Old Aug 17, 2012, 06:46 AM
Zero UAV is offline
Find More Posts by Zero UAV
Joined May 2012
Zero UAV Quad discussion & questions
Hi All,
ZERO-Steadi470 Quad will be ready in two or three weeks, welcome all healthy discussions/questions here.
Characteristics
》 Controlled by YS-X6, simple configuration and calibration;
》 Pitch and Roll 2-axis angle can be adjusted by transmitter;
》 Easily controlled by personal handheld Phone/Tablet as ground station;
》 Intelligent course lock(Carefree ) function;
》 Intelligent interest point lock, target lock and follow me;
》 Special damper, maximize decrease or remove "Rolling Shutter";
》 Rapid and effective modification algorithm, strong video stabilization;
》 Stable aerial photography system with the highest P/C ratio.
Welcome to contact with us for more details or on any questions:
Sales: sales@zerouav.com
Technical Support: support@zerouav.com
Other information: info@zerouav.com
Website: www.zerouav.com
Zero UAV is offline Find More Posts by Zero UAV
Old Aug 17, 2012, 06:55 AM
Owen X is offline
Find More Posts by Owen X
Joined Jul 2012
Sofa
Cool!!!
Owen X is offline Find More Posts by Owen X
Old Aug 17, 2012, 08:43 AM
rwijnhov is offline
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Ok I want one.
rwijnhov is offline Find More Posts by rwijnhov
Old Aug 18, 2012, 01:15 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by rwijnhov View Post
Ok I want one.
Me too
robone is offline Find More Posts by robone
Old Aug 18, 2012, 01:33 PM
fpvmodels is offline
Find More Posts by fpvmodels
Joined Jul 2012
steadi-470 AP Solution (2 min 18 sec)
more videos coming soon
fpvmodels is offline Find More Posts by fpvmodels
Site Sponsor
Old Aug 18, 2012, 02:59 PM
robone is offline
Joined Sep 2010
Originally Posted by fpvmodels View Post
ZERO-Steadi470 AP Solution- start pre-order,
For more details, pls visit:
You sure know how to kill a thread quite quickly.
Old Aug 20, 2012, 02:59 AM
devfor is offline
Find More Posts by devfor
O <- this a ground loop
Japan
Joined Nov 2010
Not only kill a thread but piss off other vendors who cling on to their manners like gentlemen holding capes across muddy oceans so that young and inexperienced foreign market support reps in China may post more details about their products for us all.
So do you want to delete those watermarked photos too while the supplier prepares of list of where to by locations at the top of this thread?
(not you robone...)
devfor is offline Find More Posts by devfor
Old Aug 20, 2012, 05:51 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
This is where the future is at for frames.....flying gimbles!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Aug 20, 2012, 08:31 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
I really hope it is only a coincidence that it looks exactly the same as the patented Ecilop platform from Mr. Zaitsevsky:
http://www.rcgroups.com/forums/showthread.php?t=1640731
stanleyy is offline Find More Posts by stanleyy
Old Aug 20, 2012, 08:39 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I'm pretty sure I remember zerouav going on record about "not being in the business of making frames" when their FC was first released, in order to focus primarily on improving FLIGHT controllers instead of wasting time/money/energy/R&D into stuff that's already been rehashed millions of times.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 20, 2012, 08:52 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Originally Posted by Zero UAV View Post
ZERO-Steadi470 is an excellent Aerial Photography System which creats the greatest possibility to make the most stable aerial photography videos.
Guys, pay attention to the Ecilop policy:
If you copy this principle of camera stabilization, each technical or marketing text related to your product(s) must mention the name of the technology's author and an active link to Ecilop.tv (Camera rotation control by Aleksey Zaitsevsky, Ecilop.tv ).
You have copied 13/14:
The key advantages of Ecilop drones compared to other commercial light multi-copters (the list was compiled at the end of 2011):
1. The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.
2. The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.
3. The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.
4. Absence of a hard connection with the servo-unit prevents camera jerks and jitter.
5. Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.
6. Precise balancing of the camera mount makes it possible to use lightweight and fast servo-units.
7. Electronic gyroscopes are installed on the stabilizable part of the camera mount and prevent swaying.
8. Soft shock absorbers suppresses vibrations in a wide range of frequencies.
9. Shock absorbers are installed on the same level with rotation axis, which prevents camera swaying during maneuvering.
10. Onboard electronics is installed on the platform with shock absorbers. The increased weight of the platform makes it more stable.
11. Autopilot accelerometers are better protected from vibrations and therefore produce more accurate results.
12. The matching of the vertical center of mass of the drone with the rotor rotation plane decreases drone swaying during maneuvering.
13. The leaning of rotor blades towards of the drone's center improves stability and widens the camera's viewing angle.
14. The camera is fastened using a lens clamp. This type of fixture is more reliable, compact and weighs less than an underlying platform.
Translation of the patent application
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Aug 20, 2012, 10:09 AM
Zero UAV is offline
Joined May 2012
[QUOTE=Zaitsevsky;22497179]Guys, pay attention to the Ecilop policy:
Steadicam is invented by Garrett Brown and it has been registered by camera manufacturer Tiffen, even Iphone has "isteadi" inside. The entire ZERO-STEADI470 system is especially designed for overcoming the difficulties in using Steadicam and helps users a lot, which makes it more convenient for customers to use the Steadicam.What's more, the ZERO flight controller invented by Zero UAV not only supports the integration of ZERO-STEADI470 system, but also supports the ECILOP frame, users can saperately perchase YS-X6 Steadi470 version to control the frame of Steadicam structure. Not mention that ZERO-STEADI470 system is not cheaper than ECILOP, it's fair.
Old Aug 20, 2012, 10:33 AM
Vivien Y is offline
Find More Posts by Vivien Y
Joined Jul 2012
1. Autopilot accelerometers is placed in a built-in damper of IMU, there is nothing doing with a frame. Maybe you should say: configuration an autopilot to aircraft is your patent too?
2. The leaning of rotor blades..? Please carefully check ZERO-STEADI470 picture and physical, there have no any leaning of the motors. Probably you should go to check S800 frame's...
3. Precise balancing..? Please carefully check the standard Steadicam principle or Z15 of DJI. Does it say ECILOPS copied one kind of stabilization which come from a center of gravity and appropriate to yourself as a patent?
Does your frame patent not allow other people to sell controller or other system?
Vivien Y is offline Find More Posts by Vivien Y
Site Sponsor
Old Aug 20, 2012, 10:36 AM
Zaitsevsky's Avatar
Joined May 2009
Ok, remove springs from your ZERO-STEADI and try to use it with a usual servo-drive .
First patented invention of Garrett Brown is a human body supported camera mount US4017168, year 1977, brand "Steadicam" (do you have a human body on your frame?). Couter-balanced system was invented long before "Steadi" (see the picture).
It is not about "Steadicam", it is about camera rotation control with combination of springs and gyro. But you have copied much more.
Site Sponsor
Old Aug 20, 2012, 10:44 AM
Vivien Y is offline
Joined Jul 2012
I'm curious where your patent territory is? Got Chinese patent already? out of curiosity only!!
Site Sponsor
New Product Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors* Zero UAV Multirotor Electronics 2445 Jun 10, 2016 08:28 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
Discussion The XAircraft X650/X650V MultiCopter (Aerial Photography & Video) owners thread xaircraft Multirotor Talk 20833 Nov 11, 2015 06:23 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Multirotor Talk 1 Jul 22, 2012 07:58 AM
Discussion X525 Quad Copter For Aerial Video Or Photography? allrc Aerial Photography 0 Jul 21, 2012 04:45 PM
