Old Aug 28, 2012, 09:23 PM
fpvmodels is offline
Find More Posts by fpvmodels
Joined Jul 2012
Originally Posted by gondoflier View Post
excellent..im sure a lot of people are waiting to see this..I am one of them. Also, when will you give us the final price and release date for steadi470 ?
It will be released in September 10th, 2012.
Marketing Price: USD1999
Preorder deal before September 9th, 2012
USD1739 (USD260 reduced)
DELIVERY TIME: 30 working days upon receipt of full payment.
What are included:
1 Airframe×1
2 Camera Gimbal×1
3 Motor×4
4 ESC×4
5 Propeller×4
6 Servo×2
7 Flight controller×1(YS-X6 Basic 4 waypoints version + Steadi470 IMU)
fpvmodels is offline Find More Posts by fpvmodels
Site Sponsor
Old Sep 05, 2012, 03:35 PM
FPVer is offline
Find More Posts by FPVer
fly FPV
Germany
Joined Jan 2010
Hi,
I now have a zero UAV
But where do I get the firmware for Quadro X?
Or the controller recognizes that yourself?
Where can I set if I wanted to fly Quad X / +, hexer or Okto?
Thank you:
Alex
FPVer is offline Find More Posts by FPVer
Old Sep 05, 2012, 08:35 PM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Originally Posted by FPVer View Post
Hi,
Thank you:
Alex
If you have the YS-X6, in GCS, when you set it up (tap on Install Guide), there is a number to place in (from the manual). Choose your multirotor setup (ie:X quad, + Quad, hexa etc...) and put that in.
Follow the setup in Install Guide, and should be simple. Do this with no props.
Salocin is offline Find More Posts by Salocin
Old Sep 07, 2012, 08:38 AM
rwijnhov is online now
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
What is the price for the steady if you already own a ys-x6?
rwijnhov is online now Find More Posts by rwijnhov
Old Sep 07, 2012, 09:07 AM
Vivien Y is offline
Find More Posts by Vivien Y
Joined Jul 2012
PM already
Vivien Y is offline Find More Posts by Vivien Y
Site Sponsor
Old Sep 15, 2012, 09:33 AM
gondoflier is online now
Find More Posts by gondoflier
Joined Jun 2012
Originally Posted by fpvmodels View Post
hi yes, we will made raw video after our shanghai hobby show soon
and ?
gondoflier is online now Find More Posts by gondoflier
Old Sep 15, 2012, 02:04 PM
nicodh is offline
Find More Posts by nicodh
Joined Jan 2011
gondolfier, there is a "raw" video in the other post... well quality is not good, and it seems to be jelly...
nicodh is offline Find More Posts by nicodh
Old Oct 09, 2012, 12:37 PM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Another big problem of the Zero-steadicam-470 is explained here: http://www.rcgroups.com/forums/showp...5&postcount=78
The gimbal of the zero can not be tilted in proper way
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Dec 02, 2012, 08:38 PM
Parift is offline
Find More Posts by Parift
Joined Aug 2012
Originally Posted by Zaitsevsky View Post
Guys, pay attention to the Ecilop policy:
If you copy this principle of camera stabilization, each technical or marketing text related to your product(s) must mention the name of the technology's author and an active link to Ecilop.tv (Camera rotation control by Aleksey Zaitsevsky, Ecilop.tv ).
You have copied 13/14:
The key advantages of Ecilop drones compared to other commercial light multi-copters (the list was compiled at the end of 2011):
1. The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.
2. The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.
3. The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.
4. Absence of a hard connection with the servo-unit prevents camera jerks and jitter.
5. Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.
6. Precise balancing of the camera mount makes it possible to use lightweight and fast servo-units.
7. Electronic gyroscopes are installed on the stabilizable part of the camera mount and prevent swaying.
8. Soft shock absorbers suppresses vibrations in a wide range of frequencies.
9. Shock absorbers are installed on the same level with rotation axis, which prevents camera swaying during maneuvering.
10. Onboard electronics is installed on the platform with shock absorbers. The increased weight of the platform makes it more stable.
11. Autopilot accelerometers are better protected from vibrations and therefore produce more accurate results.
12. The matching of the vertical center of mass of the drone with the rotor rotation plane decreases drone swaying during maneuvering.
13. The leaning of rotor blades towards of the drone's center improves stability and widens the camera's viewing angle.
14. The camera is fastened using a lens clamp. This type of fixture is more reliable, compact and weighs less than an underlying platform.
Translation of the patent application
OK,now I will response to your reasons one by one.
1、The methold using a battery to be a balancer is not a new story.,especialy in the fix wing field. Here is a example,telling you how to use a battery to balance the fuselage of a plane.
