Revolectrix diamond label 60C batteries
(stock photo)The GensAce 25C batteries I like are out of stock more often than not, and I hadn't yet heard of the Glacier batteries, so I took a gamble and picked up some Revolectrix Diamond Label 60C batteries. Some 4S 2200 mAh, and some 3S 2200 mAh. These are made (or distributed?) by the same company that makes the Cellpro PowerLab8 charger. They claim the packs are made fresh the same day as your shipment, and that seems to be the case. Delivery is overseas via UPS to the U.S.--a requirement, possibly a legal requirement. Diamond Label 60C batteries Initial observations: The batteries do not come with main power connectors. I soldered on some HXT connectors—the same type of connector that comes pre-soldered with the Gens Ace batteries. I like these connectors because they have high current carrying capacity, have excellent hold power, yet the plastic connectors have enough purchase to pull them apart without the slip ring pliers I have to use on new EC5 connectors. The wire used for balance connectors is not insulated with soft high temperature silicone insulation used for the main power leads. Whether this is better, worse, or of no practical difference I don't know. But the balance wires on the Revolectrix batteries are stiffer than my Gens Ace balance wires, possibly indicating the wire is solid conductor--which would be worse as far as durability goes in my opinion. The label on the batteries is different than what is shown in the photos (see photo below). The labels on mine had a white background, and looked like they were custom printed on-demand, using slightly pixelated fonts. They printed my name on them as well. This would be a problem if I had been picking them up for my son. Fortunately, I did not, so I have no problem with my name on the label, but this might be an issue if you're ordering extras for a flying buddy. Despite the series name, the labels weren't made from diamonds, which is disappointing if you're hoping to sell the labels. When I opened the package, I thought, wow, these can't be 2200 mAh batteries--they look so small. But then I held it next to a Gens Ace, and they were the same size. The black shrink wrap just makes them look smaller. The batteries were delivered storage charged at about 3.84 volts per cell. I am putting the 4S 2200 mAh batteries through some 4.2->3.7 charge->discharge cycles on my iCharger 3010b and paraboard, and hope to fly them sometime this weekend. I understand my charger may be able to measure the internal cell resistance, so I will have to look up how to do that, and then compare results with my Gens Ace 25C batteries. I am neither recommending nor discouraging anybody from buying these batteries. I'm just reporting what I received and my initial observations. I may seem a little more negative and tougher than other reviewers, but I give the reviews I wish others would write. The true test of whether I like these batteries won't be until I get 100 flights on them, and they haven’t puffed, and are still going strong. Regarding packs being made same day as shipment: One oddity is their website is listing 3S 2200 mAh batteries as out of stock, but not the 4S 2200 mAh batteries. This could be because they are out of the 3S balance cables, but that doesn't make sense either because the 3S 3700 mAh are in stock, which also has the claim "packs made fresh same day as your shipment". So maybe the 4S 2200 mah batteries should also be listed as out of stock. Or the cells are pre-matched before the packs are made. In any event, you might want to contact them before placing your order if your order is time sensitive, esepcially since it is being shipped from overseas. |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
The way to measure the IR from your iCharger is:
One pack at a time both discharge and balance connected, and at 3.85V storage. Press and hold the far left button (STOP) until it beeps. Then press once the second button from the left and you should see a message reading measuring IR. Would be keen to see what data you get on these as I'm about to pull the trigger on some 4s and 6s packs from these guys and still looking for reviews. |
Latest blog entry: full scale
Thanks for the background creapyd...I wondered why they were offering two different balance connectors.
While it is possible to charge any LiPoly thru the balancing leads only it gets a bit complicated when one has 1,2.3,4,5,6S LiPolys.
First balancing connectors were either Poly Quest / Hyperion or Tanic with JST parkflyer type with a single connector for each cell. Next was ThunderPower . If you want to read up on what early balancing was like. http://www.rcgroups.com/forums/showp...0&postcount=29 Charles |
I have a plane that pulls 800 watts static with a fresh gens ace. I flew it tonight, but I didn't bring the new batteries...only the gens aces. I'll try to get some flights on them this weekend. |
Sounds great.
Don't happen to have an eagle tree or castle logger you can plot to compare amps, watts and voltage sag in flight by chance? |
Actually, my son has one of my CC ESCs in his Extra 330LX. Good idea.
| Thread Tools | |
| Discussion Cellpro Revolectrix red label | appleflyer | Batteries and Chargers | 6 | Mar 18, 2013 01:47 PM |
| Discussion 60C Gens Ace batteries now in stock | Shortman | Batteries and Chargers | 9 | Oct 19, 2012 04:34 AM |
| Sold Neu Energy 4S Lipo Batteries 30c/60c 2500mah | sammydabull | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Jul 01, 2012 03:13 PM |
| Help! battery polarity not labeled anywhere? | unj008 | Batteries and Chargers | 1 | Apr 15, 2012 04:07 AM |
| For Sale FMA Direct Revolectrix Black Label 25C 3S 2200mAH batteries x 2 | metalhead1986 | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Jan 13, 2009 12:44 PM |
