Old Aug 16, 2012, 11:59 PM
szewang2805 is offline
Find More Posts by szewang2805
Joined Dec 2006
Hobbyhot:SKYRC TORO 1/8 RC Model Truck X8PT 2000KV Brushless Motor & 150A ESC Combo
SKYRC Launched a great 150A ESC with X series motor for 1/8 buddy
available at hobbyhot.com
Motor Specifications
Model: X8PT 2000KV
Suitable Model: 1/8 RC Truck / Truggy / Buggy
Motor Type: Sensorless
Rotation Speed: 2000KV (RPM/V)
Power: 3000 Watts
Max. Voltage: 23V
Max. Current: 130A
Resistance: 0.0064ohm
Poles: 6P
Motor Length: 74mm
Motor Diameter with Fins: 42.8mm
Shaft Diameter: 5mm
Length of Extend Shaft: 15mm
Weight: 445g
ESC Introduction
Toro 8 speed controls set a new standard in brushless performance and Toro 8 is big power in a small package.
This brushless, sensorless speed control is packed with many features making it unbeatable for either non stop fun or top level racing.
The features of Toro 8 can be easily accessed and adjusted using the program card. At the press of a single button you can adjust the LiPo battery voltage cut off, the maximum punch, the brake strength, the drag brake, the motor timing and the reverse lock out! All the setting will show on the program card at once.
The complete new design will prove that brushless technology has just reached a new high!
- Super smooth starting up
- New high performance heat dissipation power boards
- Built in ventilation fan for extreme cooling
- Safety features including thermal cut off
- LiPo/NiCd/NiMH Support
- New software increases power and top speeds
- New adjustable features via included program card- Very easy to use
- New high power brakes, fully adjustable
- New high power drag brakes, fully adjustable
- Support LiPo up to 6 cells
ESC Specifications
Function: Fwd/Brk or Fwd/Brk/Rev
Input Power (Cells): (2-6S LiPo)
Motor Limits
Brushless KV <= 2400: Up to 6S(25.2Volt), for 1/8 monster trucks and truggies
Brushless KV >2400: Up to 4S(16.8Volt), ideal for 1/8 buggies
On Resistance,Brushless: 0.0002 Ohms per phase at 25 C (77 F) Trans. Temp.
Continuous/Burst Current: 150 Amp / 950 Amp
Switching BEC: 5.7 Volts, 3 Amp
Status LED: 1 with 3 color (Red, Green & Orange)
Thermal Overload Protection: Yes
Dimensions(LxWxH): 48.8x57.8x35.8mm (1.29x2.28x1.41in)
Weight (Without wires): 88g (3.1oz)
Program Card Specifications
Dimension: 52.5 x 79.5 x 6.6mm
Net Weight: 11g
Suitable Model: SKYRC TORO ESC
szewang2805 is offline Find More Posts by szewang2805
Reply With Quote  (Disabled)
Discussion SkyRC Toro SC120 ESC and Toro 4P 3200Kv Motor szewang2805 Car Talk 1 Apr 25, 2012 09:32 PM
Sold Xerun 1/8th 2000Kv motor and 150A Sensored ESC combo - like new. ClayH Cars - Cars and Parts (FS/W) 1 Apr 07, 2012 08:46 PM
