
Joined Aug 2012
12、Then to the twelfth reason:“The matching of the vertical center of mass of the drone with the rotor rotation plane decreases drone swaying during maneuvering.”
And the thirteenth reason:The leaning of rotor blades towards of the drone's center improves stability and widens the camera's viewing angle.
I'm so tired.
Please Learn more about ELECTRONICS first.
I am not so interested to talk with you now.
Site Sponsor
Old Dec 02, 2012, 10:51 PM
Zaitsevsky's Avatar
Joined May 2009
Signal from the gyro is necessary to eliminate swinging. Misconception of the single Zero-IMU was explained: http://www.rcgroups.com/forums/showp...&postcount=842
One of two gyros will not coincide with a first rotation axle if you place them in a single block.
Site Sponsor
Old Dec 02, 2012, 10:57 PM
Parift is offline
Joined Aug 2012
13、Your last and the fourteenth reason is:“The camera is fastened using a lens clamp. This type of fixture is more reliable, compact and weighs less than an underlying platform.”
1)You bought a lock tail gyro from others and tell everybody you make it,it is so funny.
And now,you do the samilar job one more time.
The camera tray is not inverted by you,OK?
2)In one words.
You know nothing about Electronics.
But you have told everybody : the lock tail gyro that you buy from other is a great idea of yours.
It makes me to doubt your behavior telling everybody that ZeroUAV is coping your ideas.
You want money only,right?
Please explain this thing first.
I do not want to talk to you any more before you can explain why you bought a lock tail gyro and told everyone you made it!
3)To those who want to know what's happening,please check the words below:
Site Sponsor
Old Dec 02, 2012, 11:11 PM
Zaitsevsky's Avatar
Joined May 2009
Are you the creator of this element?
2)In one words.
Ecilop - camera rotation control (soft connection with a servo plus a gyroscope), first patent LT5816.
Nothing more, no money, no time/profit limits.
Site Sponsor
Old Dec 02, 2012, 11:37 PM
Parift is offline
Joined Aug 2012
RESPONSE TO Zaitsevsky
OK,NOW I post all the posts response to your statement here:
1.The methold using a battery to be a balancer is not a new story.,especialy in the fix wing field. Here is a example,telling you how to use a battery to balance the fuselage of a plane.
The link:http://www.rc-airplane-world.com/bal...airplanes.html
Some words inside:“If the balance does need to be adjusted to get the correct Centre of Gravity, the first thing to do is try moving the battery pack and/or receiver further forward or backward inside the plane. By doing this you are adjusting the balance without adding extra 'dead' weight to the model in the form of ballast.”
Your first reason is :“The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.”
Then,can you tell me,is there something very different between balancing a fuselage of a plane and balancing the camera mount when using a battery to be a balancer?
2.
To a balancer,the tray balance is a good example.It came out in the middle of the nineteenth Century.
Your second reason is:“The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.”
Then,please tell me,does your great idea has nothing to do with the working principle of a tray balance?
And then,please tell me:did you copy the great idea of the Steadicam?
3.
Your third reaon is:“The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.”
Then I can tell you,there is an older balancer named "Chen".
The Chinese people have used thing thing for more than 1000 years.
Is your idea greater than this little thing?
4.
Your fourth reason is:“Absence of a hard connection with the servo-unit prevents camera jerks and jitter..”
Sorry to answero you know something about Electronics?
You bought a lock tail gyro of the Helicopter and use it be a stablizer,but the ZeroUAV is doing another thing.
They use the independent IMU to measure the attitude data of the camer mount,and then feekback the data to the aotopilot,and send out the special stabilizaation signal to stabilize the camner mount.
The two working methold is not the same thing. Between yours and theirs.
Please do not show your poor Electronic knowledge,OK!
The way of the ZeroUAV is a complete solution including Electronic parts and Mechanic parts.But there is only one thing related to the Electronics in your solution:the lock tail gyro of the Helicopter.
But you buy it from other people,right?
You buy something from other and tell everyone that you are the inventor of it?
You are so great!
NOT ONLY YOU!
Camera tray
2)Battery platform
6.
7.
8.
Then can you tell me ,why a great people like can make such a mistake?
9.
10.
2)
EVERYONE KNOW IT!
SIR!
11.
The single electronic parts in your product is bought from other.
So how can you talk about the "Autopilot accelerometers".
12.
I'm so tired.
13.
2)In one words.
Site Sponsor
Old Dec 02, 2012, 11:50 PM
Parift is offline
Joined Aug 2012
Originally Posted by zaitsevsky View Post
i have to be happy with such a primitive concurrents. But i'm not, because it is boring.
ok!
You are a great man!
You know everythinbg!
But please do not buy sth and tell others that you are the first people who make it again!
Site Sponsor
Old Dec 14, 2012, 03:52 AM
MAT1978 is offline
Find More Posts by MAT1978
Portugal, Faro District, Almancil
Joined Feb 2008
Ok have been reading this thread over and over, Seems like not one of these designs has anything over the other, just trying to grab the steadycam ap market with dlight difference in design, so brings me to this conclusion.
#1 Anyone following this thread must have some technical knowledge of how to create a frame
#2 Are more than aware what they want out of a ap vehicle for stable shots.
#3 Have experimented with frames , and tweaked them to try and get better results, and posted photos on sites like this.
So where did these designs originally form? In the minds of us all. In fact , when i started in ap videography , i modified an old quadframe to take a gopro steadycam on the FRONT of the quad with ok results, does that mean i came up with this idea? This is a highly competetive markryt and i think the only rule for the consumer is to go with quality, that can be very difficult when developers are trying to come up with cheaper and lighter solutions.
I also design engineering concepts within a team and many of my ideas have been improved with external input, so in my opinion the correct thing to do would to approach the ecilop designer with there ideas to improve the concept and to have a deal of commission with the designer if said improvement were implemented into the design. THIS IS CORRECT not to change the frame slightly and call it your own WRONG. I personally will be constructing a frame based on these ideas and a few of my own to create my OWN personal rig with no intention of producing it to sell. This market has been flooded with copycats and there is no point in patent with any so called new ideas because at the end of the day, the consumer will decide what he or she will purchase.
Whoever imagined putting a Steadicam on a quadcopter is utter genius and whoever you are, hats off to you. Who knows it could of been mel lol!!!!!!!
MAT1978 is offline Find More Posts by MAT1978
New Product Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors* Zero UAV Multirotor Electronics 2447 Today 05:46 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
Discussion The XAircraft X650/X650V MultiCopter (Aerial Photography & Video) owners thread xaircraft Multirotor Talk 20833 Nov 11, 2015 06:23 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Multirotor Talk 1 Jul 22, 2012 07:58 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Aerial Photography 0 Jul 21, 2012 04:45 PM
