My Slick is actually heavier, but I have big servos in it... If I take the weight difference in servos and everything else being equal, ie flight battery etc than the ExtraVaganza if 15g (yep that's right 15 grams) heavier. There is also a difference in motors too, the Slick has 70g motor and the ExtraVaganza has the 78g motor, with all that said, the airframes are essentially the same weight.
. cdee . |
. cdee . |
Ready Set..... Go..!!!
The last thing I do on a new build is to balance a new prop and put it on. I just balanced a new prop and put it on!! . I mentioned in an earlier post - 10 or 12 inch servo extensions... definetly 12 inch and that will be tight... you will have about 1/16" left over, or for you metric types 1.57mm! If you want a little more flexibility in where you locate your Rx you might also want 2 short extensions for the ailerons, like 2 or 3 inch OR even better yet, Brad at Twisted Hobbys has some 16" extrensions... then you could bring the servo leads straight in from the wing to give a litte extra in that direction and the Rx would be located right around CG. . Pictures below of the control throws, again, nothing special here, all the box stock stuff and right at 100% on the Tx for all channels. Pretty sure there should be enough control surface travel here to satisfy even the most extreme pilots! . The look on the Pilot's face is even more funny now while looking at this set of pictures!!... ![]() . cdee . |
| Thread Tools | |
| Sold Telink / Twisted Hobbys Extra Slick SU-29 LPU Monroe, MI | bcucoach2 | Aircraft - Electric - Airplanes (FS/W) | 7 | Jul 12, 2012 10:59 AM |
| Sold NYC LPU: Brand New Built 33" EPP Extra 330 SC | livinma1 | Aircraft - Electric - Airplanes (FS/W) | 9 | May 30, 2012 07:19 AM |
| Sold 3D Hobby Shop 48" Extra 330 EPP | FlyWW1 | Aircraft - Electric - Airplanes (FS/W) | 4 | May 16, 2012 08:09 PM |
| Sold 3D Hobby Shop 48" Extra 330 EPP | FlyWW1 | Aircraft - Fuel - Airplanes (FS/W) | 4 | May 16, 2012 10:45 AM |