The link:http://www.rc-airplane-world.com/bal...airplanes.html
Some words inside:“If the balance does need to be adjusted to get the correct Centre of Gravity, the first thing to do is try moving the battery pack and/or receiver further forward or backward inside the plane. By doing this you are adjusting the balance without adding extra 'dead' weight to the model in the form of ballast.”
Your first reason is :“The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.”
Then,can you tell me,is there something very different between balancing a fuselage of a plane and balancing the camera mount when using a battery to be a balancer?
Parift is offline Find More Posts by Parift
Site Sponsor
Old Dec 02, 2012, 08:52 PM
Parift is offline
Joined Aug 2012
To your first reason,the answer is here:
http://www.rcgroups.com/forums/showp...4&postcount=84
Then next.
2、To a balancer,the tray balance is a good example.It came out in the middle of the nineteenth Century.
Your second reason is:“The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.”
Then,please tell me,does your great idea has nothing to do with the working principle of a tray balance?
And then,please tell me:did you copy the great idea of the Steadicam?
Site Sponsor
Old Dec 02, 2012, 08:55 PM
Zaitsevsky's Avatar
Joined May 2009
Then next.
The answer was published:
This thread uses the term “steadicam”, which is wrong. Today, lots of camera mounts are sold under the Steadicam brand. However, the original Steadicam invention is comprised of arms and springs that transfer the weight of the camera onto the operator’s body. A multicopter has no human body and no arms with springs. That is why the use of the term Steadicam in this context is a mistake. Here is an image of the patented Steadicam element:
Garrett Brown is the author of Steadicam. Here is an image from his patent:
Garrett Brown is the author of a number of patents that have a camera with a counterweight, but it’s the additional elements that are patented, not the stabilization principle itself.
This stabilization principle had been known long before Steadicam. Here is an invention from 1931, where the patented object is a system with counterweights:
The patented feature of ECILOP drones is the method of camera rotation that uses springs on a servo gear and the use of a gyroscope for swinging prevention:
________________________________________
P.S. Is it a joke? It is not a "Zero-steadi470":
Couter-balanced camera mount was invented in 1931, Patent US2007215
Steadicam - a human body supported mount, first patent US4017168, year 1977.
Skycam - a cable supported mount, first patent US4625938
Ecilop - camera rotation control (soft connection with a servo plus a gyroscope), first patent LT5816.
Site Sponsor
Old Dec 02, 2012, 09:02 PM
Parift is offline
Joined Aug 2012
Your third reaon is:“The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.”
Then I can tell you,there is an older balancer named "Chen".
The Chinese people have used thing thing for more than 1000 years.
Is your idea greater than this little thing?
Site Sponsor
Old Dec 02, 2012, 09:16 PM
Parift is offline
Joined Aug 2012
4、
Your fourth reason is:“Absence of a hard connection with the servo-unit prevents camera jerks and jitter..”
Sorry to answero you know something about Electronics?
You bought a lock tail gyro of the Helicopter and use it be a stablizer,but the ZeroUAV is doing another thing.
They use the independent IMU to measure the attitude data of the camer mount,and then feekback the data to the aotopilot,and send out the special stabilizaation signal to stabilize the camner mount.
The two working methold is not the same thing. Between yours and theirs.
Please do not show your poor Electronic knowledge,OK!
The way of the ZeroUAV is a complete solution including Electronic parts and Mechanic parts.But there is only one thing related to the Electronics in your solution:the lock tail gyro of the Helicopter.
But you buy it from other people,right?
You buy something from other and tell everyone that you are the inventor of it?
You are so great!
Site Sponsor
Old Dec 02, 2012, 09:40 PM
Zaitsevsky's Avatar
Joined May 2009
4、
You are so great!
I have to be happy with such a primitive concurrents. But I'm not, because it is boring.
Site Sponsor
Old Dec 02, 2012, 10:01 PM
Parift is offline
Joined Aug 2012
5、Then let's check for the overall design of the frame.
Please check the appearance first.
Your fifth reason is:“Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.”
But many products could do the same thing before your great product came out.
EG:The camera mount of XA.
MANY MANY CAN DO THE SAME THINF!
NOT ONLY YOU!
Then let's check the details.
To see if you did everything better than the ZeroUAV.
Camera tray
①The one from ZeroUAV can be adjusted from left to right.
②The one from ZeroUAV has a special damping mount.
③That of yours,can not be adjusted from left to right,and has no any daming mount.
2)Battery platform
①The one from ZeroUAV can be adjusted in both directions:Holizone and Vertical
②The one from your product can only be adjusted in one direction.
Site Sponsor
Discussion The XAircraft X650/X650V MultiCopter (Aerial Photography & Video) owners thread xaircraft Multirotor Talk 20834 Sep 22, 2016 08:27 AM
New Product Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors* Zero UAV Multirotor Electronics 2457 Sep 21, 2016 08:15 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Multirotor Talk 1 Jul 22, 2012 07:58 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Aerial Photography 0 Jul 21, 2012 04:45 PM
